Home » Eclipse Projects » Equinox » Is this official API - IExtensionRegistry#addListener(IRegistryEventListener)?
Is this official API - IExtensionRegistry#addListener(IRegistryEventListener)? [message #105977] |
Fri, 07 March 2008 17:23  |
Originally posted by: mark_melvin.amis.com
Hello All,
I am currently using the newer
IExtensionRegistry#addListener(IRegistryEventListener) family of methods,
and I plan to mention them in my EclipseCON talk on extension points.
However, there is a comment in the Javadoc (I am running on 3.4M5) that
says:
* <b>Note:</b> This is a preliminary form of a new API that might change
or be removed
* altogether prior to 3.4 release. It is being made available at this
early stage to solicit
* feedback from early adopters.
Do you plan on keeping this as official API? If so I will encourage its
use. Otherwise perhaps I should not mention it?
Mark.
Using ExtensionTracker [was Re: Is this official API - IExtensionRegistry#addListener(IRegistryEvent [message #106166 is a reply to message #106097] |
Tue, 11 March 2008 12:15   |
OK, I have done some more digging and found that this API is only slightly
used compared to tracking extensions using
org.eclipse.core.runtime.dynamichelpers.ExtensionTracker. I think I am
just going to port my example to use ExtensionTracker instead of listening
to the extension registry directly.
Does anyone have any recommendations one way or the other?
Mark.
On Mon, 10 Mar 2008 22:39:56 -0400, Mark Melvin <mark_melvin@amis.com>
wrote:
> Anyone?
> M.
> On Fri, 07 Mar 2008 17:23:43 -0500, Mark Melvin <mark_melvin@amis.com>
> wrote:
>> Hello All,
>> methods, and I plan to mention them in my EclipseCON talk on extension
>> points. However, there is a comment in the Javadoc (I am running on
>> 3.4M5) that says:
>> change or be removed
>> its use. Otherwise perhaps I should not mention it?
>> Thanks,
>> Mark.
Re: Using ExtensionTracker [was Re: Is this official API - IExtensionRegistry#addListener(IRegistryE [message #106250 is a reply to message #106166] |
Wed, 12 March 2008 15:47   |
Hi Mark,
Yes, this is the "official" :-) API. That is the usual disclaimer in case a
new API needs to be changed between an introduction and an API freeze. In
fact, it is time to remove it, thanks for the reminder.
In terms of what to use - it depends on what's more convenient for you.
Generally speaking, the new listener was added to help with the same
scenario as the ExtensionTracker class: keeping a local cache in sync with
the registry. The new listener should result in a simpler code for new
implementations, but if you have code that uses ExtensionTracker and
comfortable with it, there is really no need to switch.
Hope this helps.
Thanks you,
Oleg Besedin
"Mark Melvin" <mark_melvin@amis.com> wrote in message
news:op.t7u0r0dpy7f1g1@n-mmelvin.pc.amis.com...
> Mark.
> wrote:
>> Anyone?
>> M.
>> wrote:
>>> Hello All,
>>> 3.4M5) that says:
>>> Thanks,
>>> Mark.
Re: Using ExtensionTracker [was Re: Is this official API - IExtensionRegistry#addListener(IRegistryE [message #106320 is a reply to message #106250] |
Thu, 13 March 2008 12:00  |
Hi Oleg,
Thank you very much for the reply! It's good to know. :-)
Mark.
On Wed, 12 Mar 2008 15:47:21 -0400, Oleg Besedin <obesedin@ca.ibm.com>
wrote:
> Hi Mark,
> case a
> with
> Hope this helps.
> Thanks you,
> Oleg Besedin
>> slightly
>> listening
>> Mark.
>> wrote:
>>> Anyone?
>>> M.
>>> wrote:
>>>> Hello All,
>>>> 3.4M5) that says:
>>>> Thanks,
>>>> Mark.
Current Time: Sat Jul 19 17:09:38 EDT 2025
Powered by FUDForum. Page generated in 0.03732 seconds
