Home » Archived » BIRT » Adding sort to Property Editor(How can I add Sort to Property Editor)
Adding sort to Property Editor [message #1053738] Tue, 07 May 2013 08:42 Go to next message
I'm new to BIRT. In the instructions and book it says to Open the
Property Editor and select sort. It shows the choices as:
Properties|Binding|Group|Map|Sort|Filters
I only have:
Property Editor | Problems
Property | Binding | Map |Highlights
How can I get the Sort and Group headings to show?
[Updated on: Tue, 07 May 2013 10:57] by Moderator
Re: Adding sort to Property Editor [message #1053854 is a reply to message #1053738] Tue, 07 May 2013 17:29 Go to previous message
Are you selecting the table before clicking on the property editor? Hover over the table, a table image should appear in the lower left, click on that > click property editor > groups. You should see properties, binding, groups, map, highlights, sorting, and filters.
Previous Topic:Creating a Stacked Bar chart using a script
Next Topic:BIRT with Ruby on Rails
Current Time: Sun Jul 20 12:40:31 EDT 2025
Powered by FUDForum. Page generated in 0.06082 seconds
