Home » Archived » Buckminster » Strange behavior with cspex file
Strange behavior with cspex file [message #1053812] Tue, 07 May 2013 12:43 Go to next message
Hi *,
I noticed a strange behavior with my attached cspex file.
If I copy the file to any eclipse bundle directly to the root folder, than buckminster is claiming about 'No component named [...] is known to Buckminster'.
For example, if I have a eclipse bundle my.eclipsebundle.buckminster and I copy the cspex file myconfig.cspex to the root folder of that bundle, then I get following message from buckminster:
Project refresh on my.eclipsebundle.buckminster failed: No component named my.eclipsebundle.buckminster is known to Buckminster
If I copy the file in a subfolder of that bundle, buckminster is claiming about nothing.
Is something wrong with my cspex file? Or is this a bug?
This happens in the IDE and also on my Jenkins build. In the IDE I'm using version 3.7, on my Jenkins version 4.2. So it seems to be quite version independent.
Raphael
Re: Strange behavior with cspex file [message #1057724 is a reply to message #1053812] Wed, 08 May 2013 09:21 Go to previous message
As far as I know, a CSpec extension file must be in the root folder of the project, and named buckminster.cspex, which explains why you don't get an error when the cspex is in a subfolder.
Is myconfig.cspex still in the original project? Is that the exact name?
Previous Topic:Write-back to repositories?
Next Topic:Buckminster script execution stops after 'build -c'
Current Time: Sun Jul 20 08:17:33 EDT 2025
Powered by FUDForum. Page generated in 0.03299 seconds
