Home » Archived » Jubula » Jubula 2.0(Fail to start)
Jubula 2.0 [message #1061392] Fri, 31 May 2013 08:40 Go to next message
I have installed Jubula 2.0.00148 in Ubuntu 12.04 in the default directory (/opt/jubula_2.0.00148) and it doesn't start.
I got the following message in the console:
joaquin@hikueru:~$ /opt/jubula_2.0.00148/jubula/jubula
Error opening zip file or JAR manifest missing : ../support/chronon/recorder-3.2.0.129.jar
Error occurred during initialization of VM
agent library failed to init: instrument
and
https://lh3.googleusercontent.com/-NmB-pnHkv-s/UaiYZSHrS0I/AAAAAAAAAOo/2M7xBQvL9QE/w369-h577-no/install11.png
But I move to the directory where Jubula is installed, the application would be executed without any problem:
joaquin@hikueru:~$ cd  /opt/jubula_2.0.00148/jubula
joaquin@hikueru:~$ ./jubula
I have reviewed the installation guide and the release notes but I cannot find where is the problem. Thank you.
Joaquin Morcate
[Updated on: Fri, 31 May 2013 08:42] by Moderator
Re: Jubula 2.0 [message #1061401 is a reply to message #1061392] Fri, 31 May 2013 09:19 Go to previous messageGo to next message
This is a known problem under Linux and will be fixed with the next release (Kepler on June 26th).
You actually found the workaround yourself. You may wrap this with a shell script and live happily ever after. Wink
- Achim
Re: Jubula 2.0 [message #1061440 is a reply to message #1061401] Fri, 31 May 2013 11:53 Go to previous message
Thank you very much!
Joaquin
Previous Topic:Tables HTML Toolkit
Next Topic:Log user message or errors in jubula
Current Time: Sat Jul 19 11:42:36 EDT 2025
Powered by FUDForum. Page generated in 0.03525 seconds
