Home » Modeling » GMF (Graphical Modeling Framework) » Property Selection Filter on Property Section
Property Selection Filter on Property Section [message #1059575] Mon, 20 May 2013 10:40 Go to next message
I have this metamodel;
(i only showing releations)
abstract Field
LookUp extends Field
  contentType -> 1..1 ContentType (referance)
  showField  -> 1..1 Field (reference)
Content Type
     ownedField -> 0..* Field(containment)
here i just want when user select showfield feature from properties section of LookUp Field, GMF must show only its referenced ContentType element Field's. But when i generate GMF it shows all created Field. How can i constraint this ? anyone can help me ?
(Example attached as a picture)
on example LookUp defined and cnn2 ContentType set as its ContentType referance feature. But when i click showField from properties section i must have only 'no' Number Field. But it gives me all fields. But i need only no Number field. How can i do this anyone can help me ?
  • Attachment: LookUp.png
    (Size: 162.24KB, Downloaded 527 times)
[Updated on: Fri, 24 May 2013 04:45] by Moderator
Re: Property Selection Filter on Property Section [message #1060347 is a reply to message #1059575] Fri, 24 May 2013 04:46 Go to previous messageGo to next message
this is done via the .edit code that is generated by emf. Take a look at this http://wiki.eclipse.org/EMF-FAQ#How_can_I_control_which_instances_are_available_as_choices_when_editing_a_property_in_the_properties_view.3F .
Ralph
Re: Property Selection Filter on Property Section [message #1060406 is a reply to message #1060347] Fri, 24 May 2013 09:54 Go to previous messageGo to next message
thanks a lot i fixed my problem via above url.
Re: Property Selection Filter on Property Section [message #1061334 is a reply to message #1060406] Fri, 31 May 2013 05:15 Go to previous messageGo to next message
you could think of overwriting EMF's Jet templates. This saves you some work for the case that you are forced to delete the generated edit code in future.
Ralph
Re: Property Selection Filter on Property Section [message #1061813 is a reply to message #1061334] Tue, 04 June 2013 04:22 Go to previous message
I know better Xpand than jet but i'll try
Previous Topic:Qualified names on referance labels
Next Topic:Acces of node element from outside
Current Time: Sun Jul 20 14:28:03 EDT 2025
Powered by FUDForum. Page generated in 0.04059 seconds
