Asynchronuously write into workspace file [message #1059989] |
Wed, 22 May 2013 09:06  |
i'm (more than a little bit) confused about how to correctly write content into a file in the workspace using background processes.
At first, i used a simple thread which called IResource#setContent (and the like), however, that seemed to block the workspace and come with all sorts of downsizes.
Therefore, i've switched to the WorkspaceJob from the ResourcePlugin.
The content is streamed over the network into an instance of java.io.InputStream and i want to save this content into a specific file (defined by the given URI).
This process can take up to several minutes. Therefore, the write process should run asynchronuously in the background.
Here is my current code:
protected void writeToURI(final URI uri, final InputStream stream) throws IOException
final IFile res = (IFile) WorkspaceTools.getResource(uri); //determine the IFile from the given URI
final int hint = ... //determine correct write hint based on network request and actual resource state
WorkspaceJob writeJob = new WorkspaceJob("Write content to " + uri)
public IStatus runInWorkspace(IProgressMonitor monitor)
try
if (!res.exists())
ensureExists(res.getParent());
switch (hint)
case CREATE:
res.create(stream, true, monitor);
break;
case APPEND:
res.appendContents(stream, true, false, monitor);
break;
case SET_CONTENT:
res.setContents(stream, true, true, monitor);
} catch (CoreException e)
Close.close(stream);
return new Status(IStatus.ERROR, "de.d3fact.server.net.interfaces", "Could not write to file " + uri, e);
return Status.OK_STATUS;
writeJob.setRule(null);
writeJob.schedule();
The problem with this code is, that it, regardless of the ISchedulingRule, it seems to block the workspace.
In my scenario, i'm writing to a simple text file "Test.txt" in a simple folder called "debug" in a java project. The content consists of simple lines of text.
Now, when i try to modify java files in the same project - while i receive data over the network and write it with said code into said file, everything locks up and i have to kill the eclipse instance.
I have tried different ISchedulingRules (the IFile, IResourceRuleFactory#createRule() and IResourceRuleFactory#modifyRule respectively and currently i'm using null to have maximum concurrency).
I'm running eclipse 4.3.0 RC1 on a Mac OSX system.
My last guess is, to use the java.io.file API and when streaming has finished to run an IResource#refreshLocal(). But before i implement that hack, i wanted to ask you how to correctly write content into a file without locking up the workspace.
Re: Asynchronuously write into workspace file [message #1060135 is a reply to message #1060129] |
Thu, 23 May 2013 05:24   |
I have thought this problem over. I think, i know where the problem lies.
The problem is the WorkspaceJob. Lets say, the streaming takes ~10 minutes or so.
Now, according to my code, i create the WorkspaceJob, schedule it and then it blocks the whole workspace for said 10 minutes.
So instead, i will need to
* call the IFile#create, IFile#appendContents, IFile#setContents method from a temporary thread
* and then have a WorkspaceJob (or what ever Job) pumping incoming network data into the inputstream, connected to the file
My uninformed guess is, that this is somewhat akward and there really should be some sort of mechanism for non-blocking file transfer, but i couldn't find any information about that in the eclipse articles or on the web.
Re: Asynchronuously write into workspace file [message #1060241 is a reply to message #1060135] |
Thu, 23 May 2013 12:24  |
For the records: My specific problem is, that the eclipse API does not offer any (good) mechanism to handle long taking file operations.
The suggested workaround from the IRC was:
* Write the incoming data stream into a file in the private area of your plugin.
* When finished write the content, using a WorkspaceJob (or something similar) into the final location in the workspace.
This will prevent problems regarding the locking of the workspace (and the eclipse UI). Another idea would be to write the data in chunks into the file when the data becomes available. However, this will clutter the local history of the file and create an unusual high amount of load due to delta changes.
Advanced idea:
* Create a new filesystem provider (EFS) and with that a virtual file that can be plugged into the workspace to allow the user (while the streaming is running in the background) to mess with the virtual file and to show the user that there is something going on. With the virtual file, the user e.g. can delete the resource and i can, based on this feedback, stop the background streaming.
FUDForum. Page generated in 0.22214 seconds
