Home » Eclipse Projects » NatTable » Auto resize Column/Row Width/Height empties table
Auto resize Column/Row Width/Height empties table [message #1065178] Mon, 24 June 2013 11:26 Go to next message
I've found a problem with automatic column/row resizing by double clicking or context menu.
It's reproducible for instance in the FreezableGridExample or even the "Default NatTable" example. If you scroll to the right and then auto resize a column so that the column width decreases, the whole table is emptied and only the grid lines are visible.
The same behavior applies to auto row resize if you scroll down to the end end then auto resize a row that decreases it's height.
Can you help me with that problem?
Cheers
Alex
[Updated on: Mon, 24 June 2013 11:27] by Moderator
Re: Auto resize Column/Row Width/Height empties table [message #1065182 is a reply to message #1065178] Mon, 24 June 2013 11:56 Go to previous messageGo to next message
Hi Alex,
Coincidentally, Dirk and I were just discussing this issue - he had discovered it in another context just this morning. It is a small bug in the way the viewport reacts to changing bounds (https://bugs.eclipse.org/bugs/show_bug.cgi?id=411509) I have fixed the issue and pushed the change. Please have a look at the latest snapshot to verify the fix.
Edwin
Re: Auto resize Column/Row Width/Height empties table [message #1065355 is a reply to message #1065182] Tue, 25 June 2013 08:08 Go to previous message
Thanks a lot, this helped. Smile
Previous Topic:NatTable bold border between rows?
Next Topic:CompositeMatcherEditor - how to add dropdowns to few column only?
Current Time: Sat Jul 19 23:25:54 EDT 2025
Powered by FUDForum. Page generated in 0.05931 seconds
