Home » Language IDEs » C / C++ IDE (CDT) » problem of C++ compile for AVR
problem of C++ compile for AVR [message #1064757] Thu, 20 June 2013 16:41 Go to next message
Hi all
at first , i'm sorry for my bad inglish Sad
Recently I've moved from the PN2 to the eclipse for AVR programming. (windows -> ubuntu)
I've installed the eclipse and AVR plugin.
It works well for the C language.
I have a correct old project I created through new->convert to a C/C++ project.
All settings are correct as far as I knew.
But the program will not compile.
see please :
index.php/fa/15327/0/
what is problem ?
Crying or Very Sad
[Updated on: Thu, 20 June 2013 17:36] by Moderator
Re: problem of C++ compile for AVR [message #1064795 is a reply to message #1064757] Fri, 21 June 2013 03:34 Go to previous messageGo to next message
I think that the program source code created by the eclipse itself is not a problem.
The eclipse has a problem only with sources that already existing!
Of course these are just my guess.
I'm confused!
It is highly likely that I'm wrong syntax Even though my source has already been correct in the "winavr".
please help.
solved temporarily [message #1064829 is a reply to message #1064757] Fri, 21 June 2013 05:29 Go to previous message
The problem was solved temporarily !
I delete the source .C files and copy their codes into their respective header files.
It's interesting that source and header files that created by eclipse work correctly!!
see:
index.php/fa/15336/0/
How can i catenate hader files to source files ??
No help ?! Confused
please help Smile
Previous Topic:C++ projects give no output, am I doing something wrong?
Next Topic:Remote Debugging with Eclipse CDT - Debug an Application that is Loaded Dynamically
Current Time: Sat Jul 19 05:08:12 EDT 2025
Powered by FUDForum. Page generated in 0.03819 seconds
