Home » Language IDEs » PHP Development Tools (PDT) » Eclipse PDT and XDebug 2.2.2(xdebug, eclipse PDT, PHP)
Eclipse PDT and XDebug 2.2.2 [message #1053000] Wed, 01 May 2013 16:30 Go to next message
I'm trying to configure eclipse PDT with xdebug, in order to be able to debug my PHP code i create for Joomla/Prestashop and other CMS.
i must say that tutorials i found till now are really old and they do not reflect the current situation in terms of options, versions or feature and settings.
i tried:
http://docs.joomla.org/Configuring_Eclipse_and_Xdebug
but i wasn't able to make it run properly..
in fact even if i have break points eclipse do not stop on them.
i check if i didn't do something stupid with xdebug and tried with another IDE like PHPStorm and it works well...
so something must be wrong with eclipse settings.
Could you tell me where can i find a new tutorials or necessary information to be able to setup it correctly ?
thx.
thx.
Re: Eclipse PDT and XDebug 2.2.2 [message #1053074 is a reply to message #1053000] Thu, 02 May 2013 06:35 Go to previous messageGo to next message
I still working on this issue and i have maybe a stupid question...
whatever i use eclipse or PHPStorm it requests a PHP interpreter. But how can i set the interpreter, when the exe files are on my remote system and not on local development computer ?
Re: Eclipse PDT and XDebug 2.2.2 [message #1053091 is a reply to message #1053074] Thu, 02 May 2013 07:57 Go to previous messageGo to next message
even if the tutorial available on http://robsnotebook.com/php_debugger_pdt_xdebug does not work. Sad
i would like to know if it's really possible to debug PHP of my remote system from my windows client.
i saw a lot of blogs/tutorials about it but all have been written before PDT3.0 and the latest i found was from 2010 Sad
if it's not possible in this case i will move to another IDE Sad
[Updated on: Thu, 02 May 2013 08:07] by Moderator
Re: Eclipse PDT and XDebug 2.2.2 [message #1053137 is a reply to message #1053091] Thu, 02 May 2013 11:42 Go to previous messageGo to next message
ok, finally it works with chrome and xdebug help plugins.
Re: Eclipse PDT and XDebug 2.2.2 [message #1057787 is a reply to message #1053137] Wed, 08 May 2013 13:57 Go to previous messageGo to next message
Hi Roger,
I had the same issue and I still have the issue. I set up a WAMP server with some php files in it which are used as webservice rather than a web page. I tried to debug the script from browser but it never stops on the breakpoints,(I have the break at first line option and also have some breakpoints). I am able to debug as a php script though but it would be useful for me only if I can debug it when using from the browser. Can you let me know what you have changed to make the breakpoints work from the chrome browser?
Re: Eclipse PDT and XDebug 2.2.2 [message #1067622 is a reply to message #1057787] Tue, 09 July 2013 12:13 Go to previous messageGo to next message
Hi Testr T,
I'm having the same problem (see my post of today). Are you any further on this subject ?
Re: Eclipse PDT and XDebug 2.2.2 [message #1070625 is a reply to message #1067622] Thu, 18 July 2013 06:37 Go to previous messageGo to next message
Same problem here. It seems to be a bug in Eclipse PDT because neither debugger stops at any breakpoint. there are several breakpoints and exceptions but it just displays the final results without pausing anywhere.
[OT]Re: Eclipse PDT and XDebug 2.2.2 [message #1071562 is a reply to message #1070625] Sat, 20 July 2013 09:19 Go to previous message
suchal riaz wrote on Thu, 18 July 2013 06:37
According to Zend and Xdebug Debuggers does not stop at the breakpoints., you seem to have a different problem.
In case you described, ZendDebugger works somehow, but Xdebug does not work for remote debugging.
Previous Topic:Source Format uses tabs instead of spaces
Next Topic:Eclipse PDT Auto-Complete doesn't suggest Class methods
Current Time: Sun Jul 20 18:09:31 EDT 2025
Powered by FUDForum. Page generated in 0.05051 seconds
