NoClassDefFoundError when trying to use jacl [message #1064827] |
Fri, 21 June 2013 05:20  |
I want to use some tcl code in java. Google revealed me that "jacl" should do the job via its function "eval". So I downloaded it and added the jars (itcl.jar, ..., tjcsrc.jar) to the project's (a plugin project) build path. Now the tcl code is needed when a certain handler is triggered. But then, as soon as I try to initiate the tcl interpreter via "Interp jacl = new Interp();" I get a "NoClassDefFoundError".
But the weird thing is that when I create a new java project, add the very same jars to the buildpath and do the same thing, everything works fine...
Do you have any idea why it doesn't work?
Maximilian
FUDForum. Page generated in 0.08185 seconds
