Home » Modeling » GMF (Graphical Modeling Framework) » GMF compare
GMF compare [message #1051399] Sun, 28 April 2013 14:35 Go to next message
I'm making a graphical editor having AS-IS and TO-BE models. It would thus be very useful to be able to graphically compare two GMF diagrams.
I found this online on this topic: http://www.jonmedia.net/en/publications/master-thesis
but i can't implement it. I get import errors in the java classes of the org.eclipse.emf.compare.gmf plugin, and in the runtime, it creates a lot of error when trying to use the GMF compare function. I don't really know either how to really install this plugin, which is now just imported from the CVS..
Does anybody have more info on this topic of graphically comparing GMF models??
Simon
Re: GMF compare [message #1052570 is a reply to message #1051399] Tue, 30 April 2013 04:50 Go to previous messageGo to next message
specifing the errors that you get a bit further would help a lot.
Ralph
Re: GMF compare [message #1052584 is a reply to message #1052570] Tue, 30 April 2013 05:10 Go to previous messageGo to next message
Ok Ralph, i added some screenshots to explain my problem:
1. I import the folders from the CVS in the first post and get two unresolved errors, seen in the first attached image.
index.php/fa/14569/0/
2. I go to the runtime preferences->general->content types->GMF compare, and add the domain and diagram extensions of the files i which to compare. (second attached image)
index.php/fa/14570/0/
3. If i choose compare->local history, an empty compare screen appears with a given error (third attached image)
index.php/fa/14571/0/
The details of the loop exception are given in the last two images..
index.php/fa/14572/0/
index.php/fa/14573/0/
regards,
Simon
Re: GMF compare [message #1053497 is a reply to message #1052584] Mon, 06 May 2013 05:45 Go to previous messageGo to next message
can anyone help me with this?
Re: GMF compare [message #1053515 is a reply to message #1053497] Mon, 06 May 2013 07:06 Go to previous messageGo to next message
I would suggent looking at the following project. It has GMF support and is actively mantained -
http://wiki.eclipse.org/EMF_Compare/User_Guide#Graphical_Comparison
http://www.eclipse.org/emf/compare/doc/features/videos/EcoreTools-v2/EMFCompareEcoreTools.html
Re: GMF compare [message #1053560 is a reply to message #1051399] Mon, 06 May 2013 10:24 Go to previous messageGo to next message
Ok,
I am using Eclipse 4.2.2 Juno with EMF 2.8.3.
I first tried installing EMF Compare 2.1, but after the install, I still wasn't able to graphically compare two files.
I then instlaled EMF Compare 1.3.3, and I can now graphically compare two .ecorediag files, but it's still not possible to graphically compare two examples in runtime..
[Updated on: Mon, 06 May 2013 10:24] by Moderator
Re: GMF compare [message #1053571 is a reply to message #1053560] Mon, 06 May 2013 10:53 Go to previous messageGo to next message
I tried it with Eclipse 3.7.2 Indigo, same result,.
I don't know if i have to change anything in the preferences view, but if I now try to compare two examples in the runtime, i only get the 'visualization of structural differences', no the visualization of graphical differences...
Re: GMF compare [message #1053748 is a reply to message #1053571] Tue, 07 May 2013 09:31 Go to previous message
maybe you will get better help about this in the forum of EMF Compare.
Ralph
Previous Topic:Condition in Figure name
Next Topic:Create a child node when creating the parent
Current Time: Sun Jul 20 07:14:47 EDT 2025
Powered by FUDForum. Page generated in 0.04730 seconds
