Home » Language IDEs » C / C++ IDE (CDT) » Using gdb debugger for remote session with gdbserver(Problem using gdb from within CDT remotely in eclipse juno)
Using gdb debugger for remote session with gdbserver [message #955103] Tue, 23 October 2012 10:09 Go to next message
I have Eclipse Juno installed on RedHat Enterprise Linux (6.3). We are using the CDT (C/C++) and have the DSF/GDB framework installed for debugging.
The ide is running on a separate machine where the application is. Therefore we have installed gdbserver on the remote host and have it setup as follows:
# gdbserver CAHAL-SMSS03:10069 --attach 4589
The process starts, attachs to the program we wish to debug and awaits a connection from a remote/local gdb process.
Then, we fire up eclipse juno, create a Run/Debug configuration for C/C++ Remote Application and use the GDB (DSF) Remote application launcher where we specify the Host name and port that gdbserver is up awaiting connection.
We we hit Debug, in the debug log we see:
!ENTRY org.eclipse.cdt.dsf.gdb 4 5012 2012-10-23 07:54:19.969
!MESSAGE Error in final launch sequence
!STACK 1
org.eclipse.core.runtime.CoreException: Failed to execute MI command:
-target-select remote 192.62.246.19:10069
Error message from debugger back end:
192.62.246.19:10069: No route to host.
at org.eclipse.cdt.dsf.concurrent.Query.get(Query.java:115)
at org.eclipse.cdt.dsf.gdb.launching.GdbLaunchDelegate.launchDebugSession(GdbLaunchDelegate.java:231)
at org.eclipse.cdt.dsf.gdb.launching.GdbLaunchDelegate.launchDebugger(GdbLaunchDelegate.java:106)
at org.eclipse.cdt.dsf.gdb.launching.GdbLaunchDelegate.launch(GdbLaunchDelegate.java:94)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:855)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:704)
at org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(DebugUIPlugin.java:1047)
at org.eclipse.debug.internal.ui.DebugUIPlugin$8.run(DebugUIPlugin.java:1251)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
Caused by: java.lang.Exception: 192.62.246.19:10069: No route to host.
at org.eclipse.cdt.dsf.mi.service.command.AbstractMIControl$RxThread.processMIOutput(AbstractMIControl.java:918)
at org.eclipse.cdt.dsf.mi.service.command.AbstractMIControl$RxThread.run(AbstractMIControl.java:747)
!SUBENTRY 1 org.eclipse.cdt.dsf.gdb 4 10004 2012-10-23 07:54:19.970
I have confirmed that the 2 systems can talk tcp/ip ok...
Tried using Hostname and IP address ...same issue.
Any thoughts on what I'm doing wrong?
Thx.
Wendell MacKenzie
Re: Using gdb debugger for remote session with gdbserver [message #956376 is a reply to message #955103] Wed, 24 October 2012 09:06 Go to previous messageGo to next message
Looks like GDB cannot connect to your target. To confirm this start GDB directly from the command line on your host and try to connect to your target. If you get the same error, you have a problem connecting from host to target.
On target:
On host:
> gdb
(gdb) target remote CAHAL-SMSS03:10069
(you can use the IP address instead of the hostname if you want).
Marc
Re: Using gdb debugger for remote session with gdbserver [message #958381 is a reply to message #956376] Thu, 25 October 2012 20:29 Go to previous messageGo to next message
It was the server firewall...Sad
Working great now.
Re: Using gdb debugger for remote session with gdbserver [message #1057826 is a reply to message #958381] Thu, 09 May 2013 02:13 Go to previous message
Even i have a problem with remote debugging .In eclipse juno CDT i get this error
"warning: A handler for the OS ABI "GNU/Linux" is not built into this configuration
of GDB. Attempting to continue with the default i386 settin
gs."
Previous Topic: remote debugging in eclipse cdt from linux server using cygwin
Next Topic:Make All Doesn't Work (C:\Program:)
Current Time: Sun Jul 20 05:36:28 EDT 2025
Powered by FUDForum. Page generated in 0.05144 seconds
