Issues debugging variables in Love2D with LuaJIT [message #1064774] |
Thu, 20 June 2013 21:40  |
I am having an issue with the LDT debugger when using a version of Love2D built with LuaJIT. I am able to step into the code and set breakpoints which get tripped. However, the Variables window is not being populated. During debugging, I see this in the Console:
DEBUGGER ERROR Command context_get caused: (998) [string "ltn12.lua"]:41: bad argument #1 to 'getn' (table expected, got nil)
stack traceback:
[C]: in function 'getn'
[string "ltn12.lua"]:41: in function 'chain'
debugger.lua:122: in function 'b64'
debugger.lua:1275: in function 'make_property'
debugger.lua:497: in function <debugger.lua:486>
[C]: in function 'xpcall'
debugger.lua:2885: in function <debugger.lua:2855>
[C]: in function 'pcall'
debugger.lua:2940: in function 'line_hook'
debugger.lua:2947: in function <debugger.lua:2945>
I am using Eclipse 4.2 with the Lua Development Tools plug-in 1.0 (installed via the Marketplace). I am debugging Love2D 8.0 with LuaJIT using a Lua Application Debug Configuration (not remote). I have tried both the debugger.lua linked from the YouTube video describing the Corona steps AND the debugger.lua from a thread on this forum (specifically referencing FFI support).
Any thoughts? I'm pretty pleased with plug-in thus far, and while I can proceed without the Variables window (I've been using print debugging with Lua for years), it would be mighty handy to have a fully functioning IDE for my larger projects.
Re: Issues debugging variables in Love2D with LuaJIT [message #1065241 is a reply to message #1064926] |
Mon, 24 June 2013 23:31  |
Thanks for the reply. I'm using a "Lua Application" with a custom Intepreter pointing to Love2D. No extra arguments to the Intepreter, no -e, and no file as argument. For the Debug Configuration, however, I send along the project path and I set the working directory to my source folder.
I removed the debugger.lua file and, yes, I am using the module loaded via LUA_PATH automatically.
As for the version of LuaSocket I'm using, I'm not sure. I'll have to do some digging. I'm using LuaJIT 1.0, I do believe: this version of Love2D was built by a user with LuaJIT, and is not the standard Love2D app.
FUDForum. Page generated in 0.03770 seconds
