Home » Eclipse Projects » Gemini » Gemini JPA 1.2.0 M1 milestone available
Gemini JPA 1.2.0 M1 milestone available [message #1064362] Tue, 18 June 2013 17:24 Go to next message
1.2.0 M1 milestone supports:
- EclipseLink 2.5.0
- JPA 2.1 compatibility
- JNDI integration
It can be obtained from the downloads page:
http://www.eclipse.org/gemini/jpa/download/
or installed from the Gemini JPA P2 repository:
http://download.eclipse.org/gemini/jpa/updates
Re: Gemini JPA 1.2.0 M1 milestone available [message #1341864 is a reply to message #1064362] Thu, 08 May 2014 13:40 Go to previous messageGo to next message
Hi All,
What is the current plan for releasing 1.2.0? Will it be compatible to
EclipseLink 2.6.0?
-Gunnar
> - EclipseLink 2.5.0
> - JNDI integration
Gunnar Wagenknecht
gunnar@xxxxxxxx
Re: Gemini JPA 1.2.0 M1 milestone available [message #1365357 is a reply to message #1341864] Sun, 18 May 2014 19:05 Go to previous messageGo to next message
Yes, we will wait until EclipseLink 2.6.0 is released before releasing Gemini JPA 1.2.0, and make sure they are compatible.
-Mike
Re: Gemini JPA 1.2.0 M1 milestone available [message #1410369 is a reply to message #1341864] Wed, 20 August 2014 11:10 Go to previous messageGo to next message
Testing
Denis Roy
Eclipse Webmaster -- mailto:webmaster@xxxxxxxx
Re: Gemini JPA 1.2.0 M1 milestone available [message #1692360 is a reply to message #1410369] Wed, 15 April 2015 06:20 Go to previous messageGo to next message
Michael, any idea on 1.2.0 release date?
Pawel
Re: Gemini JPA 1.2.0 M1 milestone available [message #1703236 is a reply to message #1692360] Wed, 29 July 2015 11:47 Go to previous messageGo to next message
I wonder what the state of this project is. I'm using it quite a long time, just because I thought it would be the standard way to use JPA in OSGI. But setting it up was not easy, because it needs some kind of special loading order. Otherwise it will not work. I even have got the case where it sometimes works and sometimes not. Strange. What is the alternative to Gemini JPA:
* Apache Aries
* or the osgi.jpa.managed project from Peter Kriens (can't add the link because I have not got enough messages in this forum)
Re: Gemini JPA 1.2.0 M1 milestone available [message #1725009 is a reply to message #1064362] Mon, 29 February 2016 02:03 Go to previous message
Is there any chance the p2 update page could feature 1.2.0-M2?? Any life in here?? Smile
Previous Topic:ClassLoader Problem after switching to Java 8
Next Topic:JUnit - GeminiJPARunner
Current Time: Sun Jul 20 09:14:18 EDT 2025
Powered by FUDForum. Page generated in 0.04161 seconds
