Home » Archived » XML Schema Definition (XSD) » Problems with complexType(Problems with complexType)
Problems with complexType [message #1062668] Mon, 10 June 2013 06:14 Go to next message
I am working on a project that extends the org.eclipse.xsd module. There seem to be two problems regarding the handling of complexType.
1. The attributes of the complexContent element are lost when loading an xsd schema into the ecore model, and then deriving the xsd from the model again.
For example, when running XSDMainExample::loadAndPrint (in org.eclipse.xsd.example) for the xsd file example 1 (is attached), then the attributes of the complexContent element are lost. It looks like the attributes are not loaded into the model.
2. The complexContent element and restriction element are lost when the attribute base of the contained restriction element has value 'anyType'. See example 2.
Are these bugs or features? Should I enter a bugzilla, or is there a workaround?
Kind Regards,
Arjan Kok.
  • Attachment: example1.xsd
    (Size: 0.84KB, Downloaded 331 times)
  • Attachment: example2.xsd
    (Size: 0.81KB, Downloaded 358 times)
Re: Problems with complexType [message #1062673 is a reply to message #1062668] Mon, 10 June 2013 06:37 Go to previous messageGo to next message
Arjan,
Comments below.
On 10/06/2013 12:14 PM, Arjan Kok wrote:
For me that prints out
<schema xmlns="http://www.w3.org/2001/XMLSchema"
xmlns:link="http://www.xbrl.org/2003/linkbase"
xmlns:xl="http://www.xbrl.org/2003/XLink">
<import namespace="http://www.xbrl.org/2003/XLink"
schemaLocation="http://www.xbrl.org/2003/xl-2003-12-31.xsd"/>
<import namespace="http://www.xbrl.org/2003/linkbase"
schemaLocation="http://www.xbrl.org/2003/xbrl-linkbase-2003-12-31.xsd"/>
<element name="reference" substitutionGroup="xl:resource">
<complexType mixed="true">
<complexContent>
<extension base="xl:resourceType">
<sequence>
<element maxOccurs="unbounded" minOccurs="0" ref="link:part"/>
</sequence>
</extension>
</complexContent>
</complexType>
</element>
</schema>
So you're specifically referring to the id attribute? I've not looked
closely, but the DOM itself should preserve that. They're not recorded
in the model. Are you discarding the DOM and regenerating it?
The same issue here. What's serialized is semantically equivalent to
what's read in, so if you discard the DOM, you should expect this type
of thing.
Are you discarding the DOM?
> Kind Regards,
> Arjan Kok.
Re: Problems with complexType [message #1062687 is a reply to message #1062673] Mon, 10 June 2013 07:43 Go to previous messageGo to next message
Hi Ed,
1) The complexContent element misses the attribute mixed = "true". Yes, I am discarding the DOM and regenerating the DOM from the model (that is what XSDMainExample::loadAndPrint does).
2) Yes, I am discarding the DOM. If the results are semantically equivalent then I am OK with it.
The goal is to work on the model level. Discarding the DOM reassures me that I don't miss information in the model.
Arjan.
[Updated on: Mon, 10 June 2013 07:47] by Moderator
Re: Problems with complexType [message #1062697 is a reply to message #1062687] Mon, 10 June 2013 08:12 Go to previous messageGo to next message
Arjan,
Comments below.
On 10/06/2013 1:43 PM, Arjan Kok wrote:
> Hi Ed,
That's redundant with respect to the mixed on the complex type itself
and is recorded only once in the semantic model and never serialized out
redundantly.
Yes as a demonstration of what's in the semantic model.
Yes that's supported. It incrementally updates the DOM.
> model.
It does the opposite. It discards information not in the semantic
model, e.g., redundancies as well as things not in the semantic model as
documented in the XML Schema specification, such as non-schema namespace
attributes.
> Arjan.
Re: Problems with complexType [message #1062703 is a reply to message #1062697] Mon, 10 June 2013 08:30 Go to previous messageGo to next message
Hi Ed,
I understand your point regarding discarding redundancies. Thanks.
I changed the example (uploaded example 3), the complexContent element has now attribute mixed="false".
It is still missing in the output. The input DOM and output DOM are now not semantically equivalent, right?
PS Are there plans to support XML Schema 1.1?
Arjan.
  • Attachment: example3.xsd
    (Size: 0.84KB, Downloaded 329 times)
Re: Problems with complexType [message #1062801 is a reply to message #1062703] Mon, 10 June 2013 15:23 Go to previous messageGo to next message
Arjan,
Comments below.
On 10/06/2013 2:30 PM, Arjan Kok wrote:
> Hi Ed,
That sounds like a loop hole in the XML Schema specification. It has no
constraints about the redundant attributes being consistent.
I think it's not well specified.
No, without funding there are no plans.
> Arjan.
Re: Problems with complexType [message #1062934 is a reply to message #1062801] Tue, 11 June 2013 09:08 Go to previous message
Thank you very much.
Kind Regards,
Arjan.
Previous Topic:Eclipse wsdl validator doesn't show exact error
Next Topic:Extending xsd.edit
Current Time: Sun Jul 20 15:20:46 EDT 2025
Powered by FUDForum. Page generated in 0.03962 seconds
