Home » Modeling » TMF (Xtext) » Setting up URI imports(Needed setup steps for URI imports to work)
Setting up URI imports [message #734490] Fri, 07 October 2011 21:02 Go to next message
I've read a lot about using 'uri imports' but somehow I still cannot make it
work for my toy grammar. I implemented
- the ScopeProvider (for local scope),
- the name provider (a simple name provider-- used during exporting),
- modified the 'language workflow
(e.g., add fragment = scoping.ImportURIScopingFragment {},
remove scoping.ImportNamespacesScopingFragment {}, etc.).
Somehow I'm still missing one step (attached is the complete code).
Here is my grammar:
grammar org.xtext.example.globalScope.FilePrint with org.eclipse.xtext.common.Terminals
import "ALINK_HERE //www.eclipse.org/emf/2002/Ecore" as ecore
generate filePrint "A LINK HERE//www.xtext.org/example/globalScope/FilePrint"
//^^^^ I put 'ALINK HERE' instead of http: so I could post this question
Model:
	(imports+=Import)*
	(images+=Image | prints+=PrintCmd)*
Image:'image' fileName= ID ';' ; //NOTE I don't use 'name' here ..
PrintCmd: 'print' image=[Image | FNQ] ';' ; //Is this correct? saw in some posts ..
FNQ returns ecore::EString : ID;
Import : 'import' importURI=STRING ';' ; // feature must be named importURI
All I want is for the 'PrintCmd' rule to be able to refer to 'Images' defined in other
file. For instance, I created a eclipse project with the following two files. The content of file1.deleteMe (deleteMe is the extension of my DSL):
import "file2.deleteMe";
image anImage ;
print anImage;
print anotherImage; //this gives a 'linking' error
and file2.deleteMe
image anotherImage ;
print anotherImage;
Any suggestions? Thanks.
Re: Setting up URI imports [message #734532 is a reply to message #734490] Sat, 08 October 2011 04:44 Go to previous messageGo to next message
i guess the basic problem is a erroneous implementation of your simple
name provider. in your case a change of the grammar might do the trick
(1) create a new Xtext project with the wizard
(2) change the workflow like
	    // scoping and exporting API
             fragment = exporting.SimpleNamesFragment {}
             // fragment = scoping.ImportNamespacesScopingFragment {}
             // fragment = exporting.QualifiedNamesFragment {}
             fragment = builder.BuilderIntegrationFragment {}
and use a grammar like
Model:
	(imports+=Import)*
Image:'image' fileName= ID ';' ; //NOTE I don't use 'name' here .. =>
you have to change the nameprovider
PrintCmd: 'print' image=[Image | ID] ';' ; // you are using simple names.
since you insist on the fileName stuff you have to use a custom
simplenameprovider
package org.xtext.example.mydsl.naming;
import org.eclipse.emf.ecore.EObject;
import org.eclipse.xtext.naming.QualifiedName;
import org.eclipse.xtext.naming.SimpleNameProvider;
import org.xtext.example.mydsl.myDsl.Image;
public class MyDslSimpleNameProvider extends SimpleNameProvider {
	public QualifiedName getFullyQualifiedName(EObject obj) {
		if (obj instanceof Image) {
			return QualifiedName.create(((Image)obj).getFileName());
		return super.getFullyQualifiedName(obj);
public class MyDslRuntimeModule extends
org.xtext.example.mydsl.AbstractMyDslRuntimeModule {
	public Class<? extends IQualifiedNameProvider>
bindIQualifiedNameProvider() {
		return MyDslSimpleNameProvider.class;
and it will work like a charm
~Christian
Am 08.10.2011 03:02, schrieb Emilio:
> Model:
> (imports+=Import)*
Re: Setting up URI imports [message #734533 is a reply to message #734532] Sat, 08 October 2011 04:57 Go to previous messageGo to next message
please note: you have to change this too:
//fragment = types.TypesGeneratorFragment {}
~Christian
Am 08.10.2011 10:44, schrieb Christian Dietrich:
> Model:
> (imports+=Import)*
> simplenameprovider
> @Override
> ~Christian
>> Model:
>> (imports+=Import)*
>> some posts ..
Re: Setting up URI imports [message #735021 is a reply to message #734533] Mon, 10 October 2011 12:50 Go to previous messageGo to next message
Christian,
Thanks. It worked by just changing my rule grammar from
to
(I already had in place all the other changes you suggested).
Re: Setting up URI imports [message #1059503 is a reply to message #735021] Mon, 20 May 2013 01:06 Go to previous messageGo to next message
Do we need to create a custom simplenameprovider for each "filename"?
If I add another grammar like this:
 Model:
 (imports+=Import)*
 (files+=File)*
 File: 'file' nameOfFile=ID ';' ; // <-- New grammar
Does this mean that I have to create a custom simplenameprovider for nameOfFile also?
How will I know if I should create one or not?
Re: Setting up URI imports [message #1059517 is a reply to message #1059503] Mon, 20 May 2013 04:31 Go to previous messageGo to next message
Yes . The nameproviders by Default use name=ID
Re: Setting up URI imports [message #1059520 is a reply to message #1059517] Mon, 20 May 2013 05:11 Go to previous messageGo to next message
Is a custom simplenameprovider necessary?
May I know what it is for? Sorry, but I cannot find any explanation online on why we need a custom simplenameprovider when using importURI.
Re: Setting up URI imports [message #1059525 is a reply to message #1059520] Mon, 20 May 2013 05:35 Go to previous messageGo to next message
You dont need to but if you compare
ImportedNamespaceAwareLocalScopeProvider
with SimpleLocalScopeProvider
you will see that the latter that is used with import uri scoping
does no relative name resolution so that you always have to use FQNs
Re: Setting up URI imports [message #1059531 is a reply to message #734490] Mon, 20 May 2013 06:19 Go to previous messageGo to next message
Fine, then I have decided not to implement the custom simplenameproviders.
But when I created 2 files..
file1.deleteMe:
image anImage ;
print anImage;
file2.deleteMe:
print anotherImage;
The generated output file only shows the contents of file1.deleteMe. I have made the changes to my workflow based on your suggestion. What other things do I need to change so that contents of file1 is merged with contents of file2?
Re: Setting up URI imports [message #1059532 is a reply to message #1059531] Mon, 20 May 2013 06:25 Go to previous messageGo to next message
Imports just make Things visible. The do NOT have include semantics
Re: Setting up URI imports [message #1059634 is a reply to message #1059532] Mon, 20 May 2013 22:13 Go to previous messageGo to next message
Oh. Is there some tutorial on how to do this? A link or some info will be helpful.
Re: Setting up URI imports [message #1059662 is a reply to message #1059634] Tue, 21 May 2013 02:57 Go to previous message
no i dont know any
Previous Topic:Getting IEditorInput in validator
Next Topic:A problem with ==, ||, and other
Current Time: Sun Jul 20 15:08:41 EDT 2025
Powered by FUDForum. Page generated in 0.04682 seconds
