Home » Archived » Jubula » aut hungs when start it
aut hungs when start it [message #1058189] Mon, 13 May 2013 03:06 Go to next message
Aut configuration set the executable file with an script names test.bat:
echo off
echo "wmic cpu get MaxClockSpeed"
setlocal enabledelayedexpansion
for /f %%i in ('set') do (
set MaxClockSpeed=%%i
echo MaxClockSpeed=!MaxClockSpeed!
echo set end
for /f %%i in ('wmic cpu get MaxClockSpeed') do (
//---------AUT hungs here----------//
echo wmic end
Thanks a lot,
posia
[Updated on: Mon, 13 May 2013 03:08] by Moderator
Re: aut hungs when start it [message #1058495 is a reply to message #1058189] Tue, 14 May 2013 07:13 Go to previous messageGo to next message
I'm sorry, I don't understand what it is you are trying to do. Is the script used for starting your AUT? If you post more information, someone might be able to help you.
Alex
Re: aut hungs when start it [message #1059151 is a reply to message #1058495] Thu, 16 May 2013 22:21 Go to previous messageGo to next message
Yes,the script I mentioned is the Aut which I want to start.
Posia
Re: aut hungs when start it [message #1059175 is a reply to message #1059151] Fri, 17 May 2013 02:36 Go to previous message
Thanks... but I'm still confused - where is the executable file call / the part that actually starts an application with a GUI? (I'm not so hot on reading scripts, so I could be incorrectly confused, but looking at it I can't see where an actual AUT would be started.)
Previous Topic:Problem with executing external command on remote machine with 'Local' parameter set on false
Next Topic:import gives strange error
Current Time: Sat Jul 19 12:39:39 EDT 2025
Powered by FUDForum. Page generated in 0.24658 seconds
