Home » Modeling » TMF (Xtext) » annotate a parameter in method(annotations)
annotate a parameter in method [message #1053092] Thu, 02 May 2013 08:07 Go to next message
I'm using a AbstractModelInferrer to generate java-code from dsl
I want to insert a method to the generated class like:
  @MyFoo
  public void foo(@MyBar(value="foo") Bar bar){
    this.bar = bar;
But I just cannot get the @MyBar(value="foo") inserted Confused
here is a part of my FooBarInferrer.xtend
class FooBarInferrer extends AbstractModelInferrer {
  @Inject extension JvmTypesBuilder
  def dispatch void infer(Foo foo, IJvmDeclaredTypeAcceptor acceptor, boolean isPreIndexingPhase) {
  acceptor.accept(foo.toClass(foo.name)).initializeLater([
     members+= foo.fooMethod
  def fooMethod(Foo foo){
       	foo.toMethod(
   	"foo",
  	foo.newTypeRef(Void::TYPE),
	   parameters += toParameter(form.bar.simpleName.toFirstLower,form.bar)
           // how do I add annotation  @MyBar(value="foo") to parameters!?
           body=[append('''this.bar = bar;''')]
	   annotations.add(form.toAnnotation("foo.annotation.MyFoo"))
note that anotation has a parameter too value=bar
Re: annotate a parameter in method [message #1053140 is a reply to message #1053092] Thu, 02 May 2013 12:10 Go to previous messageGo to next message
val p =toParameter(form.bar.simpleName.toFirstLower,form.bar)
p.annotations += ....
parameters += p
Re: annotate a parameter in method [message #1053141 is a reply to message #1053092] Thu, 02 May 2013 12:15 Go to previous messageGo to next message
solved
       	foo.toMethod(
   	"foo",
	   var fooPar = toParameter(foo.bar.simpleName.toFirstLower,form.bar)
           foorPar.annotations.add(foo.toAnnotation("foo.annotation.MyBar","foo"))
           parameters += fooPar
	   annotations.add(foo.toAnnotation("foo.annotation.MyFoo"))
thx Christian
before I tried
 foorPar.annotations.add(toAnnotation("foo.annotation.MyBar","foo"))
and
 foorPar.annotations.add(fooPar.toAnnotation("foo.annotation.MyBar","foo"))
still learning Embarrassed
[Updated on: Thu, 02 May 2013 12:24] by Moderator
Re: annotate a parameter in method [message #1053142 is a reply to message #1053140] Thu, 02 May 2013 12:18 Go to previous messageGo to next message
or equivalently, but a slightly more concise
parameters += toParameter(form.bar.simpleName.toFirstLower,form.bar) => [
   annotations += ....
Re: annotate a parameter in method [message #1053144 is a reply to message #1053142] Thu, 02 May 2013 12:29 Go to previous messageGo to next message
Ok Thomas I see...
Need to work on my xtend-skills
Re: annotate a parameter in method [message #1053151 is a reply to message #1053144] Thu, 02 May 2013 14:08 Go to previous messageGo to next message
next problem ...
foo.toAnnotation("foo.annotation.MyBar","foo") becomes @MyBar("foo")
needs to be
@MyBar(value="foo")
Re: annotate a parameter in method [message #1053179 is a reply to message #1053151] Thu, 02 May 2013 17:30 Go to previous messageGo to next message
isnt that the same?
Re: annotate a parameter in method [message #1053180 is a reply to message #1053179] Thu, 02 May 2013 17:41 Go to previous messageGo to next message
Btw you may digg into
org.eclipse.xtext.xbase.compiler.JvmModelGenerator.toJava(JvmAnnotationValue, ITreeAppendable, GeneratorConfig)
org.eclipse.xtext.xbase.jvmmodel.JvmTypesBuilder.toAnnotation(EObject, String, Object)
and create your own toAnnotation
that sets an JvmAnnotationValue.operation
Re: annotate a parameter in method [message #1053245 is a reply to message #1053180] Fri, 03 May 2013 07:18 Go to previous messageGo to next message
found out that adding key-value pairs to an Annotation is not that obvious.
but here is an intresting post that helps a lot: http://www.eclipse.org/forums/index.php/t/300722/
Re: annotate a parameter in method [message #1053250 is a reply to message #1053179] Fri, 03 May 2013 07:42 Go to previous messageGo to next message
Christian Dietrich wrote on Thu, 02 May 2013 17:30
isnt that the same?
Yes, it is the same... in this simplified example.
I'm learning in small steps
But I will eventualy need a convertion to something like
@Column(name="T_NAME", updatable=false)
and
@RequestMapping(value="/welcome", method = RequestMethod.GET)
I will surely have a look at
[Updated on: Fri, 03 May 2013 07:43] by Moderator
Re: annotate a parameter in method [message #1053257 is a reply to message #1053250] Fri, 03 May 2013 08:10 Go to previous messageGo to next message
Actually, a few weeks ago I digged through the api for solving similar problems, and finally came up with my own utilities.
class Utils {
	@Inject extension TypesFactory
	def addStringValue(JvmAnnotationReference annoRef, String name, String value) {
		val op = annoRef.findOperationByName(name)
		annoRef.values += createJvmStringAnnotationValue => [
			operation = op
			values += value
		annoRef
	// Similar methods (left to the reader as an exercise ;-) )
	//   addIntValue(JvmAnnotationReference annoRef, String name, int value)
	//   addBooleanValue(JvmAnnotationReference annoRef, String name, boolean value)
	//   addAnnotationValue(JvmAnnotationReference annoRef, String name, JvmAnnotationReference value)
	//   addEnumValue(JvmAnnotationReference annoRef, EObject context, String name, Enum<?> value)
	//   addTypeValue(JvmAnnotationReference annoRef, EObject context, String name, Class<?> value)
	def private findOperationByName(JvmAnnotationReference annoRef, String name) {
		annoRef.annotation.declaredOperations.findFirst[it.simpleName == name]
For example, for building the annotation
@NamedQuery(name="Printer.findAll", query="SELECT x FROM Printer AS x")
I can write
    @Inject extension Utils
    val a = e.toAnnotation("javax.persistence.NamedQuery")
        .addStringValue("name", "Printer.findAll")
        .addStringValue("query", "SELECT x FROM Printer AS x")
Re: annotate a parameter in method [message #1053258 is a reply to message #1053257] Fri, 03 May 2013 08:12 Go to previous messageGo to next message
yes this is what i meant with digging
icon14.gif  Re: annotate a parameter in method [message #1053288 is a reply to message #1053257] Fri, 03 May 2013 11:06 Go to previous messageGo to next message
Thomas Fritsch wrote on Fri, 03 May 2013 08:10
does the job perfectly !
thx Thomas.
Re: annotate a parameter in method [message #1421357 is a reply to message #1053288] Thu, 11 September 2014 04:58 Go to previous messageGo to next message
To add an annotation attribute that has a list of String values, the following method will do:
def addListOfStringValues(JvmAnnotationReference annoRef, String name, List<String> newValues) {
		operation = op
		for(value: newValues) {
			values += value
	annoRef
Re: annotate a parameter in method [message #1421429 is a reply to message #1421357] Thu, 11 September 2014 06:58 Go to previous message
Hi Mohamed,
you can make your method even easier to use with varargs parameter:
def addStringValues(JvmAnnotationReference annoRef, String name, String... newValues) {
		operation = op
		values += newValues
	annoRef
And Xtend's += operator is smart enough to know how to add the array String[] newValues to the List<String> values.
Previous Topic:Annotation with Enum values
Next Topic:[solved] Accessing types and their properties from another file (with same grammar)
Current Time: Sun Jul 20 04:11:58 EDT 2025
Powered by FUDForum. Page generated in 0.05158 seconds
