Home » Eclipse Projects » Remote Application Platform (RAP) » UICallBack and Table with SWT.VIRTUAL option
UICallBack and Table with SWT.VIRTUAL option [message #105784] Fri, 19 September 2008 09:11 Go to next message
Good day!
I tried to use a virtual table created by using class Table,
data which should be updated to a client side.
Clarify the following details:
1. If you create a virtual table through a "new Table (...)", and then
specify setItemsCount for the table, so that updates do not come to the
client, the function setItemsCount runs fine, but the event SWT.SetData
for not occur or occurs once during the open session and then take off for
bugs.
2. But if create TableViewer and do the same thing, but update data
through the Content and Label providers then all working properly.
In the case at No. 1 this is a bug?
Thank you very much.
Re: UICallBack and Table with SWT.VIRTUAL option [message #105873 is a reply to message #105784] Mon, 22 September 2008 07:06 Go to previous messageGo to next message
Originally posted by: rherrmann.innoopract.com
Sergei,
even though I would recommend to use the JFace TableViewer (No. 2),
doing the same thing with only the Table widget should work.
Have a look at the TableTab class in the ControlsDemo on how to use
VIRTUAL tables and SetData.
If your Table-code works in SWT but not in RAP, please file a bug
report along with a standalone code snippet.
Rüdiger
Rüdiger Herrmann
Innoopract
http://innoopract.com
delivering eclipse technology
Sergei wrote:
> Good day!
> for bugs.
Re: UICallBack and Table with SWT.VIRTUAL option [message #135799 is a reply to message #105873] Thu, 11 June 2009 10:07 Go to previous messageGo to next message
Hi Rüdiger,
for case at No. 1, after adding items with Table.setItemCount should be
called Table.checkData for items visible to the user?
In the following snippet, when clicked the Add button, the list item
count is incremented by 50 and the event SetData doesn't be called until
an event occurs from the browser:
public class RapTest implements IEntryPoint {
public int createUI() {
Display d = new Display();
final Shell s = new Shell(d);
s.setSize(800, 600);
final Table t = new Table(s, SWT.BORDER | SWT.VIRTUAL);
t.setBounds(20, 40, 350, 500);
t.setHeaderVisible(true);
TableColumn tc1 = new TableColumn(t, SWT.LEFT);
tc1.setText("A");
tc1.setWidth(100);
TableColumn tc2 = new TableColumn(t, SWT.LEFT);
tc2.setText("B");
tc2.setWidth(100);
TableColumn tc3 = new TableColumn(t, SWT.LEFT);
tc3.setText("C");
tc3.setWidth(100);
Button b = new Button(s, SWT.PUSH);
b.setBounds(450, 40, 50, 50);
b.setText("Add");
b.addSelectionListener(new SelectionAdapter(){
public void widgetSelected(SelectionEvent e) {
t.setItemCount(t.getItemCount() + 50);
t.addListener(SWT.SetData, new Listener() {
public void handleEvent(Event event) {
TableItem item = (TableItem) event.item;
int index = event.index;
item.setText(0, String.format("A%05d", index));
item.setText(1, String.format("B%05d", index));
item.setText(2, String.format("C%05d", index));
s.open();
while( !s.isDisposed() )
if( !d.readAndDispatch() )
d.sleep();
s.dispose();
d.dispose();
return 0;
Enrico
Rüdiger Herrmann ha scritto:
> Sergei,
> Cheers,
> Rüdiger
> Rüdiger Herrmann
> Innoopract
> Sergei wrote:
>> Good day!
>> the client, the function setItemsCount runs fine, but the event
>> SWT.SetData for not occur or occurs once during the open session and
>> then take off for bugs.
Re: UICallBack and Table with SWT.VIRTUAL option [message #135837 is a reply to message #135799] Fri, 12 June 2009 04:34 Go to previous message
Enrico Zanaga wrote:
> Hi Rüdiger,
yes
you may need to call Table#redraw() after calling setItemCount. If
this still doesn't help and you are working with the latest version
of RAP and the same code works in SWT, feel free to file a bugzilla.
> @Override
> tc1.setText("A");
> tc1.setWidth(100);
> tc2.setText("B");
> tc2.setWidth(100);
> tc3.setText("C");
> tc3.setWidth(100);
> b.setText("Add");
> @Override
> @Override
> s.open();
> d.sleep();
> s.dispose();
> d.dispose();
> return 0;
> Enrico
>> Sergei,
>> Cheers,
>> Rüdiger
>> Rüdiger Herrmann
>> Innoopract
>> Sergei wrote:
>>> Good day!
>>> then specify setItemsCount for the table, so that updates do not come
>>> to the client, the function setItemsCount runs fine, but the event
Previous Topic:qooxdoo plan
Next Topic:Language pack
Current Time: Sat Jul 19 22:38:33 EDT 2025
Powered by FUDForum. Page generated in 1.06569 seconds
