Home » Archived » Jubula » Problem with toolkit example for rcp
Problem with toolkit example for rcp [message #1043354] Wed, 17 April 2013 11:42 Go to next message
I would like to test an RCP application and I need to create some toolkit. So, I tried to make a toolkit with the example for RCP integrated in Jubula. I followed the steps in the "extending Jubula" document and now Jubula highlight the component (SWT Group). But when I want to check the property of this component, my check failed and I have a "Configuration error".
So, I would like to know what does it mean by "configuration error" and how I can fix this problem ?
I hope you can help me.
Re: Problem with toolkit example for rcp [message #1044662 is a reply to message #1043354] Fri, 19 April 2013 03:18 Go to previous messageGo to next message
An important question before anyone can help is - which version are you using? There have been changes from 1.3 to 2.0.
For more links on extensions in 1.3, look here. For a thread that contained information on 2.0, look here.
HTH,
Alex
Re: Problem with toolkit example for rcp [message #1044872 is a reply to message #1043354] Fri, 19 April 2013 08:48 Go to previous messageGo to next message
I'm using the version 2.0.
But after some try I find the problem. Actually, the fragment ( in the example for extending RCP) has the host plugin org.eclipse.jubula.rc.swt but like it's for an RCP application the host plugin must be org.eclipse.jubula.rc.rcp.swt. After the deployment, I have no problem to test the new composant.
Thanks for your answer,
Best regards
Re: Problem with toolkit example for rcp [message #1046670 is a reply to message #1044872] Mon, 22 April 2013 04:01 Go to previous messageGo to next message
Great to hear - and thanks for posting the solution Smile
Re: Problem with toolkit example for rcp [message #1062935 is a reply to message #1043354] Tue, 11 June 2013 09:09 Go to previous message
Hi guys,
Do you have some tricks to make that RCP sample working?
I failed even to see the new component (SWT) Group when adding test step after preparing plugin acccoding to the steps from manual.
Alex.
Previous Topic:How to select which records of a data set to use
Next Topic:Autrun and RCP application
Current Time: Sat Jul 19 12:28:06 EDT 2025
Powered by FUDForum. Page generated in 0.04018 seconds
