Workbench.xmi fails to load [message #1065250] |
Tue, 25 June 2013 02:27  |
I get this exception for a little while, but never needed to use any persisted state. But now, I want to use the getPersistedState-method of parts. Unfortunately the workbench.xmi isn't created correctly. Anyway it fails to load with the following exception:
!ENTRY org.eclipse.e4.ui.workbench 4 0 2013-06-25 08:09:57.466
!MESSAGE Unable to load resource file:/D:/runtime-test_2.4/.metadata/.plugins/org.eclipse.e4.workbench/workbench.xmi
!STACK 0
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: org.eclipse.emf.ecore.xmi.IllegalValueException: Value 'org.eclipse.e4.ui.model.application.ui.basic.impl.PartStackImpl@1c02c21 (elementId: de.cmp.test.stations.partstack.tree, tags: null, contributorURI: platform:/plugin/de.cmp.test.stations) (widget: null, renderer: null, toBeRendered: true, onTop: false, visible: true, containerData: 27, accessibilityPhrase: null)' is not legal. (file:/D:/runtime-test_2.4/.metadata/.plugins/org.eclipse.e4.workbench/workbench.xmi, 587, 277)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDemandLoadException(ResourceSetImpl.java:319)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:278)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:406)
at org.eclipse.e4.ui.internal.workbench.ResourceHandler.loadResource(ResourceHandler.java:234)
at org.eclipse.e4.ui.internal.workbench.ResourceHandler.loadMostRecentModel(ResourceHandler.java:202)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.loadApplicationModel(E4Application.java:370)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createE4Workbench(E4Application.java:220)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:557)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:543)
at de.cmp.test.main.e3.Application.start(Application.java:20)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:601)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Caused by: org.eclipse.emf.ecore.xmi.IllegalValueException: Value 'org.eclipse.e4.ui.model.application.ui.basic.impl.PartStackImpl@1c02c21 (elementId: de.cmp.test.stations.partstack.tree, tags: null, contributorURI: platform:/plugin/de.cmp.test.stations) (widget: null, renderer: null, toBeRendered: true, onTop: false, visible: true, containerData: 27, accessibilityPhrase: null)' is not legal. (file:/D:/runtime-test_2.4/.metadata/.plugins/org.eclipse.e4.workbench/workbench.xmi, 587, 277)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.setFeatureValue(XMLHandler.java:2658)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.setFeatureValue(XMLHandler.java:2643)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.setValueFromId(XMLHandler.java:2814)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.setAttribValue(XMLHandler.java:2716)
at org.eclipse.emf.ecore.xmi.impl.SAXXMIHandler.handleObjectAttribs(SAXXMIHandler.java:79)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromFactory(XMLHandler.java:2188)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromTypeName(XMLHandler.java:2091)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObject(XMLHandler.java:2026)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.createObject(XMIHandler.java:128)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleFeature(XMLHandler.java:1835)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XMLHandler.java:1018)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMIHandler.java:81)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:996)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:707)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.startElement(XMIHandler.java:163)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.startElement(AbstractSAXParser.java:506)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanStartElement(XMLDocumentFragmentScannerImpl.java:1323)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(XMLDocumentFragmentScannerImpl.java:2717)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(XMLDocumentScannerImpl.java:607)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java:489)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:835)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:764)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:123)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1210)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(SAXParserImpl.java:568)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl.parse(SAXParserImpl.java:302)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:175)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLResourceImpl.java:240)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1505)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1284)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:259)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:274)
... 23 more
Caused by: java.lang.IllegalArgumentException: The selected element org.eclipse.e4.ui.model.application.ui.basic.impl.PartStackImpl@1c02c21 (elementId: de.cmp.test.stations.partstack.tree, tags: null, contributorURI: platform:/plugin/de.cmp.test.stations) (widget: null, renderer: null, toBeRendered: true, onTop: false, visible: true, containerData: 27, accessibilityPhrase: null) is not a child of this container
at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElement(ElementContainerImpl.java:158)
at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.eSet(ElementContainerImpl.java:234)
at org.eclipse.e4.ui.model.application.ui.impl.GenericTileImpl.eSet(GenericTileImpl.java:119)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSet(BasicEObjectImpl.java:1071)
at org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.setValue(XMLHelperImpl.java:1204)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.setFeatureValue(XMLHandler.java:2653)
... 54 more
The RCP has one main Application.e4xmi and about eight fragments with one perspective per fragment.
I added the workbench.xmi to this post. I'd be really glad to get a hint on that.
Best regards
Bastian
[Updated on: Tue, 25 June 2013 02:40] by Moderator
Re: Workbench.xmi fails to load [message #1244050 is a reply to message #1065308] |
Tue, 11 February 2014 16:04   |
We are experiencing a similar exception in Eclipse 4.2 extended by Rational Developer for i v 9.0
From the .log:
!MESSAGE Unable to load resource file:/C:/Users/ekomeshak/IBM/rationalsdp/workspace/.metadata/.plugins/org.eclipse.e4.workbench/workbench.xmi
!STACK 0
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: org.eclipse.emf.ecore.xmi.IllegalValueException: Value 'org.eclipse.e4.ui.model.application.ui.basic.impl.PartStackImpl@49bbb05 (elementId: PartStack@2abada0b, tags: null, contributorURI: null) (widget: null, renderer: null, toBeRendered: false, onTop: false, visible: true, containerData: null, accessibilityPhrase: null)' is not legal. (file:/C:/Users/ekomeshak/IBM/rationalsdp/workspace/.metadata/.plugins/org.eclipse.e4.workbench/workbench.xmi, 3411, 1)
Very interested in updates as customer is pushing for resolution.
Re: Workbench.xmi fails to load [message #1244578 is a reply to message #1244342] |
Wed, 12 February 2014 09:48  |
The scenario is that the customer is trying to customize a perspective, and then when they load the workbench, their customizations are lost due to the exception.
So the elementId is being set by the Customize Perspective ... action in Eclipse 4.2
FUDForum. Page generated in 0.05446 seconds
