Home » Archived » BIRT » how-to-get-a-x-axis-label-value-by-parameter-in-bar-chart
how-to-get-a-x-axis-label-value-by-parameter-in-bar-chart [message #1058527] Tue, 14 May 2013 08:03 Go to next message
in this script we are getting baseAxes value according to parameter
function beforeGeneration(chart, icsc)
importPackage( Packages.org.eclipse.birt.chart.model.attribute.impl );
importPackage( Packages.org.eclipse.birt.chart.model.attribute );
xAxis = chart.getBaseAxes()[0];
if ( xAxis.getType() == AxisType.DATE_TIME_LITERAL){
var groupparm = icsc.getExternalContext().getScriptable().getParameterValue("pDateGrouping");
if( groupparm == "Days")
xAxis.setFormatSpecifier( JavaDateFormatSpecifierImpl.create("MM/dd/yyyy") );
else if( groupparm == "Years" )
xAxis.setFormatSpecifier( JavaDateFormatSpecifierImpl.create("yyyy") );
else if( groupparm == "Months" )
xAxis.setFormatSpecifier( JavaDateFormatSpecifierImpl.create("MM/yy") );
else if( groupparm == "Quarters" ){
xAxis.setFormatSpecifier( JavaDateFormatSpecifierImpl.create("'Q'Q/yy") );
my requirement
if ( xAxis.getType() == AxisType.TEXT_LITERAL){
var groupparm = icsc.getExternalContext().getScriptable().getParameterValue("geography");
if( groupparm == "zone")
xAxis.?( ?.create("?") );
else if( groupparm == "state" )
else if( groupparm == "city" )
like wise i have one table in that many columns are there zone,state,city,...its go on
so now my doubt is
for example:
if i click option "zone" in list box i have get value in bar chart south,west,east,north in x-axis and corresponding net sale in y axis....
if i click option "state" in list box i have get value in bar chart tamilnadu,kerala,chennai, in x-axis and corresponding net sale in y axis....
thanks in advance..............
Re: how-to-get-a-x-axis-label-value-by-parameter-in-bar-chart [message #1058777 is a reply to message #1058527] Tue, 14 May 2013 23:32 Go to previous messageGo to next message
You could create a chart for each option and drop the unneeded ones. You could change your chart query based on the selection and make the column names generic so that you can use the same chart and same dataSet. If I'm misunderstanding, is there any way you could create a simple example design that I can run, so I can see exactly what you're trying to do?
Re: how-to-get-a-x-axis-label-value-by-parameter-in-bar-chart [message #1058874 is a reply to message #1058777] Wed, 15 May 2013 09:47 Go to previous messageGo to next message
here i attached is a model example ...
like wise
my requirement
so now my doubt is
for example:
can u create a sample report for this....
how to change chart query based on the selection and make the column names generic
its urgent requirement
[Updated on: Wed, 15 May 2013 09:50] by Moderator
Re: how-to-get-a-x-axis-label-value-by-parameter-in-bar-chart [message #1059076 is a reply to message #1058874] Thu, 16 May 2013 10:32 Go to previous messageGo to next message
kindly reply for my last topic
please help
thank in advance...
Re: how-to-get-a-x-axis-label-value-by-parameter-in-bar-chart [message #1059122 is a reply to message #1059076] Thu, 16 May 2013 16:29 Go to previous messageGo to next message
What's your BIRT version?
EDIT: Nevermind. I didn't see the example attached above. Smile
[Updated on: Thu, 16 May 2013 20:24] by Moderator
Re: how-to-get-a-x-axis-label-value-by-parameter-in-bar-chart [message #1059141 is a reply to message #1058527] Thu, 16 May 2013 20:39 Go to previous messageGo to next message
Take a look at the modified design attached. In the original query, I alias the fields, as you did in your original dataSet. I then use the parameter value to modify the query in the beforeOpen to change the field brought in under the xaxis alias.
The chart is set up to use the fields xaxis and yaxis, so it doesn't care what the query is. Hope this helps.
Re: how-to-get-a-x-axis-label-value-by-parameter-in-bar-chart [message #1059320 is a reply to message #1059141] Fri, 17 May 2013 09:58 Go to previous messageGo to next message
thank u.....i need exactly this is........
And again one doubut for me.....
i attached a sample report and and mine report
just compare and clarify a doubt ....
please...help me
thank in advance...
Re: how-to-get-a-x-axis-label-value-by-parameter-in-bar-chart [message #1059409 is a reply to message #1059320] Sat, 18 May 2013 00:45 Go to previous messageGo to next message
Can you explain more about what you're wanting me to look at? Thanks.
Re: how-to-get-a-x-axis-label-value-by-parameter-in-bar-chart [message #1059567 is a reply to message #1059409] Mon, 20 May 2013 10:01 Go to previous messageGo to next message
hi thanks for reply....
my requirement is:
1)geography-------->listbox
2) country------------cascading parameter
zone
state
city
...etc
3)to drop table
like 1) bill
2)sale
3)etc....
my question is when i select in geography value and i have to drop a table
and then again i will select from cascading paramter and i will drop same table
i have run both by separate it run ......good
when i combine in same report it cant be run....so it possible to exceute in same report
i have used a to drop a table in before factory
a = reportContext.getReportRunnable().designHandle.getDesignHandle().findElement("apc");
b = reportContext.getReportRunnable().designHandle.getDesignHandle().findElement("aspb");
c = reportContext.getReportRunnable().designHandle.getDesignHandle().findElement("bill");
d = reportContext.getReportRunnable().designHandle.getDesignHandle().findElement("aspd");
e=reportContext.getReportRunnable().designHandle.getDesignHandle().findElement("sale");
f=reportContext.getReportRunnable().designHandle.getDesignHandle().findElement("walkin");
if (params["Table"].value == "APC")
b.drop();
c.drop();
d.drop();
e.drop();
f.drop();
if (params["Table"].value == "ASPB")
a.drop();
c.drop();
d.drop();
e.drop();
f.drop();
if (params["Table"].value == "BILL")
a.drop();
b.drop();
d.drop();
e.drop();
f.drop();
if (params["Table"].value == "ASPD")
a.drop();
b.drop();
c.drop();
e.drop();
f.drop();
if (params["Table"].value == "SALE")
a.drop();
b.drop();
c.drop();
d.drop();
f.drop();
if (params["Table"].value == "WALKIN")
a.drop();
b.drop();
c.drop();
d.drop();
e.drop();
for Geography: i have pass parameter by this
<method name="beforeOpen"><![CDATA[
if(params["Geography"].value =="STATE_NAME")
this.queryText = this.queryText.replace("ZONE_NAME","STATE_NAME");
else if(params["Geography"].value =="CITY_NAME")
this.queryText = this.queryText.replace("ZONE_NAME","CITY_NAME");
else if(params["Geography"].value =="AREA_MANAGER")
this.queryText = this.queryText.replace("ZONE_NAME","AREA_MANAGER");
else if(params["Geography"].value =="outlet_name")
this.queryText = this.queryText.replace("ZONE_NAME","outlet_name");
]]></method>
for country,city,state i have pass parameter by this:
<method name="beforeOpen"><![CDATA[var Varcoun;
var Varzone;
var Varstate;
var Varcity;
var Vararea;
var Varoutlet;
var txtcoun;
var txtzone;
var txtstate;
var txtcity;
var txtarea;
var txtoutlet;
if(params["country"]==' All country')
Varcoun= '%'
txtcoun= ' LIKE ';
else
Varcoun = params["country"]
txtcoun = ' = ';
if(params["zone"]==' All zone')
Varzone= '%'
txtzone= ' LIKE ';
else
Varzone = params["zone"]
txtzone = ' = ';
if(params["state"]==' All state')
Varstate = '%'
txtstate = ' LIKE ';
else
Varstate = params["state"]
txtstate = ' = ';
if(params["city"]==' All city')
Varcity = '%'
txtcity = ' LIKE '
else
Varcity = params["city"]
txtcity = ' = ';
if(params["Area Manager"]==' All manager')
Vararea = '%'
txtarea = ' LIKE ';
else
Vararea = params["Area Manager"]
txtarea = ' = ';
if(params["outlet"]==' All outlet')
Varoutlet = '%'
txtoutlet = ' LIKE ';
else
Varoutlet = params["outlet"]
txtoutlet = ' = ';
("/**a**/",
" AND COUNTRY_NAME"+ txtcoun + "'"+ Varcoun +
"'AND ZONE_NAME"+ txtzone + "'"+ Varzone +
"'AND STATE_NAME"+ txtstate+ "'"+ Varstate +
"'AND CITY_NAME"+ txtcity+ "'"+ Varcity +
"'AND AREA_MANAGER"+ txtarea + "'"+ Vararea +
"'AND OUTLET_NAME"+ txtoutlet+ "'"+ Varoutlet +"'"+
"GROUP BY TRAN_DATE,COUNTRY_NAME,zone_name,STATE_NAME,CITY_NAME,AREA_MANAGER,OUTLET_NAME,CAFE_TYPE_ID"
kindly help me...
thank in advance
Re: how-to-get-a-x-axis-label-value-by-parameter-in-bar-chart [message #1059640 is a reply to message #1059567] Tue, 21 May 2013 01:16 Go to previous messageGo to next message
Can you attach your design? Better yet, can you create a sample showing the issue with the sample database? This way I can see your setup and run the report.
Re: how-to-get-a-x-axis-label-value-by-parameter-in-bar-chart [message #1059950 is a reply to message #1059640] Wed, 22 May 2013 06:27 Go to previous message
No Message Body
[Updated on: Wed, 22 May 2013 06:30] by Moderator
Previous Topic:Multi level Pie Chart
Next Topic:Postscript Level BIRT 2.2RC2
Current Time: Sun Jul 20 17:49:50 EDT 2025
Powered by FUDForum. Page generated in 0.04841 seconds
