Home » Archived » M2M (model-to-model transformation) » How to duplicate an element
How to duplicate an element [message #105834] Fri, 29 May 2009 11:20 Go to next message
I am a beginner and I am a bit lost dealing with this:
I have a metamodel with this structure
A <-> Connection <-> B
Where A has a collection of Connections, B has a Collection of
Connection and Connection has one A(opposite of connections in A) and
One B(opposite of connections in B)
If I have this instance of the previous metamodel:
a1 <-> conn1 <-> b1
and I want to generate something like this
a1 <-> Conn1 <-> b1
a1 <-> Conn1' <-> b1
I want to duplicate the Connection conn1. I want a1 and b1 connected
twice, with the original connection and a new one.
I dont know how to duplicate the connection conn1 and generate the new one.
I would preciate any clue about how to deal with this.
thanks in advance
colo
Re: How to duplicate an element [message #105862 is a reply to message #105834] Tue, 02 June 2009 02:35 Go to previous messageGo to next message
You post concerns ATL or QVT?
You must prefix your post with the [ATL] or [QVT]
> a1 <-> conn1 <-> b1
> a1 <-> Conn1 <-> b1
> thanks in advance
> colo
[ATL] How to duplicate an element [message #106120 is a reply to message #105862] Thu, 04 June 2009 21:38 Go to previous messageGo to next message
a1 <-> conn1 <-> b1
a1 <-> Conn1 <-> b1
thanks in advance
colo
Esteban DUGUEPEROUX escribió:
>> a1 <-> conn1 <-> b1
>> a1 <-> Conn1 <-> b1
>> one.
>> thanks in advance
>> colo
Re: [ATL] How to duplicate an element [message #106139 is a reply to message #106120] Sat, 06 June 2009 07:01 Go to previous messageGo to next message
Originally posted by: a.w.laarman.ewi.utwente.nl
Hi colo,
If the number of duplicates is constant, you can use the normal ATL rules to
solve this. That goes somehting like this:
rule AtoX {...}
rule BtoY {...}
rule ConnectiontoCC {
from i:Connection {..}
to o1:Connection2, o2:Connection2 {...}
Alfons
On 6/5/09 3:38 AM, in article h09su3$h4k$1@build.eclipse.org, "Colo"
> a1 <-> conn1 <-> b1
> a1 <-> Conn1 <-> b1
> thanks in advance
> colo
>> Hi,
>>> a1 <-> conn1 <-> b1
>>> a1 <-> Conn1 <-> b1
>>> one.
>>> thanks in advance
>>> colo
Re: [ATL] How to duplicate an element [message #107839 is a reply to message #106139] Sat, 04 July 2009 17:24 Go to previous messageGo to next message
I'm an ATL novice too. My problem is similar to Colo's but with a couple
of complications. My metamodel is like this:
A contains -> B contains -> C ref -> D
So I have an instance like:
a contains -> b
b contains -> (c1, c2)
c1 ref->d1
c2 ref->d2
I want duplicate elements contained in "a" using ATL where the number
duplicates to create is computed by a some helpers. If I want 2
duplicates, the model should be like:
a contains -> b, b
c1 ref->d1
c2 ref->d2
c1 ref->d1
c2 ref->d2
Thanks a lot for your help. Please let me know if your any clarifications.
regards,
Panto
Alfons Laarman wrote:
> Hi colo,
> rule AtoX {...}
> rule BtoY {...}
> Regards,
> Alfons
>> a1 <-> conn1 <-> b1
>> a1 <-> Conn1 <-> b1
>> thanks in advance
>> colo
>>> Hi,
>>>> a1 <-> conn1 <-> b1
>>>> a1 <-> Conn1 <-> b1
>>>> one.
>>>> thanks in advance
>>>> colo
Re: [ATL] How to duplicate an element [message #108230 is a reply to message #107839] Fri, 10 July 2009 17:16 Go to previous messageGo to next message
hi Pantanowitz, I solved my problem using 2 transformations:
In the first one(t1) I created the duplicated elements only(but still
unconnected).
In the second one(t2) I connect the new elements created in t1 as needed.
The input models for t2 are the original one and the partial one I
created with t1.
I decided to do that because in atl you can just navigate your source
models. In the second transformation I navigate my original source
model, an the partial one created in t1 to connect the elements as needed.
I follow the basic pattern described here:
http://www.eclipse.org/m2m/atl/basicExamples_Patterns/articl e.php?file=SideEffect/index.html
I expect me to be clear.
colo
Pantanowitz escribió:
> Hello,
> a contains -> b
> c1 ref->d1
> c2 ref->d2
> a contains -> b, b
> c1 ref->d1
> c2 ref->d2
> c1 ref->d1
> c2 ref->d2
> regards,
> Panto
>> Hi colo,
>> rules to
>> rule AtoX {...} rule BtoY {...}
>> Regards,
>> Alfons
>>> a1 <-> conn1 <-> b1
>>> a1 <-> Conn1 <-> b1
>>> new one.
>>> thanks in advance
>>> colo
>>>> Hi,
>>>>> a1 <-> conn1 <-> b1
>>>>> a1 <-> Conn1 <-> b1
>>>>> one.
>>>>> thanks in advance
>>>>> colo
Re: [ATL] How to duplicate an element [message #108260 is a reply to message #108230] Sat, 11 July 2009 11:59 Go to previous message
Thanks Colo,
It's sucks that ATL does not allow you to navigate the target model. I
was hoping there was an elegant way to use the resolveTemp operation to
helps us out! But I guess it's better to have something that works ;)
and your approach makes sense!
thanks,
Panto,
> unconnected).
> created with t1.
> colo
>> Hello,
>> couple of complications. My metamodel is like this:
>> a contains -> b
>> c1 ref->d1
>> c2 ref->d2
>> a contains -> b, b
>> c1 ref->d1
>> c2 ref->d2
>> c1 ref->d1
>> c2 ref->d2
>> clarifications.
>> regards,
>> Panto
>>> Hi colo,
>>> rules to
>>> Regards,
>>> Alfons
>>>> a1 <-> conn1 <-> b1
>>>> a1 <-> Conn1 <-> b1
>>>> new one.
>>>> thanks in advance
>>>> colo
>>>>> Hi,
>>>>>> a1 <-> conn1 <-> b1
>>>>>> a1 <-> Conn1 <-> b1
>>>>>> new
>>>>>> one.
>>>>>> thanks in advance
>>>>>> colo
Previous Topic:[ATL] collecting transformation trace information
Next Topic:[ATL] Running ATL Transformation from JAVA
Current Time: Sat Jul 19 22:32:04 EDT 2025
Powered by FUDForum. Page generated in 0.04252 seconds
