Home » Eclipse Projects » Memory Analyzer » Memory analyzer not opening hprof
Memory analyzer not opening hprof [message #1059461] Sat, 18 May 2013 20:07 Go to next message
I am new to mat, and I am having some issues. I ran the command:
ant run-tests
my build.xml contains the following:
<target name="run-tests">
<junit fork="yes" printsummary="withOutAndErr">
<formatter type="plain" usefile="false" />
<test name="CLASSNAME"/>
<classpath refid="Compiler.classpath"/>
<jvmarg value="-XX:-HeapDumpOnOutOfMemoryError"/>
<jvmarg value="-XX:HeapDumpPath=/mnt/hgfs/RAM/dumps.hprof"/>
</junit>
</target>
and I get a out of memory exception. The file dumps.hprof is created, but when I try to open it in eclipse memory analyzer I get an error. I have attached the hprof (as .rar it's too big) and the .log. Any help would be appreciated.
  • Attachment: dumps.rar
    (Size: 940.20KB, Downloaded 408 times)
  • Attachment: .log
    (Size: 2.64KB, Downloaded 467 times)
Re: Memory analyzer not opening hprof [message #1060603 is a reply to message #1059461] Mon, 27 May 2013 05:38 Go to previous message
The dump is corrupt:
!MESSAGE (Possibly) Invalid HPROF file: Expected to read another 308,909,576 bytes, but only 43,679,837 bytes are available.
Do you usually get bigger heap dumps?
jhat reads the dump but also warns:
WARNING: Unexpected EOF. Will miss information...
Can you try running your tests with a more recent JVM?
I suppose Memory Analyzer could be enhanced to attempt to read a truncated dump, but I'm not sure how useful the result would be.
Previous Topic:Thread Details/Overview won't open: Object 0x2aab50739d48 not found.
Next Topic:OQL: calling Java methods
Current Time: Sat Jul 19 15:41:44 EDT 2025
Powered by FUDForum. Page generated in 0.04472 seconds
