Home » Archived » Buckminster » eclipse.build does not generate class files when using Buckminster 4.2 on Jenkins
eclipse.build does not generate class files when using Buckminster 4.2 on Jenkins [message #1046297] |
Sun, 21 April 2013 14:13  |
I've encountered some strange behavior with Buckminster 4.2 on Jenkins.
Buckminster is provisioned from
http://download.eclipse.org/tools/buckminster/headless-4.2/, with below
features.
Features:
org.eclipse.buckminster.core.headless.feature (%featureName)
org.eclipse.buckminster.pde.headless.feature (%featureName)
org.eclipse.buckminster.subversive.headless.feature (%featureName)
org.eclipse.buckminster.subversive.svnkit16.headless.feature
(%featureName)
The site.p2 action completes ok and without errors.
However, no class files are generated from eclipse.build!
init actor: eclipse.build[g.o.p.c:osgi.bundle$1.2.0#eclipse.build]
INFO: [start g.o.p.c:osgi.bundle$1.2.0#eclipse.build]
buckminster.component=g.o.p.c
workspace.root=/var/lib/jenkins/workspace/PG
buckminster.temp=/var/lib/jenkins/workspace/PG/buckminster.temp/g.o.p.c_1.2.0-osgi.bundle/temp
buckminster.home=/var/lib/jenkins/workspace/PG/g.o.p.c/
buckminster.output=/var/lib/jenkins/workspace/PG/buckminster.output/g.o.p.c_1.2.0-osgi.bundle
localhost=scm
generator.buildTimestamp.format=2013-04-21T15:18:01.213+0000
buckminster.component.type=osgi.bundle
buckminster.version=1.2.0
target.nl=en_US
eclipse.home=/var/lib/jenkins/tools/hudson.plugins.buckminster.BuckminsterInstallation/Buckminster_4.2/buckminster
INFO: [end g.o.p.c:osgi.bundle$1.2.0#eclipse.build]
Naturally, the bundle jar does not contain any class files either.
init actor: copyTargetFragments[g.o.p.c:osgi.bundle$1.2.0#target.fragments]
Action g.o.p.c:osgi.bundle$1.2.0#target.fragments using 'up to date'
policy ACTOR: Product is up to date
Action g.o.p.c:osgi.bundle$1.2.0#bundle.jar using 'up to date' policy
COUNT: Rebuild needed: File count(0) < expected(1)
init actor: ant[g.o.p.c:osgi.bundle$1.2.0#bundle.jar]
buildFileId=buckminster.pdetasks
targets=create.bundle.jar
INFO: [start g.o.p.c:osgi.bundle$1.2.0#bundle.jar]
Product alias = action.output
Product base = ${buckminster.output}/jar/
localhost=scm
target.nl=en_US
Base: /var/lib/jenkins/workspace/PG/g.o.p.c/bin: No such file or directory
INFO: [end g.o.p.c:osgi.bundle$1.2.0#bundle.jar]
Could this be a bug or am i missing something?
Sakis Kotisis
Senior Software Engineer
SciGen Technologies, S.A.
Re: eclipse.build does not generate class files when using Buckminster 4.2 on Jenkins [message #1047010 is a reply to message #1046358] |
Mon, 22 April 2013 13:10   |
Hello Thomas,
Following your recommendation, I tried the following both with Eclipse 3.8
and 4.2:
1) Checkout into new workspace from SVN through Subversive
2) Open target definition file and set as target platform
3) Buckminster > Invoke Action ... > site.p2
The p2 site is generated with the jars including the class files.
And then with headless Buckminster 4.2 on same system:
1) Checkout into new workspace from SVN through TortoiseSVN
2) Run the following script
importtargetdefinition -A 'F:/_Workspaces/bucky-pg/c.s.p.s/mirror.target'
import 'C:/Users/tkotisis/workspace/c.s.p.s/site.cquery'
build -c
perform -D target.os=win32 -D target.ws=win32 -D target.arch=* -D
cbi.include.source=false com.scigentech.postergenius.site#site.p2
The p2 site is generated with the class files MISSING from jars.
Below is an example of actions for a specific bundle:
!ENTRY org.eclipse.buckminster.core 0 293 2013-04-22 19:46:04.224
!MESSAGE init actor: eclipse.build[g.o.p.c:osgi.bundle$1.2.0#eclipse.build]
!ENTRY org.eclipse.buckminster.core 1 293 2013-04-22 19:46:04.226
!MESSAGE [start g.o.p.c:osgi.bundle$1.2.0#eclipse.build]
workspace.root=C:/Users/tkotisis/workspace
buckminster.temp=F:/TMP/bucky-pg/buildtmp/g.o.p.c_1.2.0-osgi.bundle/temp
buckminster.home=C:\Users\tkotisis\workspace\g.o.p.c\
buckminster.output=F:/TMP/bucky-pg/out/g.o.p.c_1.2.0-osgi.bundle
localhost=pavlos-PC
generator.buildTimestamp.format=2013-04-22T16:46:03.489+0000
target.nl=el_GR
eclipse.home=F:\TMP\buckminster4.2
!ENTRY org.eclipse.buckminster.core 1 293 2013-04-22 19:46:04.229
!MESSAGE [end g.o.p.c:osgi.bundle$1.2.0#eclipse.build]
!ENTRY org.eclipse.buckminster.core 0 293 2013-04-22 19:46:04.232
!ENTRY org.eclipse.buckminster.core 0 293 2013-04-22 19:46:04.234
!MESSAGE Action g.o.p.c:osgi.bundle$1.2.0#target.fragments using 'up to
date' policy ACTOR: Product is up to date
!ENTRY org.eclipse.buckminster.core 0 293 2013-04-22 19:46:04.237
!MESSAGE Action g.o.p.c:osgi.bundle$1.2.0#bundle.jar using 'up to date'
policy COUNT: Rebuild needed: File count(0) < expected(1)
!ENTRY org.eclipse.buckminster.core 0 293 2013-04-22 19:46:04.239
!MESSAGE init actor: ant[g.o.p.c:osgi.bundle$1.2.0#bundle.jar]
!ENTRY org.eclipse.buckminster.core 1 293 2013-04-22 19:46:04.242
!MESSAGE [start g.o.p.c:osgi.bundle$1.2.0#bundle.jar]
Product base = ${buckminster.output}\jar\
localhost=pavlos-PC
target.nl=el_GR
!ENTRY org.eclipse.buckminster.core 0 293 2013-04-22 19:46:04.245
!MESSAGE Base: C:\Users\tkotisis\workspace\g.o.p.c\bin: No such file or
directory
!ENTRY org.eclipse.buckminster.core 1 293 2013-04-22 19:46:04.344
!MESSAGE [end g.o.p.c:osgi.bundle$1.2.0#bundle.jar]
Of course, in case the IDE is used, the bundle projects are built on
checkout and on setting the target definition as well.
Hence, the directory \bin already exists and contains the class files
before Buckminster is called.
Is there anything else i could try to troubleshoot?
Sakis
On Sun, 21 Apr 2013 23:21:31 +0300, Thomas Hallgren <thomas@xxxxxxxx> wrote:
> I'd recommend that you create a new workspace from scatch in your IDE
> and see if the problem is visible there. Buckminster has no builder of
> it's own. It just calls on Eclipse to do the build, the same way your
> IDE does.
> - thomas
> On 2013-04-21 20:13, Sakis Kotisis wrote:
>> Hello,
>> features.
>> Features:
>> (%featureName)
>> localhost=scm
>> target.nl=en_US
>> init actor:
>> localhost=scm
>> target.nl=en_US
>> directory
Sakis Kotisis
Re: eclipse.build does not generate class files when using Buckminster 4.2 on Jenkins [message #1047101 is a reply to message #1047010] |
Mon, 22 April 2013 15:49   |
Don't see how you can make it work using win32.win32.*
Does it produce class files if you use win32.win32.x86 ?
- thomas
On 2013-04-22 19:10, Sakis Kotisis wrote:
> Hello Thomas,
> 3.8 and 4.2:
> build -c
> localhost=pavlos-PC
> target.nl=el_GR
> localhost=pavlos-PC
> target.nl=el_GR
> directory
> Sakis
>> IDE does.
>> - thomas
>>> Hello,
>>> features.
>>> Features:
>>> (%featureName)
>>> localhost=scm
>>> target.nl=en_US
>>> init actor:
>>> localhost=scm
>>> target.nl=en_US
>>> directory
Re: eclipse.build does not generate class files when using Buckminster 4.2 on Jenkins [message #1047492 is a reply to message #1047101] |
Tue, 23 April 2013 05:25   |
It doesn't.
It does from the IDE irrespective of the target flags.
The only difference i can discern in the logs when building from the IDE
(as opposed to building from headless), is that the flags appear for each
action.
For example, the log snippet corresponding to the same bundle when
building from the IDE is:
target.arch=*
workspace.root=F:/_Workspaces/bucky-pg
buckminster.home=F:\_Workspaces\bucky-pg\g.o.p.c\
buckminster.temp.root=F:/TMP/bucky-pg/buildtmp
localhost=pavlos-PC
generator.buildTimestamp.format=2013-04-23T08:34:12.813+0000
target.nl=el_GR
target.ws=win32
eclipse.home=C:\Eclipse\rcp-3.8-x86_64
buckminster.output.root=F:/TMP/bucky-pg/out
target.os=win32
target.arch=*
localhost=pavlos-PC
target.nl=el_GR
target.ws=win32
target.os=win32
This might be, because the flags are specified in a .properties file.
It probably doesn't make a difference, but i can't think of anything else.
Any other suggestions?
Sakis
> - thomas
>> Hello Thomas,
>> 3.8 and 4.2:
>> build -c
>> localhost=pavlos-PC
>> target.nl=el_GR
>> localhost=pavlos-PC
>> target.nl=el_GR
>> directory
>> Thanks,
>> Sakis
>>> IDE does.
>>> - thomas
>>>> Hello,
>>>> Jenkins.
>>>> below
>>>> features.
>>>> Features:
>>>> (%featureName)
>>>> localhost=scm
>>>> target.nl=en_US
>>>> init actor:
>>>> localhost=scm
>>>> target.nl=en_US
>>>> directory
Sakis Kotisis
Re: eclipse.build does not generate class files when using Buckminster 4.2 on Jenkins [message #1047801 is a reply to message #1047704] |
Tue, 23 April 2013 13:09   |
Hello Lorenzo,
Jenkins is running on Debian, but i'm reproducing the issue on win32 to
simulate my Eclipse IDE build as much as possible.
Indeed whether on linux or win32, headless build does not include the
class files.
On win32, building from the IDE with the same flags does.
Moreover, i tested a headless build of the Mail example RCP with a similar
script and everything worked fine.
This leads me to suspect that something in the way my RCP is structured
confuses Buckminster.
My site feature (the feature site.p2 is called on) includes several
features, unlike the Mail example RCP site feature which only includes one.
A lot of trial and error awaits, I would appreciate any hints.
On Tue, 23 Apr 2013 17:40:24 +0300, Lorenzo Bettini <bettini@xxxxxxxx.it>
wrote:
> But is your Jenkins running on a win32 platform?
Sakis Kotisis
Re: eclipse.build does not generate class files when using Buckminster 4.2 on Jenkins [message #1048131 is a reply to message #1047801] |
Wed, 24 April 2013 00:47   |
I assume that your JAVA_HOME on Jenkins appoints a JDK and not just a JRE?
Each project has an output folder for the compiler, typically denoted in
the hidden .classpath file like this:,
<classpathentry kind="output" path="bin"/>
Is that folder being created when you issue the build command? Does it
contain anything?
Does a 'build -c' and a 'build -t' yield the same output?
- thomas
On 2013-04-23 19:09, Sakis Kotisis wrote:
> Hello Lorenzo,
> class files.
> similar script and everything worked fine.
Re: eclipse.build does not generate class files when using Buckminster 4.2 on Jenkins [message #1048366 is a reply to message #1048131] |
Wed, 24 April 2013 07:06   |
Thank you for the pointers.
Buckminster is executed from Jenkins with the following command:
[PG] $ /usr/lib/jvm/jdk1.7.0/bin/java
-Dbuckminster.output.root=/var/lib/jenkins/workspace/PG/buckminster.output
-Dbuckminster.temp.root=/var/lib/jenkins/workspace/PG/buckminster.temp
-Xmx256m -jar
/var/lib/jenkins/tools/hudson.plugins.buckminster.BuckminsterInstallation/Buckminster_4.2/buckminster/plugins/org.eclipse.equinox.launcher_1.3.0.v20120522-1813.jar
-application org.eclipse.buckminster.cmdline.headless -data
/var/lib/jenkins/workspace/PG --loglevel debug -S
/var/lib/jenkins/workspace/PG/commands.txt
On my test system i call it directly with JDK1.6 :
"C:\Program Files\Java\jdk1.6.0_20\bin\java.exe"
-Dbuckminster.output.root=F:\TMP\bucky-pg\out
-Dbuckminster.temp.root=F:\TMP\bucky-pg\buildtmp -Xmx256m -jar
F:\_Eclipse\rcp-juno-x86_64\plugins\org.eclipse.equinox.launcher_1.3.0.v20120522-1813.jar
C:\Users\tkotisis\workspace --loglevel debug -S F:\TMP\bucky-pg-script.txt
classpathentry exists in the checked out bundle projects.
The build command is executed. The log is not very helpful though:
!ENTRY org.eclipse.buckminster.runtime 0 293 2013-04-23 11:24:04.694
!MESSAGE build '-c'
!ENTRY org.eclipse.buckminster.core 0 293 2013-04-23 11:24:04.954
!MESSAGE Doing full workspace refresh
!ENTRY org.eclipse.buckminster.core 0 293 2013-04-23 11:24:04.957
!MESSAGE Waiting for jobs to end
No bin folder is created for any bundle.
The result is the same with 'build -t'.
Let me describe the structure of my RCP, in case this might be helpful.
The RCP product is based on features, and is itself included in a feature:
<features>
<feature id="c.s.jre" version="1.6.13"/>
<feature id="org.eclipse.rcp"
version="3.6.2.r362_v20101104-9SAxFMKFkSAqi8axkv1ZjegmiBLY"/>
<feature id="org.eclipse.emf.common"/>
<feature id="org.eclipse.emf.common.ui"/>
<feature id="org.eclipse.emf.ecore"/>
<feature id="org.eclipse.emf.edit"/>
<feature id="org.eclipse.emf.edit.ui"/>
<feature id="c.s.org.eclipse.platform" version="1.0.0"/>
<feature id="c.s.org.eclipse.help" version="1.0.0"/>
<feature id="org.eclipse.nebula" version="1.0.0"/>
<feature id="org.eclipse.rest" version="3.4.2"/>
<feature id="c.s.pg.feature" version="1.21.0"/>
<feature id="c.s.pg.c" version="1.1.0"/>
<feature id="c.s.pg.co" version="1.0.5"/>
<feature id="c.s.pg.r" version="1.0.1"/>
<feature id="c.s.pg.f" version="1.1.1"/>
<feature id="c.s.pg.m.t" version="1.0.0"/>
<feature id="c.s.pg.c" version="1.15.0"/>
</features>
Note the 'c.s.pg.feature', which in turn includes the RCP product.
To build the p2 site with Buckminster, another feature was created,
'c.s.pg.site'.
It almost mirrors the product definition:
<feature
id="c.s.pg.site"
label="p2 Update Site"
version="1.0.0"
provider-name="ST">
<includes id="c.s.pg.c" version="0.0.0"/>
<includes id="c.s.pg.co" version="0.0.0"/>
<includes id="c.s.pg.core" version="0.0.0"/>
<includes id="c.s.pg.feature" version="0.0.0"/>
<includes id="c.s.pg.f" version="0.0.0"/>
<includes id="c.s.pg.m.t" version="0.0.0"/>
<includes id="c.s.pg.r" version="0.0.0"/>
<includes id="org.eclipse.emf.common" version="0.0.0"/>
<includes id="org.eclipse.emf.common.ui" version="0.0.0"/>
<includes id="org.eclipse.emf.ecore" version="0.0.0"/>
<includes id="org.eclipse.emf.edit" version="0.0.0"/>
<includes id="org.eclipse.emf.edit.ui" version="0.0.0"/>
<includes id="org.eclipse.nebula" version="0.0.0"/>
<includes id="org.eclipse.rest" version="0.0.0"/>
<includes id="org.eclipse.rcp" version="0.0.0"/>
<includes id="c.s.org.eclipse.help" version="0.0.0"/>
<includes id="c.s.org.eclipse.platform" version="0.0.0"/>
</feature>
Since the mail example RCP is built alright using the same script, i can
only assume Buckminster does not like something in my project structure.
> JRE?
> contain anything?
> - thomas
>> Hello Lorenzo,
>> class files.
>> one.
Sakis Kotisis
Re: eclipse.build does not generate class files when using Buckminster 4.2 on Jenkins [message #1048534 is a reply to message #1048452] |
Wed, 24 April 2013 11:58   |
I assume you mean listsite, right?
C:\Users\tkotisis>"C:\Program Files\Java\jdk1.6.0_20\bin\java.exe"
-Xmx256m -jar
F:\TMP\buckminster4.2\plugins\org.eclipse.equinox.launcher_1.3.0.v20120522-1813.jar
-application org.eclipse.buckminster.cmdline.headless --loglevel debug
listsite
listsite
Features:
org.eclipse.buckminster.product (%featureName)
(%featureName)
org.eclipse.equinox.p2.director.feature (%featureName)
However, building the mail example rcp (which builds ok) produces the log
output below.
Please note, besides some errors there is no log output either.
Could you, please, post a build log snippet, so i know what to look for?
!ENTRY org.eclipse.buckminster.runtime 0 293 2013-04-24 12:28:40.651
!MESSAGE build '-c'
!ENTRY org.eclipse.equinox.preferences 4 2 2013-04-24 12:28:41.291
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.equinox.preferences".
!STACK 0
java.lang.NoClassDefFoundError: Could not initialize class
org.eclipse.jface.preference.PreferenceConverter
at
org.eclipse.wb.internal.core.preferences.PreferenceInitializer.initializeDefaultPreferences(PreferenceInitializer.java:50)
at
org.eclipse.core.internal.preferences.PreferenceServiceRegistryHelper$1.run(PreferenceServiceRegistryHelper.java:300)
at
org.eclipse.core.internal.preferences.PreferenceServiceRegistryHelper.runInitializer(PreferenceServiceRegistryHelper.java:303)
at
org.eclipse.core.internal.preferences.PreferenceServiceRegistryHelper.applyRuntimeDefaults(PreferenceServiceRegistryHelper.java:131)
at
org.eclipse.core.internal.preferences.PreferencesService.applyRuntimeDefaults(PreferencesService.java:368)
at
org.eclipse.core.internal.preferences.DefaultPreferences.applyRuntimeDefaults(DefaultPreferences.java:166)
at
org.eclipse.core.internal.preferences.DefaultPreferences.load(DefaultPreferences.java:237)
at
org.eclipse.core.internal.preferences.EclipsePreferences.create(EclipsePreferences.java:410)
at
org.eclipse.core.internal.preferences.EclipsePreferences.internalNode(EclipsePreferences.java:663)
at
org.eclipse.core.internal.preferences.EclipsePreferences.node(EclipsePreferences.java:805)
at
org.eclipse.core.internal.preferences.AbstractScope.getNode(AbstractScope.java:38)
at
org.eclipse.core.runtime.preferences.DefaultScope.getNode(DefaultScope.java:76)
at
org.eclipse.ui.preferences.ScopedPreferenceStore.getDefaultPreferences(ScopedPreferenceStore.java:250)
at
org.eclipse.ui.preferences.ScopedPreferenceStore.getPreferenceNodes(ScopedPreferenceStore.java:285)
at
org.eclipse.ui.preferences.ScopedPreferenceStore.internalGet(ScopedPreferenceStore.java:475)
at
org.eclipse.ui.preferences.ScopedPreferenceStore.getBoolean(ScopedPreferenceStore.java:387)
at
org.eclipse.wb.internal.core.editor.describer.JavaSourceUiDescriber.isGUISource(JavaSourceUiDescriber.java:65)
at
org.eclipse.wb.internal.core.editor.describer.JavaSourceUiDescriber.describe(JavaSourceUiDescriber.java:52)
at
org.eclipse.core.internal.content.ContentTypeCatalog.describe(ContentTypeCatalog.java:218)
at
org.eclipse.core.internal.content.ContentTypeCatalog.collectMatchingByContents(ContentTypeCatalog.java:190)
at
org.eclipse.core.internal.content.ContentTypeCatalog.internalFindContentTypesFor(ContentTypeCatalog.java:403)
at
org.eclipse.core.internal.content.ContentTypeCatalog.internalFindContentTypesFor(ContentTypeCatalog.java:450)
at
org.eclipse.core.internal.content.ContentTypeCatalog.getDescriptionFor(ContentTypeCatalog.java:346)
at
org.eclipse.core.internal.content.ContentTypeCatalog.getDescriptionFor(ContentTypeCatalog.java:360)
at
org.eclipse.core.internal.content.ContentTypeMatcher.getDescriptionFor(ContentTypeMatcher.java:86)
at
org.eclipse.core.internal.resources.ContentDescriptionManager.readDescription(ContentDescriptionManager.java:445)
at
org.eclipse.core.internal.resources.ContentDescriptionManager.getDescriptionFor(ContentDescriptionManager.java:355)
at
org.eclipse.core.internal.resources.File.internalGetCharset(File.java:246)
at org.eclipse.core.internal.resources.File.getCharset(File.java:207)
at org.eclipse.core.internal.resources.File.getCharset(File.java:194)
at
org.eclipse.jdt.internal.core.util.Util.getResourceContentsAsCharArray(Util.java:1156)
at
org.eclipse.jdt.internal.core.builder.SourceFile.getContents(SourceFile.java:79)
at org.eclipse.jdt.internal.compiler.ReadManager.run(ReadManager.java:173)
at java.lang.Thread.run(Thread.java:619)
!ENTRY org.eclipse.equinox.preferences 4 2 2013-04-24 12:28:41.295
!STACK 0
java.lang.ExceptionInInitializerError
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Caused by: org.eclipse.swt.SWTException: Invalid thread access
at org.eclipse.swt.SWT.error(SWT.java:4361)
at org.eclipse.swt.SWT.error(SWT.java:4276)
at org.eclipse.swt.SWT.error(SWT.java:4247)
at org.eclipse.swt.widgets.Display.error(Display.java:1258)
at org.eclipse.swt.widgets.Display.checkDevice(Display.java:764)
at org.eclipse.swt.widgets.Display.getSystemFont(Display.java:2459)
at
org.eclipse.jface.preference.PreferenceConverter.<clinit>(PreferenceConverter.java:84)
... 35 more
!ENTRY org.eclipse.equinox.preferences 4 2 2013-04-24 12:28:41.298
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.buckminster.core 0 293 2013-04-24 12:28:43.125
>> -Xmx256m -jar
>> !MESSAGE build '-c'
> Something here isn't right. The actual build does nothing. If it did,
> there should be some message indicating that fact.
> What features do you have installed in the Headless Buckminster? Is the
> PDE feature present? What's the output of buckminster lscmd ?
> - thomas
Sakis Kotisis
Re: eclipse.build does not generate class files when using Buckminster 4.2 on Jenkins [message #1048557 is a reply to message #1048534] |
Wed, 24 April 2013 12:36   |
Sorry, the log in my previous email was from building with an IDE
Buckminster.
Building the mail example rcp with headless Buckminster, produces the same
(thrifty) build step log output as building my rcp.
I do the following:
1) Copy mail example rcp project files to folder
'C:\Users\tkotisis\workspace2'
2) Delete 'bin' and .settings folder
3) Execute the following command
-Dbuckminster.output.root=F:\TMP\buckymail\out
-Dbuckminster.temp.root=F:\TMP\buckymail\buildtmp -Xmx256m -jar
C:\Users\tkotisis\workspace2 --loglevel debug -S
F:\TMP\buckytest-script.txt
, with following script
'F:/_Workspaces/buckytest/com.example.mail.site/rcp.target'
import 'C:/Users/tkotisis/workspace2/com.example.mail.site/site.cquery'
build -c
perform -D target.os=win32 -D target.ws=win32 -D target.arch=x86_64 -D
cbi.include.source=false com.example.mail.site#site.p2
OUTCOME
The bin folder is generated in 'com.example.mail' bundle.
The log output for the build step is:
!ENTRY org.eclipse.buckminster.runtime 0 293 2013-04-24 19:22:14.689
!MESSAGE build '-c'
!ENTRY org.eclipse.buckminster.core 0 293 2013-04-24 19:22:16.420
!ENTRY org.eclipse.buckminster.core 0 293 2013-04-24 19:22:16.439
On Wed, 24 Apr 2013 18:58:29 +0300, Sakis Kotisis
> -Xmx256m -jar
> listsite
> listsite
> Features:
> (%featureName)
> log output below.
> !MESSAGE build '-c'
> !STACK 0
> at
> at
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 35 more
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
>>> -Xmx256m -jar
>>> !MESSAGE build '-c'
>> - thomas
Sakis Kotisis
Re: eclipse.build does not generate class files when using Buckminster 4.2 on Jenkins [message #1051096 is a reply to message #1047801] |
Sun, 28 April 2013 03:32   |
can you share your code?
On 04/23/2013 07:09 PM, Sakis Kotisis wrote:
> Hello Lorenzo,
> class files.
HOME: http://www.lorenzobettini.it
Re: eclipse.build does not generate class files when using Buckminster 4.2 on Jenkins [message #1051897 is a reply to message #1051096] |
Mon, 29 April 2013 06:42   |
If you mean the source code for the app i'm building, i'm afraid it's
closed source.
If you mean the Buckminster related files, please look at the end of this
mail.
I've tried several things since my last post:
* restructuring my app to mirror the Mail example RCP (single feature
including plug-ins and features)
* creating the Mail example RCP with Eclipse 3.6 and building with
Buckminster 4.2 (since my app targets Eclipse 3.6)
* fixing some plug-in warnings related to JRE execution environment
* removing any mac-only plug-ins (since building on win32)
* calling 'build -c' or 'build -t' multiple times before 'perform' in the
build script
The problem remains the same: no bin folder in the bundles being built, no
errors in log output.
The app seems assembled ok, but there are no .class files in the jars.
According to Thomas, the 'build' command should produce some output in the
logs.
However, the Mail example RCP builds fine (including the .class files),
without any additional output appearing in the log file related to the
build.
I can't think of anything else besides debugging at this point!
site.cquery:
<cq:componentQuery
xmlns:cq="http://www.eclipse.org/buckminster/CQuery-1.0"
resourceMap="site.rmap">
<cq:rootRequest name="com.example.mail.site"
componentType="eclipse.feature"/>
</cq:componentQuery>
site.rmap:
<rm:rmap xmlns:bc="http://www.eclipse.org/buckminster/Common-1.0"
xmlns:rm="http://www.eclipse.org/buckminster/RMap-1.0">
<rm:locator searchPathRef="resources"/>
<rm:searchPath name="resources">
<rm:provider componentTypes="osgi.bundle,eclipse.feature"
readerType="local" source="false">
<rm:property key="buckminster.source" value="false"/>
<rm:uri format="file:///{0}/{1}/">
<bc:propertyRef key="workspace.root" />
<bc:propertyRef key="buckminster.component"/>
</rm:uri>
</rm:provider>
</rm:searchPath>
</rm:rmap>
buckminster script:
'F:/_Workspaces/bucky-pg/c.s.p.site/mirror.target'
import 'C:/Users/tkotisis/workspace/c.s.p.site/site.cquery'
build -c
perform -D target.os=win32 -D target.ws=win32 -D target.arch=x86 -D
cbi.include.source=false c.s.p.site#site.p2
On Sun, 28 Apr 2013 10:32:24 +0300, Lorenzo Bettini <bettini@xxxxxxxx.it>
>> Hello Lorenzo,
>> class files.
>> one.
Sakis Kotisis
Re: eclipse.build does not generate class files when using Buckminster 4.2 on Jenkins [message #1051932 is a reply to message #1051897] |
Mon, 29 April 2013 07:45   |
Without the sources it's kind of hard to detect where the problem is :)
(well, almost surely, the problem is some of your bundles/features)...
it looks like you resolve your target platform using a target definition
file; I guess that target definition files refers only to win32 right?
Since, IIRC, in the past some problems were experienced when the actual
os,ws,arch was not specified in the .cquery, why don't you try to
specify it?
<cq:property key="target.arch" value="*"/>
<cq:property key="target.os" value="*"/>
<cq:property key="target.ws" value="*"/>
but that's just a guess...
cheers
Lorenzo
> closed source.
> this mail.
> the build script
> no errors in log output.
> the logs.
> build.
> site.cquery:
> <cq:componentQuery
> site.rmap:
> </rm:uri>
> </rm:provider>
> </rm:searchPath>
> </rm:rmap>
> buckminster script:
> build -c
>>> Hello Lorenzo,
>>> class files.
>>> includes one.
Re: eclipse.build does not generate class files when using Buckminster 4.2 on Jenkins [message #1052831 is a reply to message #1046297] |
Tue, 30 April 2013 11:56   |
I started debugging the build process with headless Buckminster.
During the org.eclipse.buckminster.core.commands.Build,
wsRoot.getProjects() returns 0 projects, even after the refresh?
The reason is that the SVN checkout is taking place from TortoiseSVN (or
in the case of Jenkins, it's SVN client) before there is an actual
workspace.
Could this be the culprit? This would certainly explain why no bundle is
actually being built.
Buckminster import and perform isn't bothered, since it only checks paths
through it's rmap.
However this leaves the question open: how can a build be accomplished
with headless Buckminster without materializing the source but checking it
out from SVN?
On Sun, 21 Apr 2013 21:13:58 +0300, Sakis Kotisis
> Hello,
> features.
> Features:
> (%featureName)
> localhost=scm
> target.nl=en_US
> init actor:
> localhost=scm
> target.nl=en_US
> directory
Sakis Kotisis
Re: eclipse.build does not generate class files when using Buckminster 4.2 on Jenkins [message #1052843 is a reply to message #1052831] |
Tue, 30 April 2013 12:46   |
I think that's quite the standard situation with Jenkins: the job is
configured to fetch/update the repository before the actual build
step... at least in my case, I always setup my Jenkins job like that
(though in my case I use git all the time).
The rmap can be configured to read from the local file system instead of
svn, and, indeed, you already do that:
</rm:uri>
</rm:provider>
</rm:searchPath>
</rm:rmap>
but you need to make sure that the components can be found in
workspace.root which in your case is /var/lib/jenkins/workspace/PG if I
understand correctly, or you need to pass the correct property value for
workspace.root... moreover you use source to false, and also
buckminster.source to false...
I usually use
<rm:provider componentTypes="eclipse.feature,osgi.bundle,buckminster"
readerType="local" mutable="false">
<rm:property key="buckminster.mutable" value="false"/>
I also use
<rm:uri format="{0}/{1}">
since the workspace.root should be already absolute...
I don't know whether these are the problems
> workspace.
> paths through it's rmap.
> it out from SVN?
>> Hello,
>> below features.
>> Features:
>> (%featureName)
>> localhost=scm
>> target.nl=en_US
>> init actor:
>> localhost=scm
>> target.nl=en_US
>> directory
Re: eclipse.build does not generate class files when using Buckminster 4.2 on Jenkins [message #1052973 is a reply to message #1052843] |
Wed, 01 May 2013 12:49   |
Thanks for the help Lorenzo.
I'm pretty sure though, that this the reason the bundles are not being
built.
I.e. during org.eclipse.buckminster.core.commands.Build execution,
Buckminster does not find any projects in it's workspace.
I also tried with source="true" and mutable="false".
I don't understand why it works with the Mail example RCP though, or in
your case.
Maybe by refreshing the workspace, it picks up the projects.
Thomas could shed some light.
In the meantime I'm trying to materialize the source from SVN with
Buckminster.
Let's see how this goes.
On Tue, 30 Apr 2013 19:46:41 +0300, Lorenzo Bettini <bettini@xxxxxxxx.it>
> </rm:uri>
> </rm:provider>
> </rm:searchPath>
> </rm:rmap>
> I usually use
> I also use
>> workspace.
>> it out from SVN?
>>> Hello,
>>> below features.
>>> Features:
>>> (%featureName)
>>> localhost=scm
>>> target.nl=en_US
>>> init actor:
>>> localhost=scm
>>> target.nl=en_US
>>> directory
Sakis Kotisis
Re: eclipse.build does not generate class files when using Buckminster 4.2 on Jenkins [message #1053022 is a reply to message #1052973] |
Thu, 02 May 2013 01:50  |
Hi Sakis,
I'm back to my original recommendation. Start with an empty workspace in
your IDE. Repeat the steps there. Its important that you do an SVN check
out that your IDE has no knowledge of!
Run your query from inside the IDE. That should result in your workspace
being populated with projects. If it doesn't, then something is wrong
and there should be a clear indication as to what that is.
As Lorenzo mentioned, using source="false" will never work for things
that you want Bucky to consider as projects.
- thomas
> built.
> your case.
> Buckminster.
>> <?xml version="1.0" encoding="UTF-8"?>
>> </rm:uri>
>> </rm:provider>
>> </rm:searchPath>
>> </rm:rmap>
>> I usually use
>> I also use
>>> workspace.
>>> it out from SVN?
>>>> Hello,
>>>> below features.
>>>> Features:
>>>> (%featureName)
>>>> localhost=scm
>>>> target.nl=en_US
>>>> init actor:
>>>> localhost=scm
>>>> target.nl=en_US
>>>> directory
Current Time: Sat Jul 19 16:22:18 EDT 2025
Powered by FUDForum. Page generated in 0.09914 seconds
