Home » Eclipse Projects » Eclipse Platform » actions form contextmenu executed twice
actions form contextmenu executed twice [message #1053466] Mon, 06 May 2013 03:01 Go to next message
Hello everyone,
one of our users das a strange problem using eclipse: when using something from the context menu, every action is executed twice
(e.g. copy and paste inserts twice, easy explore opens 2 windows etc.)
This started last monday and we have no idea why. A newer version of eclipse or different versions of java do not help.
Any ideas?
Peter
Re: actions form contextmenu executed twice [message #1059345 is a reply to message #1053466] Fri, 17 May 2013 11:16 Go to previous messageGo to next message
I have exactly the same problem. I have tried running Eclipse Indigo and Juno. I have tried 32bit and 64bit versions. I have tried running Java 6 and Java 7. I have tried using the USB mouse and the touchpad when selecting a menu item. Always the same behavior. It started when i reinstalled Eclipse after switching to Windows 7.
The problem only seems to occur when selecting a menu item using the mouse/touchpad, not if using the keyboard.
I run a similar setup on another computer at home - running Windows 8 - without any problems.
I am very thankful if someone has a solution to this problem. It is truly irritating!
Re: actions form contextmenu executed twice [message #1059712 is a reply to message #1059345] Tue, 21 May 2013 06:27 Go to previous messageGo to next message
We tested this here as well, and see the same effect that this is jsut occuring when the mouse is used.
Peter
Re: actions form contextmenu executed twice [message #1060754 is a reply to message #1059712] Tue, 28 May 2013 07:18 Go to previous messageGo to next message
The problem seems to be nView, and the solutoin is to disable it
see: stackoverflow.com/questions/16470866/eclipse-dialogs-open-twice-when-clicked-with-mouse
Re: actions form contextmenu executed twice [message #1060772 is a reply to message #1060754] Tue, 28 May 2013 08:05 Go to previous message
Ah, problem solved Smile Disabling nView was the solution!
Thanks Peter!
Previous Topic:How to detect that code is running in Development environment or in generic Eclipse using Plugins?
Next Topic:ComboViewer catching "drop down" event
Current Time: Sat Jul 19 22:53:01 EDT 2025
Powered by FUDForum. Page generated in 0.05210 seconds
