Home » Modeling » GMF (Graphical Modeling Framework) » Saving a Diagram as a GIF
Saving a Diagram as a GIF [message #104180] Thu, 15 February 2007 05:23 Go to next message
Originally posted by: martin.tauber.t-online.de
Hello everybody,
I'm trying to save a diagram that I have created as a gif, but the code
I'm using is only producing exceptions ... Has anybody an Idea what
might be wrong? (when I break after loading the resource, to me the
resource doesn't look like it's been loaded correctly. The object loaded
is a DiagramImpl, which is what I expected, but the content seams to be
empty. the file stored is ok, since I can load it to the editor. I am
also wondering, if I somehow have to tell the resourceset, that about
the model file, since the diagram file references to the model...)
private void compile(IFile input) {
IFolder htmlDir = this.getProject().getFolder("html");
String outputFileName =
input.getLocation().removeFileExtension().addFileExtension("gif ").lastSegment();
IFile output = htmlDir.getFile(outputFileName);
ResourceSet resourceSet = new ResourceSetImpl();
Resource resource = resourceSet.getResource(
URI.createURI(input.getRawLocationURI().toString()), true);
if(resource instanceof XMIResourceImpl){
Object object = resource.getContents().get(0);
CopyToImageUtil copyToImageUtil = new CopyToImageUtil();
try {
copyToImageUtil.copyToImage((Diagram)
object, output.getFullPath(), ImageFileFormat.GIF, null,
PreferencesHint.USE_DEFAULTS);
} catch (CoreException e) {
e.printStackTrace();
Re: Saving a Diagram as a GIF [message #104333 is a reply to message #104180] Thu, 15 February 2007 10:18 Go to previous messageGo to next message
If your diagram is canonical there is a possibility that all shapes on
it are transient and had not been persisted (which is OK).
You can check if this is the case by opening your diagram file in a text
editor and check if it had children inside it
If the diagram is canonical it will be populated when the editor opens
What exceptions do you get ?
another important thing is to check the Element feature on the diagram
if it is null or proxy , then this explains why your diagram shows up empty
Martin Tauber wrote:
> Hello everybody,
> try {
Re: Saving a Diagram as a GIF [message #104573 is a reply to message #104333] Fri, 16 February 2007 05:37 Go to previous messageGo to next message
I think I'm getting a bit closer. I debugged the code and found out that
the CoptyToImageUtil.copyToImage method tries to create a new Shell().
This fails.
Hm - I am trying to write a builder that converts diagrams to images as
soon as they are saved. It is the default Nature/Builder configuration
of eclipse that I am making use of here, so the builder is running in a
seperate thread (And I guess not the thread which has all the gui
information ...) So this might be the cause of the exception ...
But ... why the hell does the convertion need SWT? And how can I avoid it?
Martin
P.S. Sounds interesting the canonical stuff, can you please give some
more information about why I would need it? Has it something to do with
the lazy loading / proxies in EMF?
>> Hello everybody,
>> code I'm using is only producing exceptions ... Has anybody an Idea
>> what might be wrong? (when I break after loading the resource, to me
>> the resource doesn't look like it's been loaded correctly. The object
>> loaded is a DiagramImpl, which is what I expected, but the content
>> seams to be empty. the file stored is ok, since I can load it to the
>> editor. I am also wondering, if I somehow have to tell the
>> resourceset, that about the model file, since the diagram file
>> try {
>> null, PreferencesHint.USE_DEFAULTS);
Re: Saving a Diagram as a GIF [message #104627 is a reply to message #104573] Fri, 16 February 2007 10:10 Go to previous messageGo to next message
Hi ;
To save the diagram as Image, the diagram had to be opened, opened here
do not mean just open the resource we need to render the diagram it does
not matter if it is rendered in memory or i the actual editor but it had
to be rendered, other wise the transient canonical views will not show
up and layout will not be correct
> This fails.
> Regards
> Martin
> Thanks
>> text editor and check if it had children inside it
>> empty
>>> Hello everybody,
>>> try {
Re: Saving a Diagram as a GIF [message #104669 is a reply to message #104627] Fri, 16 February 2007 10:43 Go to previous messageGo to next message
Does that mean I can't achieve what I was trying to achieve?
Martin
> Hi ;
> here do not mean just open the resource we need to render the diagram it
> does not matter if it is rendered in memory or i the actual editor but
> it had to be rendered, other wise the transient canonical views will not
> show up and layout will not be correct
>> that the CoptyToImageUtil.copyToImage method tries to create a new
>> Shell(). This fails.
>> as soon as they are saved. It is the default Nature/Builder
>> configuration of eclipse that I am making use of here, so the builder
>> is running in a seperate thread (And I guess not the thread which has
>> all the gui information ...) So this might be the cause of the
>> exception ...
>> it?
>> Regards
>> Martin
>> with the lazy loading / proxies in EMF?
>> Thanks
>>> on it are transient and had not been persisted (which is OK).
>>> diagram if it is null or proxy , then this explains why your diagram
>>> shows up empty
>>>> Hello everybody,
>>>> object loaded is a DiagramImpl, which is what I expected, but the
>>>> content seams to be empty. the file stored is ok, since I can load
>>>> it to the editor. I am also wondering, if I somehow have to tell the
>>>> try {
Re: Saving a Diagram as a GIF [message #104707 is a reply to message #104669] Fri, 16 February 2007 16:06 Go to previous messageGo to next message
What I was trying to say is that GMF requires SWT, EMF and GEF
I'm not sure what is the problem in your case may be you need to change
the place where you call CoptyToImageUtil
if you can write a junit to reproduce this problem, then we can look at
it and see if there is possible solution
> Regards
> Martin
>> Hi ;
>> it does not matter if it is rendered in memory or i the actual editor
>> but it had to be rendered, other wise the transient canonical views
>> will not show up and layout will not be correct
>>> exception ...
>>> avoid it?
>>> Regards
>>> Martin
>>> Thanks
>>>> shows up empty
>>>>> Hello everybody,
>>>>> me the resource doesn't look like it's been loaded correctly. The
>>>>> the resourceset, that about the model file, since the diagram file
>>>>> try {
Re: Saving a Diagram as a GIF [message #104781 is a reply to message #104707] Sat, 17 February 2007 04:30 Go to previous messageGo to next message
Hi Mohammed,
sorry I'm not familiar with junit, but I'll try to explain, why I think
it doesn't work. As I see it, GMF creates an image from the diagram
model, by just doing the same as if it would render the image to the
screen. My guess it that at some point the graphic context is changed so
that the rendering is not done to the screen, but to some buffer which
is then converted to the appropriate format and then written to disk.
ok, and here comes the problem. To render the diagram GMF goes nearly
the same route through the code as when rendering to the screen. Which
means that for rendering to an image file, it needs all the SWT suff, it
would also need to render it to the screen.
Now here comes my problem. I'm not trying to render the image in the
main thread of the application and I think this causes the trouble. I'm
trying to render in a serperate builder thread. As it seams some of the
SWT stuff can only be done from the main thread and this causes
copyToImage to fail.
Remember copyToImage needs a shell as a parameter. I'm trying to invoke
the copyToImage in a background thread. There just is no shell!
So I think, how copyToImage is designed today, it is to closly bound to
SWT and as a result, I can't achieve rendering a diagram to a image in a
background job.
Hope this informs
Martin
>> Regards
>> Martin
>>> Hi ;
>>> opened here do not mean just open the resource we need to render the
>>> diagram it does not matter if it is rendered in memory or i the
>>> actual editor but it had to be rendered, other wise the transient
>>> canonical views will not show up and layout will not be correct
>>>> builder is running in a seperate thread (And I guess not the thread
>>>> which has all the gui information ...) So this might be the cause of
>>>> the exception ...
>>>> avoid it?
>>>> Regards
>>>> Martin
>>>> some more information about why I would need it? Has it something to
>>>> do with the lazy loading / proxies in EMF?
>>>> Thanks
>>>>>> Hello everybody,
>>>>>> Idea what might be wrong? (when I break after loading the
>>>>>> resource, to me the resource doesn't look like it's been loaded
>>>>>> correctly. The object loaded is a DiagramImpl, which is what I
>>>>>> expected, but the content seams to be empty. the file stored is
>>>>>> ok, since I can load it to the editor. I am also wondering, if I
>>>>>> somehow have to tell the resourceset, that about the model file,
>>>>>> try {
Re: Saving a Diagram as a GIF [message #105826 is a reply to message #104707] Wed, 21 February 2007 08:13 Go to previous messageGo to next message
Is something unclear about my description?
Martin
>> Regards
>> Martin
>>> Hi ;
>>>> the exception ...
>>>> avoid it?
>>>> Regards
>>>> Martin
>>>> Thanks
>>>>>> Hello everybody,
>>>>>> try {
Re: Saving a Diagram as a GIF [message #105923 is a reply to message #105826] Wed, 21 February 2007 10:37 Go to previous messageGo to next message
No; what you said is clear enough
when it fails to create the shell do you get an
ERROR_THREAD_INVALID_ACCESS exception ?
if not what exception do you get
id you can send me a sample code to reproduce it this will help, if not
that is OK, i think i know what is going on
> Regards
> Martin
>> change the place where you call CoptyToImageUtil
>> at it and see if there is possible solution
>>> Regards
>>> Martin
>>>> Hi ;
>>>>> images as soon as they are saved. It is the default Nature/Builder
>>>>> avoid it?
>>>>> Regards
>>>>> Martin
>>>>> to do with the lazy loading / proxies in EMF?
>>>>> Thanks
>>>>>> shapes on it are transient and had not been persisted (which is OK).
>>>>>> a text editor and check if it had children inside it
>>>>>> opens
>>>>>>> Hello everybody,
>>>>>>> the code I'm using is only producing exceptions ... Has anybody
>>>>>>> an Idea what might be wrong? (when I break after loading the
>>>>>>> try {
>>>>>>> ImageFileFormat.GIF, null, PreferencesHint.USE_DEFAULTS);
Re: Saving a Diagram as a GIF [message #105937 is a reply to message #105826] Wed, 21 February 2007 10:57 Go to previous messageGo to next message
What happens if you wrap the call for the copyToImageUtil in a
dispaly.syncExec or asyncExec
does it help ?
> Regards
> Martin
>>> Regards
>>> Martin
>>>> Hi ;
>>>>> avoid it?
>>>>> Regards
>>>>> Martin
>>>>> Thanks
>>>>>> opens
>>>>>>> Hello everybody,
>>>>>>> try {
Re: Saving a Diagram as a GIF [message #214480 is a reply to message #105937] Sun, 04 January 2009 13:40 Go to previous messageGo to next message
Originally posted by: info.pw-toxic.de
I think i have a similar Problem. I want to do the following:
I have a GMFDiagram, and i want to export the diagram to an external
file (for example a gif image).
But there is no Editor opened or something like this. The following code
is executed by an extension point of my plug-in:
so i use the extension points org.eclipse.ui.menus and
org.eclipse.ui.commands.
CopyToImageUtil util = new CopyToImageUtil();
DiagramEditPart editPart = util.createDiagramEditPart(
diagram.getGmfdiagram(),
null,
util.copyToImage(
editPart,
new Path("test"),
null
But i get this error:
org.eclipse.swt.SWTException: Invalid thread access
at the line "DiagramEditPart editPart = util.createDiagramEditPart("
So i tried something different:
util.copyToImage(
new Path("test"),
null,
but then i get the following error:
java.lang.NullPointerException (first line of code above)
I have browsed the GMF newsgroup, but i couldn't find any solution to
this topic. Google couldn't help me too, so you are my last hope ;)
Any help would be appreciated!
Both full stack traces:
at
org.eclipse.draw2d.DeferredUpdateManager.sendUpdateRequest(D eferredUpdateManager.java:243)
at
org.eclipse.draw2d.DeferredUpdateManager.queueWork(DeferredU pdateManager.java:231)
at
org.eclipse.draw2d.DeferredUpdateManager.addInvalidFigure(De ferredUpdateManager.java:126)
at org.eclipse.draw2d.Figure.revalidate(Figure.java:1349)
at org.eclipse.draw2d.Figure.setLayoutManager(Figure.java:1538)
at
org.eclipse.draw2d.LightweightSystem.createRootFigure(Lightw eightSystem.java:166)
at org.eclipse.draw2d.LightweightSystem.init(LightweightSystem. java:184)
at org.eclipse.draw2d.LightweightSystem.<init>(LightweightSystem.java:77)
at
org.eclipse.gmf.runtime.diagram.ui.parts.DiagramGraphicalVie wer$LightweightSystemWithUpdateToggle. <init>(DiagramGraphicalViewer.java:136)
at
at
org.eclipse.gmf.runtime.diagram.ui.parts.DiagramGraphicalVie wer.createLightweightSystem(DiagramGraphicalViewer.java:173)
at
org.eclipse.gef.ui.parts.GraphicalViewerImpl.<init>(GraphicalViewerImpl.java:66)
at
org.eclipse.gef.ui.parts.ScrollingGraphicalViewer.<init>(ScrollingGraphicalViewer.java:44)
at
org.eclipse.gmf.runtime.diagram.ui.parts.DiagramGraphicalVie wer. <init>(DiagramGraphicalViewer.java:53)
at
org.eclipse.gmf.runtime.diagram.ui.OffscreenEditPartFactory. createDiagramEditPart(OffscreenEditPartFactory.java:98)
at
org.eclipse.gmf.runtime.diagram.ui.render.util.CopyToImageUt il.createDiagramEditPart(CopyToImageUtil.java:86)
at
org.eclipse.gmf.runtime.diagram.ui.render.util.CopyToImageUt il.copyToImage(CopyToImageUtil.java:400)
at
org.eclipse.gmf.runtime.diagram.ui.render.util.CopyToImageUt il.copyToImage(CopyToImageUtil.java:305)
at
org.eclipse.gmf.runtime.diagram.ui.render.util.CopyToImageUt il.copyToImage(CopyToImageUtil.java:123)
> does it help ?
>> Regards
>> Martin
>>>> Regards
>>>> Martin
>>>>> Hi ;
>>>>> the diagram it does not matter if it is rendered in memory or i the
>>>>>> out that the CoptyToImageUtil.copyToImage method tries to create a
>>>>>> new Shell(). This fails.
>>>>>> thread which has all the gui information ...) So this might be the
>>>>>> avoid it?
>>>>>> Regards
>>>>>> Martin
>>>>>> Thanks
>>>>>>> opens
>>>>>>>> Hello everybody,
>>>>>>>> try {
Re: Saving a Diagram as a GIF [message #214491 is a reply to message #214480] Sun, 04 January 2009 15:52 Go to previous messageGo to next message
Originally posted by: atoulme.intalio.com
For reference the fix consists of wrapping the code:
PlatformUI.getWorkbench().getDisplay().syncExec(new Runnable() { public
void run() {// do the transformation here}});
Antoine
Re: Saving a Diagram as a GIF [message #214522 is a reply to message #214491] Mon, 05 January 2009 06:11 Go to previous messageGo to next message
Thanks Toulme, this fixes the first error, but the image export still
only works, if i have previousivly opened the diagram in an GMF editor
manually in my eclipse RCP. The GMF Diagrams don't need to be opened
currently. It helps if I open the diagrams once, and close them again.
Eclipse seems to remember which diagrams i have opened previousivly.
Anyway, if i haven't opened the diagram yet, this error occurs:
org.eclipse.swt.SWTException: Failed to execute runnable
(java.lang.NullPointerException)
at org.eclipse.swt.SWT.error(SWT.java:3777)
at org.eclipse.swt.SWT.error(SWT.java:3695)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.j ava:194)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchroniz er.java:150)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4021)
at
org.unicase.docExport.exportModel.renderers.defaultRenderers .impl.DefaultModelElementRendererImpl.renderDiagram(DefaultM odelElementRendererImpl.java:288)
at
org.unicase.docExport.exportModel.renderers.defaultRenderers .impl.DefaultModelElementRendererImpl.render(DefaultModelEle mentRendererImpl.java:137)
at
org.unicase.docExport.exportModel.renderers.defaultRenderers .impl.DefaultDocumentRendererImpl.renderModelElement(Default DocumentRendererImpl.java:250)
at
org.unicase.docExport.exportModel.renderers.defaultRenderers .impl.DefaultDocumentRendererImpl.renderDocLeafSection(Defau ltDocumentRendererImpl.java:130)
at
org.unicase.docExport.exportModel.renderers.defaultRenderers .impl.DefaultDocumentRendererImpl.render(DefaultDocumentRend ererImpl.java:95)
at org.unicase.docExport.DocumentExport.export(DocumentExport.j ava:58)
at org.unicase.docExport.DocumentExport.run(DocumentExport.java :73)
at
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:121)
at
org.eclipse.gmf.runtime.diagram.core.util.ViewUtil.getIdStr( ViewUtil.java:646)
at
org.eclipse.gmf.runtime.diagram.ui.render.util.CopyToImageUt il.copyToImage(CopyToImageUtil.java:121)
at
org.unicase.docExport.exportModel.renderers.defaultRenderers .impl.DefaultModelElementRendererImpl$1.run(DefaultModelElem entRendererImpl.java:303)
org.unicase.docExport is my plugin and
DefaultModelElementRendererImpl.java:303 is the following line:
util.copyToImage(
Here is the full code:
public void run() {
try {
util.copyToImage(
new Path(tmpImage.toString()),
ImageFileFormat.SVG,
new NullProgressMonitor(),
> Antoine
Re: Saving a Diagram as a GIF [message #214672 is a reply to message #214522] Tue, 06 January 2009 16:06 Go to previous messageGo to next message
Sebastian,
What does "diagram.getGmfdiagram()" do? I'm guessing that it returns
null when you haven't previously opened the diagram, which makes me
think that maybe you're not loading the resource that contains the
diagram in that case?
Linda
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> util.copyToImage(
> Runnable() {
> public void run() {
> try {
> util.copyToImage(
>> public void run() {// do the transformation here}});
>> Thanks,
>> Antoine
Re: Saving a Diagram as a GIF [message #214679 is a reply to message #214672] Tue, 06 January 2009 19:43 Go to previous message
Hi Linda,
You are right. diagram.getGmfDiagram() returned null in these cases. The
resource was loaded, but the Diagram needs to be initialized within an
transaction.
Thanks a lot!
Linda Damus schrieb:
> Sebastian,
> Regards,
> Linda
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> util.copyToImage(
>> Runnable() {
>> public void run() {
>> try {
>> util.copyToImage(
>>> Thanks,
>>> Antoine
Previous Topic:after configure command executed twice?
Next Topic:Drag and drop from diagram to a view
Current Time: Sun Jul 20 06:15:28 EDT 2025
Powered by FUDForum. Page generated in 0.23809 seconds
