Home » Modeling » TMF (Xtext) » How to infer an annotation with a key-value pair
How to infer an annotation with a key-value pair [message #1064262] Tue, 18 June 2013 09:16 Go to next message
Hi all,
I'm using the model inferrer to infer an annotation, e.g., as follows:
annotations += model.toAnnotation("org.my.MyAnnotation")
I also managed to infer an annotation with a String value:
annotations += model.toAnnotation("org.my.MyAnnotation", "MyValue")
My question is, how to infer an annotation that has a key-value pair, e.g., @MyAnnotation(id = "MyId").
Oren
Re: How to infer an annotation with a key-value pair [message #1064302 is a reply to message #1064262] Tue, 18 June 2013 11:00 Go to previous messageGo to next message
There is no helper method for that so far. You have to create the
appropriate Jvm<Type>AnnotationValue using the types factory, assign the
value and add it to the annotation as in
org.eclipse.xtext.xbase.jvmmodel.JvmTypesBuilder.toAnnotation(EObject,
String, Object)
The name of the parameter is indeed a cross reference to a method of the
annotation type. So in addition, you have to find the operation with the
given name in the methods of the annotation type and set that as the
operation of the annotation value.
18.06.13 15:16, schrieb Oren Mishali:
> Hi all,
> Oren
Re: How to infer an annotation with a key-value pair [message #1080806 is a reply to message #1064302] Tue, 06 August 2013 07:48 Go to previous messageGo to next message
Have you been succesful with this? I'm having the exact same issue right now and I can't seem to figure it out.
Re: How to infer an annotation with a key-value pair [message #1080807 is a reply to message #1064302] Tue, 06 August 2013 07:49 Go to previous messageGo to next message
Have you figured this out? I'm stuck on this myself
Re: How to infer an annotation with a key-value pair [message #1081053 is a reply to message #1080807] Tue, 06 August 2013 14:48 Go to previous messageGo to next message
i dont get this point. the tipp was 100% straight forward
public class ExtendedJvmTypesBuilder extends JvmTypesBuilder {
	@Inject
	private TypeReferences references;
	@Inject
	private TypesFactory typesFactory;
	@Nullable
	public JvmAnnotationReference toAnnotationExtended(@Nullable EObject sourceElement, @Nullable String annotationTypeName,
			Pair<String, String> ...  values) {
		JvmAnnotationReference result = typesFactory.createJvmAnnotationReference();
		JvmType jvmType = references.findDeclaredType(annotationTypeName, sourceElement);
		if (jvmType == null) {
			throw new IllegalArgumentException("The type "+annotationTypeName +" is not on the classpath.");
		if (!(jvmType instanceof JvmAnnotationType)) {
			throw new IllegalArgumentException("The given class " + annotationTypeName + " is not an annotation type.");
		JvmAnnotationType annotationType = (JvmAnnotationType) jvmType;
		result.setAnnotation(annotationType);
		for (Pair<String, String> value : values) {
			JvmStringAnnotationValue annotationValue = typesFactory.createJvmStringAnnotationValue();
			annotationValue.getValues().add(value.getValue());
			JvmOperation operation = getJvmOperation(annotationType, value.getKey());
			if (operation != null) {
				annotationValue.setOperation(operation);
			result.getValues().add(annotationValue);
		return result;
	private JvmOperation getJvmOperation(JvmAnnotationType type, String name) {
		for (JvmOperation op : type.getDeclaredOperations()) {
			if (op.getSimpleName().equals(name)) {
				return op;
		return null;
Re: How to infer an annotation with a key-value pair [message #1827858 is a reply to message #1081053] Mon, 25 May 2020 14:10 Go to previous messageGo to next message
I have similar problems generating Annotations out of the Inferrrer.
I found Christians solution, but I get back an instance of the class
JvmAnnotationReferenceImplCustom
as result in
which returns an unmodifiable List
	public EList<JvmAnnotationValue> getValues() {
		EList<JvmAnnotationValue> explicitValues = getExplicitValues();
		List<JvmOperation> operations = Lists.newArrayList(getAnnotation().getDeclaredOperations());
		if (operations.size() <= explicitValues.size()) {
			return ECollections.unmodifiableEList(explicitValues);
		Set<JvmOperation> seenOperations = Sets.newHashSetWithExpectedSize(operations.size());
		BasicEList<JvmAnnotationValue> result = new BasicEList<JvmAnnotationValue>(operations.size());
		for(JvmAnnotationValue value: explicitValues) {
			seenOperations.add(value.getOperation());
			result.add(value);
		for(JvmOperation operation: operations) {
			if (seenOperations.add(operation)) {
				JvmAnnotationValue defaultValue = operation.getDefaultValue();
				if (defaultValue != null) {
					result.add(defaultValue);
		return ECollections.unmodifiableEList(result);
The only possible values to set are those collected for all operations without default value, but I also need to set those with a default value to an other value. How can I set all possible Enumeration operations?
Additionally I want to set a String value using a String constant instead of the String-Literal itself. Other Annotation values are Enumeration literals; here a small example what I mean:
public enum MyColors {
   red,
   green,
   blue;
public interface MyFeatures {
   public static final String MY_COLOR_FEATURE = "myColorFeature";
public class Something {
   @MyAnnotation(feature=Test.MY_COLOR_FEATURE, color=MyColors.green)
   public void someMethod() {}
I have an already inferred JvmField for the String constant and a JvmTypeReference to the already existing Enumeration. Can you show me how to infer an Annotation as shown in the Example?
Tom
Re: How to infer an annotation with a key-value pair [message #1827868 is a reply to message #1827858] Tue, 26 May 2020 01:35 Go to previous messageGo to next message
I am not sure if this is possible https://www.eclipse.org/forums/index.php/t/1085224/
https://bugs.eclipse.org/bugs/show_bug.cgi?id=460798
Maybe you can find a sample somewhere
Or find a solution by reading the code
[Updated on: Tue, 26 May 2020 01:35] by Moderator
Re: How to infer an annotation with a key-value pair [message #1827889 is a reply to message #1827868] Tue, 26 May 2020 08:14 Go to previous messageGo to next message
Hello Christian,
Thank you for your answer, I checked the Links, they refer to similar Problems but I did not found a solution for me.
Do you know what was the reason the (new) getValues() Method return only those Enumeration values with no default?
I looks like the whole concept has changed since you posted your solution...
Thank you,
Tom
Re: How to infer an annotation with a key-value pair [message #1827913 is a reply to message #1827889] Tue, 26 May 2020 15:03 Go to previous messageGo to next message
i dont get this question about the default. please elaborate
Re: How to infer an annotation with a key-value pair [message #1827960 is a reply to message #1827913] Wed, 27 May 2020 12:45 Go to previous messageGo to next message
Hello Christian,
You can see what I mean with "default" in the following snippet out of the Xtext original method
JvmAnnotationReferenceImplCustom>>getValues()
Only the operations with no defaults defined in the Annotation will be in the (unmodifiable!) result list, so it is neither possible to set an alternate value to a JvmAnnotationValue witch has an default defined because it is not in the list, nor you can add a JvmAnnotationValue because of the "Unmodifiable".
Is there an other way to set annotation values (especially those who have an default)?
Regards, Tom
Re: How to infer an annotation with a key-value pair [message #1827964 is a reply to message #1827960] Wed, 27 May 2020 14:53 Go to previous message
are you talking about "special type values" or simply ones like string, int.
or some that call to stuff like yours above https://www.eclipse.org/forums/index.php?t=msg&th=1067387&goto=1698455&#msg_1698455
Previous Topic:Parsing XML
Next Topic:[solved] Indentation of elements in EList using formatting2 API
Current Time: Sun Jul 20 09:12:24 EDT 2025
Powered by FUDForum. Page generated in 0.25315 seconds
