Home » Eclipse Projects » EclipseLink » EclipseLink and MongoDB - Auto incrementing field
EclipseLink and MongoDB - Auto incrementing field [message #1063780] Fri, 14 June 2013 04:21 Go to next message
Dear all!
We're using Eclipse Link 2.4 with MongoDB.
Due to a business requirement we need to be able to generate an auto incrementing sequence (as documented here: docs.mongodb.org/manual/tutorial/create-an-auto-incrementing-field)
Has anyone ever had to do this? The problem is that the ObjectID's are not really human readable. E.g. in URLs: htt...://bookStore.com/books/51BAB665040EE9317CAD525A.
Our customer would like to be able to use an ID like 1234 to identify a book...
What do you think about this?
Is there a possibility to implement the solution proposed by MongoDB above with EclipseLink/NOSQL? Currently I don't see how I could call the mongodb-function "getNextSequence"...
Thank you for your help!
Cheers
Michael
Re: EclipseLink and MongoDB - Auto incrementing field [message #1064285 is a reply to message #1063780] Tue, 18 June 2013 10:39 Go to previous messageGo to next message
You can use a native query to create your id and either assign it to your object yourself, or use a custom Sequence in EclipseLink to use your function to define the id.
Another option would be to map a Sequence entity to a collection and keep a counter field in it that you increment and commit to get a new id (use optimistic locking).
Re: EclipseLink and MongoDB - Auto incrementing field [message #1064293 is a reply to message #1064285] Tue, 18 June 2013 10:52 Go to previous message
Perfect, thank you James!
Previous Topic:SetFirstResult and setMaxResult problem if exist @OneToMany relation
Next Topic:@OneToMany and @ManyToOne in MongoDB and JPA -EISOneToOneMapping cannot be cast to
Current Time: Sun Jul 20 12:03:04 EDT 2025
Powered by FUDForum. Page generated in 0.03702 seconds
