my parameter problem [message #1059951] |
Wed, 22 May 2013 06:30  |
my requirement is:
1) geography-------->separate listbox
2) country------------separate cascading parameter
city
...etc
3)to drop table like i)mrp
ii)buy
iii)etc....
4)and then i want to select year,quarter,month
5)which type likewise i want to select value-wise like 1,2,3 or percentage-wise
kindly add payment date in this report............for year,quarter,month
my question is when i select in geography value and then i have to drop a table,and then i want to select a year,quarter,month,percentage-wise or value-wise
and then again i will select from cascading paramter and then i have to drop a table,and then i want to select a year,quarter,month,percentage-wise or value-wise
and then when i select year it automatically change the quarter,month for particular year.....like wise...
i have run both by separate it run ......good
when i combine in same report it cant be run....so it possible to exceute in same report
i have attached a report ...here
can u modify a report and send to me
kindly help me.....its urgent
thank u .....
Attachment: A.rptdesign
(Size: 124.76KB, Downloaded 285 times)
[Updated on: Wed, 22 May 2013 06:48] by Moderator
Re: my parameter problem [message #1060188 is a reply to message #1060089] |
Thu, 23 May 2013 08:41   |
thank for reply ....
you are understood correctly.......wt i want...but my probelm...
i)first i select geography it want to change chart's x-axis category to match that field is work fine then i have to drop a table work fine,and then i want to select a year,quarter,month,percentage-wise or value-wise--am not getting this- paramter selection------>this is separate way to run the report
ii)at that same time again i will select country and city parameter, query have to change the data by parameter then again i have to drop same table for this parameter too,and then i want to select a year,quarter,month,percentage-wise or value-wise am not getting this- paramter selection for this report
if u look at this report u will get only selection of country and city parameter only passing paramter not for a geography selection so check it well and give solution for this report
kindly can u able to create sampledb with my requirement with
year,quarter,month,types
thanks in advance
Attachment: report
(Size: 126.48KB, Downloaded 370 times)
Re: my parameter problem [message #1061047 is a reply to message #1060646] |
Wed, 29 May 2013 12:28  |
To avoid something like this, you'd just need to check if the series was null before trying to check the series identifier. If it was, you'd stop doing any script and then could show a text in your report letting you know that the data was null. Hope this helps.
FUDForum. Page generated in 0.05539 seconds
