Home » Eclipse Projects » Remote Application Platform (RAP) » Eclipse4 applications on RAP(Problems running the example on https://github.com/eclipsesource/rap-e4)
Eclipse4 applications on RAP [message #1060374] Fri, 24 May 2013 06:57 Go to next message
Hy there,
could anyone please help me to get the example on https://github.com/eclipsesource/rap-e4 running, showcasing the usage of E4 on RAP?
I am currently facing two problems:
The target is not correct; I could remediate this by updating it. But in the code the class org.eclipse.e4.ui.workbench.rap.E4EntryPointFactory is referenced. And even google does not show me a location on where to get this Sad
Marco
Re: Eclipse4 applications on RAP [message #1060436 is a reply to message #1060374] Fri, 24 May 2013 11:53 Go to previous messageGo to next message
Hi Marco,
This is an experimental repository, it's not ready for production. You
can read more about this experiment in this blog post [1].
The class E4EntryPointFactory is contained in a fork of the platform.ui
repository [2].
Ralf
[1] http://eclipsesource.com/blogs/2012/07/16/eclipse-4-applications-on-rap/
[2] https://github.com/eclipsesource/eclipse.platform.ui
Ralf Sternberg
Twitter: @EclipseRAP
Re: Eclipse4 applications on RAP [message #1060460 is a reply to message #1060436] Fri, 24 May 2013 15:38 Go to previous messageGo to next message
Hy Ralf, thanks again for your answer! As mentioned in the issue on github I can't get the example running. I have been attentative to the repository by your blog [1] entry in first place!
I am not considering it for production use, but for learning about the curren state of Eclipse 4 - RAP integration. Could you give me a few hints on what would have to be done to adapt it to the current state of development and get the example running again? I tried the following steps (as described in the issue):
  1. Imported your branch
  2. Set the baseline error to warning
  3. Loaded the target, did an update (as the target is not working) and fixed the references to RAP 2.0 (click on edit, select the feature)
  4. Modified some Classes and methods for example switch from IEntryPoint to EntryPoint
Now, however, I do not find the bundle org.eclipse.e4.services.util, while the code seems to compile.
Re: Eclipse4 applications on RAP [message #1060870 is a reply to message #1060460] Tue, 28 May 2013 14:50 Go to previous messageGo to next message
Hi Marco,
that was some time ago, I don't recall all the details. But I still have
this workspace, if this helps.
There's no such bundle in my workspace, why is it needed?
Regards, Ralf
Ralf Sternberg
Re: Eclipse4 applications on RAP [message #1062950 is a reply to message #1060870] Tue, 11 June 2013 10:10 Go to previous message
I found a more current treat on this topic in http://www.eclipse.org/forums/index.php/t/488439/ ! Thanks Ralf!
Previous Topic:RAP in standalone OSGi javax.servlet import constraint
Next Topic:What is the proper way to determine initial jface dialog size?
Current Time: Sat Jul 19 19:51:06 EDT 2025
Powered by FUDForum. Page generated in 0.04107 seconds
