Home » Archived » BIRT » Report Preview doesn't work
Report Preview doesn't work [message #1065254] Tue, 25 June 2013 02:45 Go to next message
Came across this weird problem. I am using BIRT Designer 3.7 and recently updated to IE10 to fix some issues with IE9. However after this, preview doesn't work anymore. I click it, use the parameters that worked before, but clicking OK does nothing. No errors even pop up, I click OK and nothing happens at all. I tried changing it to external browser, using both IE and Chrome (installed on work PC) but nothing happens. Tried deleting the rptconfig files as well. Did updating to IE10 make it stop working? Do I need to get another browser like Firefox or Opera? I will need permission for that so I hope I don't have to deal with that hassle.
I can preview the item using Run > View Report at least, just that Report Preview makes my testing faster.
If it helps, I am using the standalone designer.
Re: Report Preview doesn't work [message #1065667 is a reply to message #1065254] Thu, 27 June 2013 01:36 Go to previous messageGo to next message
I'm downloading the 3.7 RCP designer, now. I'll check this out in the morning. There seems to be a problem with the non-RCP version when trying to use IE10 as well, but I get an error message.
Re: Report Preview doesn't work [message #1065676 is a reply to message #1065667] Thu, 27 June 2013 02:07 Go to previous messageGo to next message
I ended up just trying it now. I get an error when attempting to use IE10 with the RCP designer as well. Firefox doesn't work either. Chrome does though. I checked this with the latest version as well, and it works for me with all browsers. Interesting that Chrome doesn't work for you. What version of Chrome are you using? I'm using 27.0.1453.116
Re: Report Preview doesn't work [message #1065862 is a reply to message #1065676] Thu, 27 June 2013 19:40 Go to previous messageGo to next message
Mine is currently 27.0.1453.110. I don't even see an error message really. Seems like I will just have to live with having to use View Report to preview my reports.
Re: Report Preview doesn't work [message #1066883 is a reply to message #1065862] Fri, 05 July 2013 00:37 Go to previous message
Are you still having an issue with this? What all different preference settings did you use that didn't work?
Previous Topic:source code of BIRT: A Field Guide (third edition)
Next Topic:Excel import
Current Time: Sat Jul 19 16:32:43 EDT 2025
Powered by FUDForum. Page generated in 0.33232 seconds
