Home » Archived » BIRT » Table rows height problem
Table rows height problem [message #1044943] Fri, 19 April 2013 10:37 Go to next message
Hi All,
there is the possibility to lock the height of a table's row to avoid that this stretching in the presence of a text too big?
I have setted the height in inches but when i export in pdf (or ppt) this expands based on text...
Thanks in advance
Re: Table rows height problem [message #1045068 is a reply to message #1044943] Fri, 19 April 2013 14:20 Go to previous messageGo to next message
Are you using a fixed layout? If so, can you create a sample showing your issue that I can run? Thanks.
Re: Table rows height problem [message #1045762 is a reply to message #1045068] Sat, 20 April 2013 16:54 Go to previous messageGo to next message
Hi Michael,
I do not know how to use the fixed layout, but I have attached 2 example with 2 different layouts that have the same problem even if in different ways:
1) report_A: pdf there are no bottom borders, ppt writes over
2) report_B: row spread out
Considering that the layout of these reports have already been approved, there is a way (an attribute) to set the maximum height and not allow the lines to spread and do not allow to write over?
Thanks in advance
Re: Table rows height problem [message #1048605 is a reply to message #1045762] Wed, 24 April 2013 14:12 Go to previous messageGo to next message
In report B, if you set the report to fixed layout vs the auto layout it's currently in, the text seems to be cut off correctly.
Setting heights for the containing grids in report A allows the border to be shown. I cannot test for ppt because I have PowerPoint 2010.
Re: Table rows height problem [message #1053720 is a reply to message #1048605] Tue, 07 May 2013 07:36 Go to previous messageGo to next message
Hi Michael,
how can i set a fixed layout?
I change a LayoutPreference in advanced section of a report, but doesn't work.
[Updated on: Tue, 07 May 2013 07:38] by Moderator
Re: Table rows height problem [message #1057734 is a reply to message #1053720] Wed, 08 May 2013 09:50 Go to previous message
A fixed layout can be set in the general section of the property editor. If you click on the report in a blank spot or select the report design in the outline view, then go to the property editor's general section and scroll to the bottom, you should see the option.
Previous Topic:any solution for limit runaway report queries ?
Next Topic:Creating a Stacked Bar chart using a script
Current Time: Sun Jul 20 04:15:19 EDT 2025
Powered by FUDForum. Page generated in 0.07389 seconds
