Home » Modeling » M2T (model-to-text transformation) » [Acceleo]Acceleo does not see metamodels located in targetplatform
[Acceleo]Acceleo does not see metamodels located in targetplatform [message #1052031] Mon, 29 April 2013 10:35 Go to next message
a similar bugs was reported here some times ago :
http://forge.ow2.org/tracker/index.php?func=detail&aid=311798&group_id=273&atid=350389
I have the same problem, using Acceleo 3.1. I wonder if this has been resolved since ?
Re: [Acceleo]Acceleo does not see metamodels located in targetplatform [message #1052183 is a reply to message #1052031] Mon, 29 April 2013 15:00 Go to previous messageGo to next message
3.4 is much better in this respect.
Ed Willink
On 29/04/2013 15:35, Stephane Bouchet wrote:
> resolved since ?
Re: [Acceleo]Acceleo does not see metamodels located in targetplatform [message #1052633 is a reply to message #1052183] Tue, 30 April 2013 06:28 Go to previous messageGo to next message
hi Ed, using the latest 3.4 M7 do not resolve my problem. i have a metamodel and an acceleo services plugin in the targetplatform, the ecore is present and acceleo still cannot resolve it during compilation.
Re: [Acceleo]Acceleo does not see metamodels located in targetplatform [message #1052847 is a reply to message #1052633] Tue, 30 April 2013 12:55 Go to previous messageGo to next message
Your original reference was to a 2008 bug report - totally irrelevant by
now.
Have you followed the tutorials and FAQs since your problem seems to be
rather basic.
Ed Willink
Re: [Acceleo]Acceleo does not see metamodels located in targetplatform [message #1053053 is a reply to message #1052847] Thu, 02 May 2013 05:06 Go to previous messageGo to next message
Hi Ed,
I'm using Acceleo since 2007.
My configuration is quite simple : my Target Platform contains Acceleo 3.1, the metamodel and a plugin with some acceleo services. my developement environment has acceleo 3.4 M7 installed.
The metamodel and the services cannot be found by acceleo when it compiles. I got a workaround ( getting the metamodel and the plugin in my workspace ), but i wonder if the community had this problem, too.
Re: [Acceleo]Acceleo does not see metamodels located in targetplatform [message #1053098 is a reply to message #1053053] Thu, 02 May 2013 08:43 Go to previous messageGo to next message
Hi Stephane
If you search the Acceleo Bugzillas raised by me you will find a number
of issues related to metamodel resolution and a discussion on how the
prevailing algorithms are helpful rather than conforming to a sound
design. I have considerable problems only some of which I am able to
workaround.
It is difficult to categorize user problems as newbie failures to comply
with configuration requirements or more advanced deficiencies in the
heuristics.
Ed Willink
On 02/05/2013 10:06, Stephane Bouchet wrote:
> Hi Ed,
> developement environment has acceleo 3.4 M7 installed. The metamodel
Re: [Acceleo]Acceleo does not see metamodels located in targetplatform [message #1053108 is a reply to message #1053098] Thu, 02 May 2013 09:34 Go to previous messageGo to next message
Hi Ed,
sorry to bother the community with my newbies questions, i thought the acceleo developers can help me with this. I'll contact them in another way if they can't.
i'll have a look to your 105 reported bugs against acceleo and cc myself to those i found interresting to have them fixed.
Re: [Acceleo]Acceleo does not see metamodels located in targetplatform [message #1058278 is a reply to message #1053108] Mon, 13 May 2013 08:50 Go to previous messageGo to next message
In order to access metamodels, Acceleo uses the global package registry managed by EMF and we have our own package registry where the metamodels of the workspace are registered. Since we are here talking about metamodels in the target platform, Acceleo is not doing anything specific to support them. I believe that Ed Merks has worked on improving the situation in the bug 220218 so it may appear that Acceleo 3.4 improve the situation but since we are only relying on the standard behavior of EMF here (and we have always been for that), any credit should go to Ed Merks if things are improved on this subject with Kepler.
Stephane Begaudeau, Obeo
Twitter: @sbegaudeau
Google+: +stephane.begaudeau
Blog: http://stephanebegaudeau.tumblr.com | Eclipse Java Development Tools Tips and Tricks
Re: [Acceleo]Acceleo does not see metamodels located in targetplatform [message #1059247 is a reply to message #1058278] Wed, 15 May 2013 06:52 Go to previous message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=220218 is indeed a major
improvement, but
EMF used to provide the registries to resolve URIs; they were not
populated in standalone mode.
The bug fix provides the ability to populate them standalone, but
Applications must invoke the EcorePlugin.ExtensionProcessor.process() to
perform that population, so without a code change in Acceleo, or user
code, the bug fix is useless.
The bug fix does a nice job of scanning the classpath so that a
resolution of each URI is available. However IIRC you must add
additional URI mappings to make platform:/resource and platform:/plugin
interchangeable. If you want to go further and make physical and ns URIs
interchangeable and so defeat metamodel schizophrenia, you need the
extra redirecting package registry entries that OCL's ProjectMap provides.
Ed Willink
On 13/05/2013 13:50, Stephane Begaudeau wrote:
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=220218 so it may appear
> Regards,
> Twitter: http://twitter.com/#!/sbegaudeau
> Google+: https://plus.google.com/u/0/105625286543794908607/
> http://stephanebegaudeau.tumblr.com/post/37318392815/eclipse-java-development-tools
Previous Topic:[acceleo] loading EMF resource with a folder URI
Next Topic:[Acceleo] NullPointerException during Tycho Build
Current Time: Sat Jul 19 10:38:36 EDT 2025
Powered by FUDForum. Page generated in 0.05538 seconds
