Home » Eclipse Projects » Memory Analyzer » How to open a HTML report via MAT in Eclipse?(HTML leak suspect report)
How to open a HTML report via MAT in Eclipse? [message #1048490] Wed, 24 April 2013 10:42 Go to next message
In Eclispe help, find that:
"Running Leak Suspect Report
In the toolbar select the drop-down menu Run Expert System Test > Leak Suspects . As a result an HTML report will be opened. It contains an overview of the heap dump and leak suspect info. "
But actually when i select Run Expert System Test > Leak Suspects, no HTML report is opened in Eclispe.
But under the hprof file path, a Leak_Suspects.zip has been created, and it contains the index.html which shows the leak suspect overview info.
Is these some configuration i have missed for this?
Ubuntu 12.10 32-bit
Eclipse SDK Version: 4.2.2, Build id: M20130204-1200
MAT Version 1.2
I'm a newer for MAT, and looking forward someone's help.Thanks in advance.
Re: How to open a HTML report via MAT in Eclipse? [message #1059011 is a reply to message #1048490] Thu, 16 May 2013 04:12 Go to previous message
I'm not sure what has happened. Does
Run Expert System Test > Open Report > yourdump_Leak_Suspects.zip
work?
Does
Open Query Browser > Leak Identification > Find Leaks
work?
Previous Topic:where I can download some docs about the MAT
Next Topic:Help in analysis
Current Time: Sat Jul 19 19:23:26 EDT 2025
Powered by FUDForum. Page generated in 0.04566 seconds
