Home » Modeling » UML2 » Problems with using the UML.ecore metamodel directly
Problems with using the UML.ecore metamodel directly [message #1059519] Mon, 20 May 2013 04:54 Go to next message
For a prototype of an UML-tool, I'd like to use the UML.ecore file which is part of Eclipse UML2 directly. Therefore, I searched for the org.eclipse.uml2.uml_<version>.jar file and extracted the UML.ecore and its genmodel file. Then I created a new "Empty EMF Project" in Eclipse and imported both files. At this point, everything looks fine, I can browse through the uml-core hierarchy etc. without getting any errors.
But when I try to generate the model code via the imported genmodel, the generation suddenly stops with a bunch of exceptions (see attachment #1).
I also tried to delete the genmodel and create it on my own, based on UML.ecore. This time, the model generation finishes without any problems, but the generated code contains errors (see attachment #2).
How could I fix this? thanks.
Re: Problems with using the UML.ecore metamodel directly [message #1059754 is a reply to message #1059519] Tue, 21 May 2013 10:07 Go to previous messageGo to next message
Arn,
UML.ecore needs to use UML2's extended version of GenModel to generate
properly; I don't think it makes sense to try to regenerate UML2 again.
You should just use what's already generated.
Re: Problems with using the UML.ecore metamodel directly [message #1059777 is a reply to message #1059754] Tue, 21 May 2013 10:40 Go to previous message
As Ed notes, this is a fairly dubious undertaking. But it should work.
Provided:
You use the same Eclipse tool versions as the UML code.
You use all the UML files (from GIT rather than Import Project)
You don't 'improve' the code by adding extra files such as Ecore.ecore.
I suggest that you practice regebnerating the unmodified source before
modifying, and thinking hard about why you want to modify at all.
Ed Willink
On 21/05/2013 15:07, Ed Merks wrote:
> Arn,
> again. You should just use what's already generated.
>> getting any errors.
>> attachment #1).
Previous Topic:How to write Eclipse UML2 XMI
Next Topic:Loading UML-Model with papyrus-profile applied
Current Time: Sat Jul 19 23:23:26 EDT 2025
Powered by FUDForum. Page generated in 0.03593 seconds
