Using a File located in workspace during Validation process [message #1060591] |
Mon, 27 May 2013 04:17  |
Hello
I have a little question I couldn't solve so far.
I'm using ETL and EVL to perform a transformation on my generated model from Xtext. I use them as standalone through a call in the validation process from the embedded Eclipse workspace.
In order to work, both ETL and EVL needs to be provided a "File" instance of a file located on a folder of the "Xtext Eclipse".
I use the "platform:" URI code to access file from the embedded Eclipse workspace.
How can I create a File instance of a file in my xtext.base folder, without having to provide the full path to the file ?
I know the issue might sound Epsilon-related rather then Xtext-related, but the problem is just about loading a file, from Xtext validation process, so I thought here would be a better place to get some help.
Thanks for your help.
Best reguards,
Christophe
[Updated on: Mon, 27 May 2013 04:23] by Moderator
Re: Using a File located in workspace during Valisation process [message #1061678 is a reply to message #1060591] |
Mon, 03 June 2013 09:13   |
Christophe,
I think the problem is it's a confusing questions. More comments below.
On 27/05/2013 10:17 AM, Christophe g wrote:
> Hello
Standalone alone is often interpreted to mean, "not running as an
Eclipse application", so not sure what you mean here...
Like java.io.File rather than an IFile?
> Eclipse workspace.
So you mean platform:/resource? Does this answer help?
http://wiki.eclipse.org/EMF-FAQ#How_do_I_map_between_an_EMF_Resource_and_an_Eclipse_IFile.3F
What exactly do you have? The path in the workspace? So is your
question how to get a file: URI from an IFile?
> get some help.
Is the file actually in the workspace? Don't you know it's path in the
workspace?
> Best reguards,
> Christophe
Re: Using a File located in workspace during Valisation process [message #1061692 is a reply to message #1061678] |
Mon, 03 June 2013 09:59   |
Thanks for your answer. I'll try to explain again my situation :
I'm using two different Eclipse plugins : Xtext and Epsilon. I use the "ETL" part of Epsilon to perform a transformation from two different meta models. I use the Epsilon plugin as a standalone, meaning that I call it from some java code in the Xtext plugin, in the validation process.
So I have a "regular" Xtext plugin, which create a second Eclipse specific to my language when I launch it, and the Epsilon part of it is called inside as standalone.
The ETL transformation uses 3 things as input :
_ my current model, it's the Eobject representation of the the current file in my own language.
_ a target model
_ a file, written in the Epsilon Transformation Language.
My problem is with this file.
It must be loaded as an "java.io.File". The file itself is located in a package I added in the "xtext.base" folder. I know both it's relative path and absolute path.
I use "platform:/resource" to access the file corresponding to my models, so in the workspace corresponding to my own language.
From the link in your answer, I assume that I should be able my transformation file through using an "platform:/base". Unfortunately I can't try right now, I'll let you know if it works or not.
I hope things are at least more clear.
Thanks again for your help.
Christophe
[Updated on: Mon, 03 June 2013 10:03] by Moderator
Re: Using a File located in workspace during Valisation process [message #1061954 is a reply to message #1061692] |
Wed, 05 June 2013 02:38   |
Christophe,
Comments below.
> "ETL" part of Epsilon to perform a transformation form two different
> meta model. I use the Epsilon plugin as a standalone, meaning that I
> process.
So best not call that stand alone...
So you're simply using Epsilon as part of your Eclipse application
that's primarily focused around Xtext...
> The ETL transformation uses 3 things as input : _ my current model,
> language. _ a target model
So literally their API requires java.io.File? Most EMF-based
technologies support URIs which are more general than file paths...
> My problem is with this file. It must be loaded as an "java.io.File".
IFile has getLocation and getLocationURI that you can use to get the
physical location (it's possible for it not to even be in a file in the
file system, but it typically is).
> Christophe
FUDForum. Page generated in 0.04003 seconds
