Home » Modeling » TMF (Xtext) » Using both AbstractModelInferrer and IGenerator implementations(Is it possible to have both generators in the same Xtext project?)
Using both AbstractModelInferrer and IGenerator implementations [message #1053825] Tue, 07 May 2013 14:34 Go to next message
I created a gammar for a language I am constructing using Xtext and I would like to add a code generator. At first I need to generate Java code so a AbstractModelInferer is most appropriate and at last I need to generate Xtend code so I guess a IGenerator would be more appopriate. Is it possible to have both generators (ModelInferer and IGenerator) in the same Xtext project?
I tried creating both, but only the IGenerator implementation have been used. To use a IGenerator implementation I added a method to my RuntimeModule class to inject a instance of my IGenerator implementation.
In addition, I would like to learn more details about the AbstractModelInferer but it is hard to find detailed information on how to use it. Is there any tutorial that could help me?
Thanks in advance,
Re: Using both AbstractModelInferrer and IGenerator implementations [message #1053826 is a reply to message #1053825] Tue, 07 May 2013 14:41 Go to previous messageGo to next message
> same Xtext project?
> Thanks in advance,
As far as I understand you want to use both JvmModelGenerator (which is
the default generator relying on the JvmModelInferrer which is
automatically bound when using Xbase) and an additional custom generator
to generate other things?
If so you can implement your own generator strategies in, say,
MyCustomGenerator, and then bind another generator (say MyDslGenerator)
which delegates to both JvmModelGenerator and MyCustomGenerator (both
instances must be injected).
For instance
class MyDslGenerator implements IGenerator {
@Inject JvmModelGenerator g1
@Inject MyCustomGenerator g2
generate(...) {
g1.generate(...)
g2.generate(...)
and in the runtime module you bind MyDslGenerator.
hope this helps
Lorenzo
HOME: http://www.lorenzobettini.it
Re: Using both AbstractModelInferrer and IGenerator implementations [message #1053829 is a reply to message #1053826] Tue, 07 May 2013 14:54 Go to previous messageGo to next message
Alternatively you can subclass jvmmodelgenerator and add a dispatch method for the root of your model.
e.g. http://www.eclipse.org/forums/index.php/mv/msg/473491/1038310/#msg_1038310
Re: Using both AbstractModelInferrer and IGenerator implementations [message #1053834 is a reply to message #1053826] Tue, 07 May 2013 15:32 Go to previous messageGo to next message
Ok, got it. However, how would I delegate a call to the infer method:
infer(Entity element, IJvmDeclaredTypeAcceptor acceptor, boolean isPreIndexingPhase)
in my JVMModelInferrer?
I only have access to the params of the method doGenerate(Resource input, IFileSystemAccess fsa) ... so how would extract a IJvmDeclaredTypeAcceptor from Resource input given in the doGenerate method?
Thanks for attention,
Re: Using both AbstractModelInferrer and IGenerator implementations [message #1053841 is a reply to message #1053834] Tue, 07 May 2013 15:44 Go to previous messageGo to next message
I i am not talking about the inferrer.
i mean JvmModelGenerator that is bound as IGenerator by default
Re: Using both AbstractModelInferrer and IGenerator implementations [message #1057834 is a reply to message #1053834] Thu, 09 May 2013 04:03 Go to previous messageGo to next message
Leandro:
Here's how I use IGenerator & Inferrer together
... it was not that easy
- create an IOutputConfigurationProvider
public class YourOutputProvider implements IOutputConfigurationProvider {
	public static final String DEFAULT = "DEFAULT_OUTPUT";
	public static final String OTHER = "OTHER";
	public Set<OutputConfiguration> getOutputConfigurations() {
		OutputConfiguration defaultOutput = new OutputConfiguration(DEFAULT);
	    defaultOutput.setDescription("Default Folder");
	    defaultOutput.setOutputDirectory("./src-gen");
	    defaultOutput.setOverrideExistingResources(true);
	    defaultOutput.setCreateOutputDirectory(true);
	    defaultOutput.setCleanUpDerivedResources(true);
	    defaultOutput.setSetDerivedProperty(true);
	    OutputConfiguration otherOutput = new OutputConfiguration(OTHER);
	    otherOutput.setDescription("Other Folder");
	    otherOutput.setOutputDirectory("./src-gen/other");
	    otherOutput.setOverrideExistingResources(true);
	    otherOutput.setCreateOutputDirectory(true);
	    otherOutput.setCleanUpDerivedResources(true);
	    otherOutput.setSetDerivedProperty(true);
notice the properties you can set: overrideExistingResources,...
- create an Adapter
public class OutputConfigurationAdapter implements Adapter {
	private String outputConfigurationName;
	public OutputConfigurationAdapter(String outputConfigurationName) {
		this.outputConfigurationName = outputConfigurationName;
	public String getOutputConfigurationName() {
		return outputConfigurationName;
	public void notifyChanged(Notification notification) {
	public Notifier getTarget() {
		return null;
	public void setTarget(Notifier newTarget) {
	public boolean isAdapterForType(Object type) {
		return false;
- create an IFileSystemAccess
public class OutputConfigurationFileSystemAccess implements IFileSystemAccess,
		IFileSystemAccessExtension, IFileSystemAccessExtension2 {
	protected IFileSystemAccess fsa;
	protected String outputConfigurationName;
	protected OutputConfigurationFileSystemAccess(IFileSystemAccess fsa,
		this.fsa = fsa;
	public void generateFile(String fileName, CharSequence contents) {
		fsa.generateFile(fileName, outputConfigurationName, contents);
	public void generateFile(String fileName, String outputConfiguration,
	public void deleteFile(String fileName) {
		deleteFile(fileName, outputConfigurationName);
	public void deleteFile(String fileName,
			String ignoredOutputConfigurationName) {
		((IFileSystemAccessExtension) fsa).deleteFile(fileName,
	public URI getURI(String fileName, String outputConfiguration) {
		return ((IFileSystemAccessExtension2) fsa).getURI(fileName,
	public URI getURI(String fileName) {
- create your IGenerator
class YourIGenerator implements IGenerator {
	override doGenerate(Resource input, IFileSystemAccess fsa) {
- create your Inferrer
class YourModelInferrer extends AbstractModelInferrer {
  	def dispatch void infer(Foo foo, IJvmDeclaredTypeAcceptor acceptor, boolean isPreIndexingPhase) {
		var fooClass = foo.toClass(foo.name)
		fooClass.eAdapters.add(new OutputConfigurationAdapter(YourOutputProvider::DEFAULT))
		acceptor.accept(fooClass)
				.initializeLater([
		var barClass = foo.toClass(foo.name)
		barClass.eAdapters.add(new OutputConfigurationAdapter(YourOutputProvider::OTHER))
				.initializeLater([
					// nothing to do here done in YourIGenerator
adding the different eAdapters is important here cfr YourOutputProvider::DEFAULT & YourOutputProvider::OTHER
- create an JvmModelGenerator
public class YourJvmModelGenerator extends JvmModelGenerator {
	@Inject private YourGenerator generator;
	public void doGenerate(Resource input, IFileSystemAccess fsa) {
	    EList<EObject> contents = input.getContents();
	    for (final EObject obj : contents) {
	      String outputConfiguration = null;
	      for (Adapter adapter : obj.eAdapters()) {
	        if (adapter instanceof OutputConfigurationAdapter) {
	          outputConfiguration = ((OutputConfigurationAdapter) adapter).getOutputConfigurationName();
	          break;
	      if (outputConfiguration == YourOutputProvider.DEFAULT) {
	        this.internalDoGenerate(obj, fsa); // <= GOTO INFERRER
	      } else if (outputConfiguration == YourOutputProvider.OTHER) {
	        generator.doGenerate(input, fsa); // <= GOTO IGENERATOR
here you make the switch to your Inferrer & Igenerator
- configure your RuntimeModule
	public void configure(Binder binder) {
		super.configure(binder);
		binder.bind(IOutputConfigurationProvider.class)
        .to(YourOutputProvider.class)
        .in(Singleton.class);
	public Class<? extends IGenerator> bindIGenerator() {
		return OutputConfigurationAwaredGenerator.class;
[Updated on: Thu, 09 May 2013 04:19] by Moderator
Re: Using both AbstractModelInferrer and IGenerator implementations [message #1057859 is a reply to message #1057834] Thu, 09 May 2013 07:31 Go to previous messageGo to next message
Oh, I think because in your case you needed to generate differently
according to specific inferred elements (I had missed that part)... in
my case I just wanted to generate also xml besides Java code so I did
not need to specify different output configurations right in the inferrer...
On 05/09/2013 10:03 AM, Dirk Deyne wrote:
> Lorenzo: Here's how I use IGenerator & Inferrer together .. it was not
> that easy
> @Override
> - create an Adapter
> @Override
> @Override
> return null;
> @Override
> @Override
> return false;
> IFileSystemAccess,
> this.fsa = fsa;
> @Override
> @Override
> @Override
> @Override
> @Override
> @Override
> .initializeLater([ ....
> .initializeLater([ // nothing to do
> @Override
> break;
> @Override
> @Override
icon14.gif  Re: Using both AbstractModelInferrer and IGenerator implementations [message #1057880 is a reply to message #1057834] Thu, 09 May 2013 10:28 Go to previous message
Great answer Dirk. It works like a champ.
Thanks for all other answer. They helped me a lot to understand better the code generation process.
Sincerely,
Previous Topic:Grammar ambiguity only when using external references
Next Topic:Redefining imported name
Current Time: Sun Jul 20 08:12:29 EDT 2025
Powered by FUDForum. Page generated in 0.05102 seconds
