Home » Archived » BIRT » Sort button on x-axis is disabled
Sort button on x-axis is disabled [message #1058150] Sun, 12 May 2013 11:04 Go to next message
I have a chart with day of week groupings based on a group value. The data displays correctly but the days of the week are alphabetical (Friday, Monday ..) rather than day of week order. The Sort button on the x-axis category is disabled so I can't sort on the value needed.
What did I do to disable the sort, and how can I get it back or get them into the correct order?
I am using 3.7.2
Re: Sort button on x-axis is disabled [message #1058171 is a reply to message #1058150] Sun, 12 May 2013 23:29 Go to previous messageGo to next message
Can you recreate this with the sample database so I can see your setup?
Re: Sort button on x-axis is disabled [message #1058333 is a reply to message #1058150] Mon, 13 May 2013 11:07 Go to previous messageGo to next message
BIRT apparently didn't like the aggregation I was using. I switched to the aggregation tool and got the ability to sort the data properly.
Thank you for your response!
Dave
Re: Sort button on x-axis is disabled [message #1058429 is a reply to message #1058333] Tue, 14 May 2013 01:32 Go to previous message
Great. Glad you found a solution. Let us know whenever you have questions. Smile
Previous Topic:Report Designer Will Not Generate PDF
Next Topic:CrossTab Cell formating
Current Time: Sun Jul 20 05:59:20 EDT 2025
Powered by FUDForum. Page generated in 0.04359 seconds
