Using helper as attribute/variable brings exception [message #1062004] |
Wed, 05 June 2013 07:23  |
I've got a problem with a helper, the code is as follows:
helper def : transformedIRealizations : Sequence(UML2!InterfaceRealization) = UML2!InterfaceRealization.allInstancesFrom('IN')->debug('First step: ')->select(e|e.owner.isStereotyped())->debug('Second step:');
And when I run the transformation I get the following output, including an exception:
First step: : OrderedSet {IN!<unnamed>, IN!<unnamed>,..., IN!<unnamed>}
org.eclipse.m2m.atl.engine.emfvm.VMException: 1
at main#33(UMLCopy.atl)
local variables:
Java Stack:
at org.eclipse.m2m.atl.engine.emfvm.ASMOperation.exec(ASMOperation.java:643)
at org.eclipse.m2m.atl.engine.emfvm.ASM.run(ASM.java:208)
at org.eclipse.m2m.atl.engine.emfvm.launch.EMFVMLauncher.internalLaunch(EMFVMLauncher.java:170)
at org.eclipse.m2m.atl.engine.emfvm.launch.EMFVMUILauncher.launch(EMFVMUILauncher.java:46)
at org.eclipse.m2m.atl.core.service.LauncherService.launch(LauncherService.java:136)
at org.eclipse.m2m.atl.core.ui.launch.AtlLaunchConfigurationDelegate.launchOrDebug(AtlLaunchConfigurationDelegate.java:300)
at org.eclipse.m2m.atl.core.ui.launch.AtlLaunchConfigurationDelegate.launch(AtlLaunchConfigurationDelegate.java:237)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:854)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:703)
at org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(DebugUIPlugin.java:937)
at org.eclipse.debug.internal.ui.DebugUIPlugin$8.run(DebugUIPlugin.java:1141)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Caused by: java.lang.ArrayIndexOutOfBoundsException: 1
at org.eclipse.m2m.atl.engine.emfvm.ASMOperation.exec(ASMOperation.java:456)
... 11 more
So as you can see, using the debugging function only the first step is shown, while the second step I assume is the one causing the exception.
I tried executing this code outside of this helper and it works just fine, but I wanted to include this in this helper so that I wouldn't have to run the same thing a thousand times, since my transformation was taking too long to run, and now if I do it like this it just doesnt work.
I'll add some more related code here in case it might help, let me know if there's something else you might need to know:
The header of the file:
-- @nsURI UML2=http://www.eclipse.org/uml2/3.0.0/UML
-- @nsURI XML=http://www.eclipse.org/MoDisco/Xml/0.1.incubation/XML
-- @nsURI profile=http://www.eclipse.org/uml2/3.0.0/UML
module SuperimposedStereotyping;
create OUT: UML2 from IN: UML2, Plugin: XML, Profile: profile;
helper context UML2!Class def: isStereotyped(): Boolean =
self.isInPlugin('view') or self.isInPlugin('perspective') or self.isInPlugin('actionTool') or self.isInPlugin('modalTool');
helper context UML2!Class def: isInPlugin(name: String): Boolean =
(XML!Attribute.allInstancesFrom('Plugin') -> select(e | e.value.endsWith(self.name)
and e.parent.name = name).notEmpty());
Also note that this is a superimposed module that gets called from the main module (UMLCopy.atl)
So what could be the cause?
Thanks in advance,
regards,
Javier
[Updated on: Wed, 05 June 2013 07:56] by Moderator
FUDForum. Page generated in 0.04190 seconds
