Home » Modeling » GMF (Graphical Modeling Framework) » Need help to remove Undo/Redo actions from popup menu
Need help to remove Undo/Redo actions from popup menu [message #1062180] Thu, 06 June 2013 08:03
I would like to remove the Undo and the Redo actions from the Popup menu.
These actions are declared in the plugin.xml from org.clipse.gmf.runtime.diagram.ui.providers.
I tried to remove them using the GMF extension point, but it doesn't work.
(I already used this method for others actions and it worked fine)
any ideas?
my declaration in my plugin.xml
<extension
      point="org.eclipse.gmf.runtime.common.ui.services.action.contributionItemProviders">
   <contributionItemProvider
         checkPluginLoaded="false"
         class="org.eclipse.gmf.runtime.diagram.ui.providers.DiagramContributionItemProvider">
      <Priority
            name="High">
      </Priority>
      <popupContribution>
         <popupPredefinedItem
               id="undo"
               path="/editMenu/undoGroup"
               remove="true">
         </popupPredefinedItem>
               id="redo"
               remove="true">
      </popupContribution>
   </contributionItemProvider>
</extension>
Previous Topic:Multipage Editor: Page for certain nodes
Next Topic:2 Label for node on Diagram
Current Time: Sun Jul 20 17:02:37 EDT 2025
Powered by FUDForum. Page generated in 0.03642 seconds
