Home » Archived » BIRT » "Can not open the file" exception while opening the report with 2.0RC
"Can not open the file" exception while opening the report with 2.0RC [message #104537] Wed, 04 January 2006 21:23 Go to next message
There is one .rptdesign file that new 2.0RC could not open and gives the
following error :
org.eclipse.ui.PartInitException: Cannot open the file.
at
org.eclipse.birt.report.designer.internal.ui.editors.parts.A bstractMultiPageLayoutEditor.init(AbstractMultiPageLayoutEdi tor.java:730)
at org.eclipse.ui.internal.EditorManager.createSite(EditorManag er.java:773)
at
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:572)
at
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:365)
at
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:552)
at
org.eclipse.ui.internal.EditorAreaHelper.setVisibleEditor(Ed itorAreaHelper.java:258)
at
org.eclipse.ui.internal.EditorManager.setVisibleEditor(Edito rManager.java:1216)
at org.eclipse.ui.internal.EditorManager$5.run(EditorManager.ja va:944)
at
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1044)
at org.eclipse.core.runtime.Platform.run(Platform.java:783)
at
org.eclipse.ui.internal.EditorManager.restoreState(EditorMan ager.java:939)
at
org.eclipse.ui.internal.WorkbenchPage.restoreState(Workbench Page.java:2535)
at
org.eclipse.ui.internal.WorkbenchWindow.restoreState(Workben chWindow.java:1819)
at org.eclipse.ui.internal.Workbench.doRestoreState(Workbench.j ava:2566)
at org.eclipse.ui.internal.Workbench.access$14(Workbench.java:2 515)
at org.eclipse.ui.internal.Workbench$19.run(Workbench.java:1514 )
at org.eclipse.ui.internal.Workbench$16.run(Workbench.java:1263 )
at
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:346)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:291)
at
org.eclipse.jface.dialogs.ProgressMonitorDialog.run(Progress MonitorDialog.java:447)
at
org.eclipse.ui.internal.Workbench.runStartupWithProgress(Wor kbench.java:1258)
at org.eclipse.ui.internal.Workbench.restoreState(Workbench.jav a:1512)
at org.eclipse.ui.internal.Workbench.access$12(Workbench.java:1 491)
at org.eclipse.ui.internal.Workbench$17.run(Workbench.java:1374 )
at
at org.eclipse.ui.internal.Workbench.restoreState(Workbench.jav a:1318)
at
org.eclipse.ui.internal.WorkbenchConfigurer.restoreState(Wor kbenchConfigurer.java:183)
at
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:700)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:1034)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1636)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
This does not happen with 2.0M3.
Attached is the .rptdesign file, please help. Thanks.
Re: "Can not open the file" exception while opening the report with 2.0RC [message #105212 is a reply to message #104537] Thu, 05 January 2006 22:02 Go to previous messageGo to next message
Could anyone comment on this please ? Thanks.
"Report Guy" <jamestanms@hotmail.com> wrote in message
news:dpi00f$1q1$1@utils.eclipse.org...
> following error :
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: "Can not open the file" exception while opening the report with 2.0RC [message #105227 is a reply to message #104537] Thu, 05 January 2006 22:12 Go to previous message
Attached are the screen shots in my eclipse. Strange thing is I am able to
open some other .rptdesign files but not this one.
Thanks.
> following error :
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Previous Topic:BIRT RC run from source exception problem.
Next Topic:About RunReport Class
Current Time: Sun Jul 20 14:53:12 EDT 2025
Powered by FUDForum. Page generated in 0.24264 seconds
