Home » Eclipse Projects » Equinox » Is this official API - IExtensionRegistry#addListener(IRegistryEventListener)?
Is this official API - IExtensionRegistry#addListener(IRegistryEventListener)? [message #105977] Fri, 07 March 2008 17:23 Go to next message
Originally posted by: mark_melvin.amis.com
Hello All,
I am currently using the newer
IExtensionRegistry#addListener(IRegistryEventListener) family of methods,
and I plan to mention them in my EclipseCON talk on extension points.
However, there is a comment in the Javadoc (I am running on 3.4M5) that
says:
* <b>Note:</b> This is a preliminary form of a new API that might change
or be removed
* altogether prior to 3.4 release. It is being made available at this
early stage to solicit
* feedback from early adopters.
Do you plan on keeping this as official API? If so I will encourage its
use. Otherwise perhaps I should not mention it?
Mark.
Re: Is this official API - IExtensionRegistry#addListener(IRegistryEventListener)? [message #106097 is a reply to message #105977] Mon, 10 March 2008 22:39 Go to previous messageGo to next message
Anyone?
M.
On Fri, 07 Mar 2008 17:23:43 -0500, Mark Melvin <mark_melvin@amis.com>
wrote:
> Hello All,
> methods, and I plan to mention them in my EclipseCON talk on extension
> points. However, there is a comment in the Javadoc (I am running on
> 3.4M5) that says:
> change or be removed
> Mark.
Using ExtensionTracker [was Re: Is this official API - IExtensionRegistry#addListener(IRegistryEvent [message #106166 is a reply to message #106097] Tue, 11 March 2008 12:15 Go to previous messageGo to next message
OK, I have done some more digging and found that this API is only slightly
used compared to tracking extensions using
org.eclipse.core.runtime.dynamichelpers.ExtensionTracker. I think I am
just going to port my example to use ExtensionTracker instead of listening
to the extension registry directly.
Does anyone have any recommendations one way or the other?
Mark.
On Mon, 10 Mar 2008 22:39:56 -0400, Mark Melvin <mark_melvin@amis.com>
wrote:
> Anyone?
> M.
> wrote:
>> Hello All,
>> 3.4M5) that says:
>> its use. Otherwise perhaps I should not mention it?
>> Thanks,
>> Mark.
Re: Using ExtensionTracker [was Re: Is this official API - IExtensionRegistry#addListener(IRegistryE [message #106250 is a reply to message #106166] Wed, 12 March 2008 15:47 Go to previous messageGo to next message
Hi Mark,
Yes, this is the "official" :-) API. That is the usual disclaimer in case a
new API needs to be changed between an introduction and an API freeze. In
fact, it is time to remove it, thanks for the reminder.
In terms of what to use - it depends on what's more convenient for you.
Generally speaking, the new listener was added to help with the same
scenario as the ExtensionTracker class: keeping a local cache in sync with
the registry. The new listener should result in a simpler code for new
implementations, but if you have code that uses ExtensionTracker and
comfortable with it, there is really no need to switch.
Hope this helps.
Thanks you,
Oleg Besedin
"Mark Melvin" <mark_melvin@amis.com> wrote in message
news:op.t7u0r0dpy7f1g1@n-mmelvin.pc.amis.com...
> Mark.
> wrote:
>> Anyone?
>> M.
>> wrote:
>>> Hello All,
>>> 3.4M5) that says:
>>> Thanks,
>>> Mark.
Re: Using ExtensionTracker [was Re: Is this official API - IExtensionRegistry#addListener(IRegistryE [message #106320 is a reply to message #106250] Thu, 13 March 2008 12:00 Go to previous message
Hi Oleg,
Thank you very much for the reply! It's good to know. :-)
Mark.
On Wed, 12 Mar 2008 15:47:21 -0400, Oleg Besedin <obesedin@ca.ibm.com>
wrote:
> Hi Mark,
> case a
> with
> Hope this helps.
> Thanks you,
> Oleg Besedin
>> slightly
>> listening
>> Mark.
>> wrote:
>>> Anyone?
>>> M.
>>> wrote:
>>>> Hello All,
>>>> 3.4M5) that says:
>>>> Thanks,
>>>> Mark.
Previous Topic:get bundleInfo/bundleContext for classes within a bundle outside activator
Next Topic:log4j Unexpected Result
Current Time: Sat Jul 19 19:46:55 EDT 2025
Powered by FUDForum. Page generated in 0.24324 seconds
