Home » Modeling » TMF (Xtext) » Formating with Xtend
Formating with Xtend [message #1053646] Tue, 07 May 2013 02:46 Go to next message
Hi all,
I update Xtext framework .but I have problem.I written pure java code previosly but now Formatting class is a xtend class.
My code for formating :
public class FilesystemFormatter extends AbstractDeclarativeFormatter {
// It's usually a good idea to activate the following three statements.
// They will add and preserve newlines around comments
//		c.setLinewrap(0, 1, 2).before(getGrammarAccess().getSL_COMMENTRule());
//		c.setLinewrap(0, 1, 2).before(getGrammarAccess().getML_COMMENTRule());
//	c.setLinewrap(0, 1, 1).after(getGrammarAccess().getML_COMMENTRule());
		protected void configureFormatting(FormattingConfig c) {
			FilesystemGrammarAccess f = (FilesystemGrammarAccess) getGrammarAccess();
			c.setAutoLinewrap(120);
			//c.setLinewrap(1).after(f.getFileAccess().getSemicolonKeyword_0_2_1());
			//c.setWrappedLineIndentation(f.getFileAccess().getSemicolonKeyword_0_2_1()) ;
			c.setLinewrap(1, 2, 3).around(f.getFilesystemRule());
			c.setLinewrap(1, 2, 3).around(f.getDriveRule());
			c.setLinewrap(1, 1, 2).around(f.getSyncRule());
			c.setLinewrap(1,1,2).around(f.getObjectRule());
			List<Pair<Keyword,Keyword>> pairs = f.findKeywordPairs("{", "}");
			for (Pair<Keyword, Keyword> pair : pairs) {
				c.setIndentation(pair.getFirst(), pair.getSecond());
			c.setLinewrap(0, 1, 2).before(f.getSL_COMMENTRule());
			c.setLinewrap(0, 1, 2).before(f.getML_COMMENTRule());
			c.setLinewrap(0, 1, 1).after(f.getML_COMMENTRule());
My problem :
FilesystemGrammarAccess f = (FilesystemGrammarAccess) getGrammarAccess(); is not defined in the xtend class.
I want to change this code with Xtend code Sad
Re: Formating with Xtend [message #1053648 is a reply to message #1053646] Tue, 07 May 2013 03:05 Go to previous messageGo to next message
casts are written like this in Xtend:
val FilesystemGrammarAccces f = getGrammarAccess() as
FileSystemGrammarAccess
or even shorter
val f = grammarAccess as FileSystemGrammarAccess
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Am 07.05.13 08:46, schrieb junior developer:
> Hi all,
> @Override
> getGrammarAccess();
> My problem :
> I want to change this code with Xtend code :(
Re: Formating with Xtend [message #1053664 is a reply to message #1053648] Tue, 07 May 2013 04:08 Go to previous messageGo to next message
Hi Sebastian,
I want to use my code that is written in the previosly version, in the Xtext's new version .
I have been written pure java code in the previous Xtext version,now I want to use these code in new Xtext version.is it possible ? because every generated class (such as for Validation,Formating) is a Xtend class .I want to use new version but I want to write pure java code .
must I write xtend code for this version?
Re: Formating with Xtend [message #1053665 is a reply to message #1053664] Tue, 07 May 2013 04:09 Go to previous messageGo to next message
in Xtend you cast as
val f = grammarAccess as FilesystemGrammarAccess
Re: Formating with Xtend [message #1053666 is a reply to message #1053665] Tue, 07 May 2013 04:11 Go to previous messageGo to next message
P.S:you can switch back to java for most components shitching the flag in the workflow
var generateXtendStub = false
Re: Formating with Xtend [message #1053671 is a reply to message #1053666] Tue, 07 May 2013 04:23 Go to previous messageGo to next message
Hi Christian,
Thank you for your help .
I try var generateXtendStub = false ,but MyDslValidator is still Xtend .can I change this class with java class?
Re: Formating with Xtend [message #1053674 is a reply to message #1053671] Tue, 07 May 2013 04:29 Go to previous messageGo to next message
Hi, this is a bug/non feature
you may use validation.Java..Valid...Fragment in the workflow instead
Re: Formating with Xtend [message #1053677 is a reply to message #1053674] Tue, 07 May 2013 04:35 Go to previous messageGo to next message
You can also just create the Java class (MyDslValidator) there manually and delete the Xtend file.
Same for the generator.
[Updated on: Tue, 07 May 2013 04:37] by Moderator
Re: Formating with Xtend [message #1053684 is a reply to message #1053674] Tue, 07 May 2013 04:43 Go to previous messageGo to next message
Hi Christian ,
How can I use fragment in the workflow .How can I use MyDSLjavaValidator.java class ?
sorry I don t understand
Christian Dietrich wrote on Tue, 07 May 2013 04:29
Re: Formating with Xtend [message #1053686 is a reply to message #1053684] Tue, 07 May 2013 04:44 Go to previous messageGo to next message
Simply replace the other validation fragment with it ?!?
Re: Formating with Xtend [message #1053688 is a reply to message #1053677] Tue, 07 May 2013 04:48 Go to previous messageGo to next message
Hi Claudio ,
I create a MydslValidator.java but I regenerate the grammar ,occur MydslValidator.xtend
again
Claudio Heeg wrote on Tue, 07 May 2013 04:35
Re: Formating with Xtend [message #1053711 is a reply to message #1053688] Tue, 07 May 2013 06:57 Go to previous messageGo to next message
Hi Christian,
My problem is solved with created java class.
Thanks a lots ,
Re: Formating with Xtend [message #1053729 is a reply to message #1053664] Tue, 07 May 2013 08:10 Go to previous messageGo to next message
In the mwe2 workflow, set the variable generateXtendStub to false and
replace the fragments
validation.ValidatorFragment
with
validation.JavaValidatorFragment
and
contentAssist.ContentAssistFragment
with
contentAssist.JavaBasedContentAssistFragment
This will restore the generation of Java stubs and their bindings.
Am 07.05.13 10:08, schrieb junior developer:
> Hi Sebastian,
Re: Formating with Xtend [message #1053821 is a reply to message #1053729] Tue, 07 May 2013 13:36 Go to previous message
Hi Jan,
My problem is solved with replace the fragment .but Do I encounter any problems at a later time.thank you for help,
BEst regrads
Jan Kohnlein wrote on Tue, 07 May 2013 08:10
with
and
with
> Hi Sebastian,
Previous Topic:strange behavior of XImportSection
Next Topic:How can I infer jvm type which has super type which is derived from part of domain model
Current Time: Sun Jul 20 14:45:28 EDT 2025
Powered by FUDForum. Page generated in 0.06325 seconds
