Home » Eclipse Projects » Vex » Reopening a dialog with Vex(Reopen a dialog that has Vex, or cloning Document)
Reopening a dialog with Vex [message #1060422] Fri, 24 May 2013 10:59 Go to next message
Hi Florian.
I wonder if by any chance you can help me with this issue:
I am doing something pretty similar to your example in the German magazine.
The difference is - I need to re-open the dialog with text submitted to it previously, so an example workflow would be:
* Open dialog, write TEXT, click BOLD button, click OK
-- (when dialog closes, store dialog.getDocument() )
* Open dialog (I'm sending to it the previously saved Document). It has TEXT in BOLD and allows me to add more text.
This works fine, but I keep getting an error message saying that VexWidget is disposed. (This could be happening since the dialog.getDocument doesn't exist anymore. If I re-open the dialog with a new Document, there is no error message, but obviously it doesn't have the content which I submitted in previous entries. )
I think if there was a way to clone Document, so that when reopening the dialog, I'll send to it a new Document with values from previous openings, this will solve the problem, but Document does not provide such access.
Any feedback would be appreciated!
Thanking you.
Shay
Re: Reopening a dialog with Vex [message #1060750 is a reply to message #1060422] Tue, 28 May 2013 06:59 Go to previous messageGo to next message
Solved. Had to re-create the document with DocumentReader.
cheers.
S
Re: Reopening a dialog with Vex [message #1063024 is a reply to message #1060750] Tue, 11 June 2013 16:09 Go to previous message
Sorry, I'm a bit busy at my day job at the moment, hence I didn't see your post earlier.
If you have any suggestions regarding the API, we are eager to know about it. Feel free to create bugs in https://bugs.eclipse.org/bugs.
Previous Topic:Implementing undo/copy/cut in Vex Dialog
Next Topic:Why is Editor Read-Only?
Current Time: Sun Jul 20 03:36:56 EDT 2025
Powered by FUDForum. Page generated in 0.03463 seconds
