Home » Modeling » Graphiti » How to keep active the model outline
How to keep active the model outline [message #1060371] Fri, 24 May 2013 06:35 Go to next message
I am have a problem similar to this previous post
http://www.eclipse.org/forums/index.php/t/481691/
I do have an already existing XText grammr to which corresponds an ECORE meta-model and I am developing a Graphiti editor for it. Now I'd like to drag and drop elements from a model, instance of this meta-model, to the Graphiti editor. The problem is that I'd like the XText outline to be active at the same time of the Graphiti editor. What instead happens is that the when I select the Graphiti editor I get an empty outline.
Re: How to keep active the model outline [message #1060580 is a reply to message #1060371] Mon, 27 May 2013 03:20 Go to previous messageGo to next message
Any advice would be very welcome
Re: How to keep active the model outline [message #1060767 is a reply to message #1060580] Tue, 28 May 2013 07:48 Go to previous messageGo to next message
Andrea,
the examples.common plugin implements an exemplary outline. See packages
org.eclipse.graphiti.examples.common.outline and
org.eclipse.graphiti.examples.common.outline.tree.
This should give you an idea how to activate the outline page you want to
see.
Michael
Re: How to keep active the model outline [message #1062700 is a reply to message #1060767] Mon, 10 June 2013 08:24 Go to previous messageGo to next message
Hi Michael,
I have the jar files in my plugins folder but I can't see how to use the examples Sad
Re: How to keep active the model outline [message #1064068 is a reply to message #1062700] Mon, 17 June 2013 09:32 Go to previous message
Andrea,
you can import that plugin using the "import plug-ins and fragments wizard"
under File --> Import. There you can also choose to add the sources (source
plugins are also provided by Graphiti SDK).
Michael
Previous Topic:Diagram Validation Decoration
Next Topic:decorating visual representation of business objects with icons provided from outside of the editor
Current Time: Sat Jul 19 06:50:31 EDT 2025
Powered by FUDForum. Page generated in 0.04208 seconds
