Home » Modeling » XSD » Problems with complexType?(Problems with complexType?)
Problems with complexType? [message #1062453] Fri, 07 June 2013 15:54
I am working on a project that extends the org.eclipse.xsd module. There seem to be two problems regarding the handling of complexType.
1. The attributes of the complexContent element are lost when loading an xsd schema into the ecore model, and then deriving the xsd from the model again.
For example, when running XSDMainExample::loadAndPrint (in org.eclipse.xsd.example) for the xsd file example 1 (is attached), then the attributes of the complexContent element are lost.
2. The complexContent element and restriction element are (sometimes) lost. Probably because attribute value 'anyType' of the attribute base of the restriction element. See example 2.
Are these bugs? Should I enter a bugzilla, or is there a workaround?
Kind Regards,
Arjan Kok.
  • Attachment: example1.xsd
    (Size: 0.84KB, Downloaded 390 times)
  • Attachment: example2.xsd
    (Size: 0.81KB, Downloaded 375 times)
Previous Topic:No resource type specified (at 'xpath' with value '@id')
Next Topic:Conditional in schema
Current Time: Sun Jul 20 14:23:29 EDT 2025
Powered by FUDForum. Page generated in 0.05047 seconds
