Home » Archived » Jubula » Help:testexec run in windows ocurred(testexec run in windows2003 ocurred an error while successfully running in windowsXP)
icon9.gif  Help:testexec run in windows ocurred [message #993758] Tue, 25 December 2012 06:21 Go to next message
1、testexec -autconfig clientSetup@192.168.2.92 -datadir "D:\Program Files\jubula\jubula\workspace" -dbpw passwd -dburl "jdbc:oracle:thin:@192.168.2.114:1521:jubula" -dbuser system -language zh_CN -project NetNumen -resultdir "D:\rundata" -server 192.168.2.92 -port 60000 -testsuite setupClientSuitCN -version 1.0 -data "C:\Program Files\jubula\jubula\workspace" -dbscheme jubula
2、log:2012-12-25 17:58:39.750 [main] ERROR o.e.j.c.cmd.AbstractCmdlineClient - An error ocurred: No Database Connection is available for name "Netnumen". Available names: Default Embedded (H2)
2012-12-25 17:58:39.812 [main] ERROR o.e.j.c.cmd.AbstractCmdlineClient - An error occured:
org.apache.commons.cli.ParseException:
at org.eclipse.jubula.client.cmd.AbstractCmdlineClient.parseCommandLine(AbstractCmdlineClient.java:230) ~[org.eclipse.jubula.client.cmd_1.2.1.201206131127.jar:na]
at org.eclipse.jubula.client.cmd.AbstractCmdlineClient.run(AbstractCmdlineClient.java:382) ~[org.eclipse.jubula.client.cmd_1.2.1.201206131127.jar:na]
at org.eclipse.jubula.client.cmd.AbstractLauncher.start(AbstractLauncher.java:26) [org.eclipse.jubula.client.cmd_1.2.1.201206131127.jar:na]
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196) [org.eclipse.equinox.app_1.3.100.v20110321.jar:na]
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110) [org.eclipse.osgi_3.7.2.v20120110-1415.jar:na]
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79) [org.eclipse.osgi_3.7.2.v20120110-1415.jar:na]
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344) [org.eclipse.osgi_3.7.2.v20120110-1415.jar:na]
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179) [org.eclipse.osgi_3.7.2.v20120110-1415.jar:na]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[na:1.6.0_18]
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) ~[na:1.6.0_18]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) ~[na:1.6.0_18]
at java.lang.reflect.Method.invoke(Unknown Source) ~[na:1.6.0_18]
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622) [org.eclipse.equinox.launcher_1.2.0.v20110502.jar:na]
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577) [org.eclipse.equinox.launcher_1.2.0.v20110502.jar:na]
at org.eclipse.equinox.launcher.Main.run(Main.java:1410) [org.eclipse.equinox.launcher_1.2.0.v20110502.jar:na]
at org.eclipse.equinox.launcher.Main.main(Main.java:1386) [org.eclipse.equinox.launcher_1.2.0.v20110502.jar:na]
at com.exe4j.runtime.LauncherEngine.launch(Unknown Source) [i4jruntime.jar:na]
at com.exe4j.runtime.WinLauncher.main(Unknown Source) [i4jruntime.jar:na]
Re: Help:testexec run in windows ocurred [message #994369 is a reply to message #993758] Thu, 27 December 2012 00:31 Go to previous messageGo to next message
I reinstalled Jubula1.3.0,and the problem has been solved!
Re: Help:testexec run in windows ocurred [message #1059170 is a reply to message #994369] Fri, 17 May 2013 02:21 Go to previous messageGo to next message
This problem occured again on a different machine(the same testsuit on my own machine,It works well of testexec command).I checked the Aut configuration, the .xml file, the jubula version and the dbshceme of Jubula, all of these are correct.Could anyone can offer some good idea?
Thanks a lot,
Posia
[Updated on: Fri, 17 May 2013 02:33] by Moderator
Re: Help:testexec run in windows ocurred [message #1059174 is a reply to message #1059170] Fri, 17 May 2013 02:35 Go to previous messageGo to next message
The error message say that " No Database Connection is available for name "Netnumen". Available names: Default Embedded (H2)". It sounds like the workspace you're using doesn't have the database configured or the dburl you've entered is for another database name.
HTH,
Alex
Re: Help:testexec run in windows ocurred [message #1060108 is a reply to message #1059174] Thu, 23 May 2013 03:16 Go to previous message
Hi Alex,
Does it matter that if I opened two ITE based on different workspaces? Testexec command don't know choose which one to test? How can I check it?
Thanks a lot,
Posia
Previous Topic:storeValue action not working
Next Topic:Drag and drop not scrolling in Jubula
Current Time: Sun Jul 20 10:06:02 EDT 2025
Powered by FUDForum. Page generated in 0.04005 seconds
