Home » Eclipse Projects » Eclipse Platform » Java Editor on Dialog(JDT on Editor)
Java Editor on Dialog [message #1065228] Mon, 24 June 2013 17:59
I need a java compiler platform in my application. I can do this with JDT in RCP editor. But I want to open java compiler editor with button on dialog. When the button pressed, Java editor must open on top of the dialog. How can I do this. Is there any Java complier plugin I can open on dialog page.
Other solution I try create new window. And I open JDT Java editor in new window. But The new window opening as modeless. So that this new window move to bottom of the dialog. If I can open new window as model It will be other solution for me.
Thank you for your advise
Previous Topic:Reuse property tester from dependent plugin
Next Topic:Version problem
Current Time: Sun Jul 20 10:49:01 EDT 2025
Powered by FUDForum. Page generated in 0.04129 seconds
