Home » Eclipse Projects » Eclipse 4 » Unable to display context (popup) menu for TreeViewer
Unable to display context (popup) menu for TreeViewer [message #1057821] Thu, 09 May 2013 00:33 Go to next message
I am new to Eclipse 4, so need help here.
1) I created a Popup Menu under a Part using ApplicationModel.
2) I have created a TreeViewer in this part. The TreeViewer contents are displaying fine.
3) Registered Popupmenu with MenuService instance using
menuService.registerContextMenu(myTreeViewer,Id);
Id here is the id of pop menu from application model.
4) I now run the application but cannot see the popup menu coming up on right click.
Am I missing something ? I did use Alt-Shift-F9 to confirm that popup menu is part of application model.
Re: Unable to display context (popup) menu for TreeViewer [message #1057877 is a reply to message #1057821] Thu, 09 May 2013 09:54 Go to previous messageGo to next message
S Ron wrote on Thu, 09 May 2013 06:33
Try this instead:
menuService.registerContextMenu(myTreeViewer.getControl(),Id);
Re: Unable to display context (popup) menu for TreeViewer [message #1057949 is a reply to message #1057877] Thu, 09 May 2013 22:46 Go to previous message
Thank you, that worked I had to add getControl().
Previous Topic:Editor pane tab display policy
Next Topic:How can a member variable be initialized and updated with the @Preference annotation?
Current Time: Sun Jul 20 07:59:03 EDT 2025
Powered by FUDForum. Page generated in 0.04461 seconds
